Monday, Jul 06, 2009 at 21:06
Something else I learned - about electrical sources that can and will ignite those trapped flammable fumes.
Guy I know of set his boat alight at sea off
Darwin with a under deck
fuel spill, resulting in an 18 hours swim and long barefoot walk thru the crock infested and oyster encrusted
mangroves back to
Darwin to get help.
It was a small 16 ft center console with an underfloor
tank.
One of the
fuel hoses split with age & perishing and there was maybe a half cup full of
fuel floating on top of normal bilge
water.
He lifted the floor hatch, when he smelled petrol fumes, and saw some of the
fuel floating on top of the
water.
He did make a precautionary "mayday call" on his radio, but hadn't got round to giving his exact position (1st mistake) - just mentioning that he had small
fuel spill underfloor and MIGHT be needing help if he couldn't deal with it and a ROUGH location - said he would call again when all was under control.
He was worried that the triggering of the radio & mike, might set off a spark to ignite the
fuel, so only made that first radio call and kept it short with no ECACT location (Lats and Longs).
Then he got worried about any stray electrical sparks, that might start a fire so decided to disable the starting battery system etc by turning the Cole Hersey type isolator switch off.
That was his 2nd mistake that nearly cost him and his mate their lives & what created the spark that set it alight.
His thinking was right - a
fuel tank leak COULD elevate the auto bilge switch level as tho it were
water under deck increasing in depth and cause the bilge pump to auto float switch start or trigger a high
water alarm.
Such bilge pumps are designed to pump
water not petrol - the electrical engine within is NOT spark shielded in any way, and more than one bilge pump has blown up a boat with a leaking
fuel tank below decks before today.
His problem was - he had the WRONG type of Cole Hersey isolator switch fitted to his boat, it was an automotive type NOT a marine type.
There is a difference?????
You bet there is and to this day on automotive and rec boating sites in Oz I've never seen this mentioned.
There are two type of these battery isolators, automotive and marine.
Heres the difference for those who don't know.
Automotive are whats called "make before you break" isolators, and Marine are whats called "BreaK Before You Make" isolators.
As all offroaders know, these multiple battery setups utilise these cole hersey type switches to connect and disconnect various arrangements of multiple batteries.
The "Make Before You Break" type are set up to break one circuit before you connect and make the second circuit.
These can be a problem for some types of engines especially thosenewer types with sensitive electronically controlled computer ignitions and
fuel injection systems etc and alternators with diodes etc.
It's not good for some of these to be without anywhere for the current to go when the alternator is spinning!
For this reason we hear of rules like:-
"Never siwtch thru the "OFF" position while the engine/s are running!"
This is because IF they break the first circuit before making the next circuit - we are momentarilly left with a alternator making current with no battery for it to go too.
Results can be spattered diodes in the alternator or loss of computer default manufacturer settings while there is a momentary power loss.
Another type of Cole Hersey type switch for marine use is the "Make Before Break" type - where the connector position within the switch is set such that the second circuit is made before the first circuit connection is broken.
This type allows a continuous flow of electricity, while the changes are being made.
The same Rule as above tho still applies because at the OFF position - the circuits ARE broken totally - so again regardles of the type of switch you should STILL "never switch thru the OFF position while the engine is running", no matter how fast you think you can twist it.
Using the Make before you break type of switch theres far LESS tendency for a spark to jump to the next connector because the crucuit is already open via the previous connector before it is broken - the next is already connected.
If you wanted too you could think of the make before you break type cole hersey switch as a "sparkless" connector and the agricultural auto type 4wd cole hersey break before you make variety as the "spark" type.
Using the wrong one (spark vulnerrable type in the WRONG application) i.e where any type of flammable fumes might be present, can be a very very BAD idea.
Now I will give you some examples to think about for the offroaders!!
Charging batteries emits oxygen gas - a invisible tasteless odourless but non the less explosive potential gas.
Lets say I build myself a offroad camper trailer, or buy one from a manufactuirer who knows nothing about the differences between types of cole hersey isolator switchs and uses the cheaper auto type.
Maybe you have a bank of batteries under the bed in a special built battery box / drawer arrangement?.
Guess what?
When you charge those batteries, while travelling thru a 7 pin aux power connection between trailer and vehicle or even while at rest - IF you have the WRONG (cheaper auto type break before you make type circuit connection) cole hersey type switch - and it's mounted within the van and you are unfortunate enough to switch it and create a spark in all that hydrogen gas - maybe it will be the last thing you ever do.
Same for second and 3rd batteries in the rear of utes with canpopy covers or tonneau covers or in the rear of enclosed 4wd wagons etc.
I see LOTS of cole herseys fitted inside 4wds - almost any vehicle with mutliple batteries and
winches and fridges freezers and heaps of spotties etc etc seems to have them.
Haven't seen one yet that was a marine type Make before you break circuit switch of the Cole Hersey variety.
Those agricultural automotive break before you make variety should ONLY ever be fitted in the open air under a bonnet for example NOT within a enclosed passenger cab space where extra batteries are contained, and oxygen can be generated by charging the battery.
It would be far safer for all 4wd's to just fit the marine continuous circuit make before break type switch IMHO specially for those campers with batteries banks under the bed etc.
How many folks even know there is a difference??.
The guy with the boat and his passenger survived their ordeal - I can tell you 100% he will NEVER forget there is a difference and his NEXT boat he won't skimp and fit an automotive break before make type of Cole Hersey Switch.
Boats saw the black smoke from his boat fire on the horizon not long after his first mayday call, but because they didn't have any exact location, took some time to find the actual spot from his "rough location description" and by then he 'n the mate had made a swim for it, floating on the ice box, and the big tides moved them many
miles in quick time - long before the searching boats got anywhere near their burning boat, it burnt to the
water line and sank.
His stories about the 18 hour swim and the big sharks that came to "investigate and bump them" thru the night - are enough to curl your hair.
Simple things that we don't know can easily kill us.
Knowledge is no weight to carry around.
Do a little google searching about "make before you break marine battery isolator switches" and become knowledgeable.
You might be the ONLY one in your 4wd club who actually knows! ;o)
Cheers & beers
640527
