telstra external aerial guru,s
Submitted: Tuesday, Jul 07, 2009 at 13:14
The Geriatric Gypsies
gooday all from sunny alva baech fnq
a question for the telstra external aerial gurus can i cut the aerial lead and install a plug setup thru the wall of our caravan (similar to a external tv aerial)so that i can get access to the aerial !)without having to drill a permanant hole thru the wall or 2) leave our wireless modem outside when the aerial is connected
will this create to much resistance even with top quality connections
steve
Reply By: Gone Bush (WA) - Tuesday, Jul 07, 2009 at 15:18
Steve,
don't cut the cable.
Get one of these from most caravan accessory
places.
Image Could Not Be Found
It's called an Ezy-eye. It allows you to pass the cable through the wall and when you've finished you can plug the ezy-eye.
I've installed one myself. Very easy.
It'll cost you $30.
373461
Follow Up By: Gone Bush (WA) - Tuesday, Jul 07, 2009 at 15:25
Steve's here's a better picture so you can see how it works:
640596
Reply By: The Geriatric Gypsies - Tuesday, Jul 07, 2009 at 19:34
goodday steve
thanks for the reply looks like it may
well do the job i will have a look along the way and see what i can find
thank you
steve
373503
Follow Up By: paulnsw - Thursday, Jul 09, 2009 at 08:00
You can install a cable permanently and use a screw together fitting at the aerial or externally. You will need to protect the end from moisture.
Installed a GME marine NextG aerial permanently. Folds down at the side of the van. Modem is under
seat and all permanently connected up. Put power switch on front of
seat. One of the best things I did after seeing the idea on the RVtravel
forum
640841
