Tow bar electric plug testing
Submitted: Tuesday, Jul 07, 2009 at 16:17
ThreadID: 70465 Views:11042 Replies:8 FollowUps:4
OK, have the towbar but have never towed anything. Wife keen to try out some camper trailers that are on hire sooner than later.
Q is other than drive the car out to visit them, is there any way I can test out if my electrics connection beside the towbar works as expected without actually attaching it to a caravan/trailer etc?
I have a few multimeters and think I am handy but there seems a lot of pins .... more used to the pos and neg ....
Reply By: A J - Tuesday, Jul 07, 2009 at 16:35
Porl - google 7 pin flat trailer plug - and it will take you into sites with all types of trailer electrical connections.
Find the sort that you have connected to your car.
Use your multimeter to work out if power is coming through each connection - remember which wire is the earth.
A J
AnswerID: 373466
Follow Up By: Member - Porl - Tuesday, Jul 07, 2009 at 16:44
Ok, that's a great start then, 6 to have power and 1 earth.
thanks
FollowupID: 640603
Reply By: escapesilv - Tuesday, Jul 07, 2009 at 17:26
Hi Porl
Not necessarily will you have power in the remaining 6, in my case you only have power in 4 of them, that is 2 for blinkers, one for driving lights and one for brakes. and of cause the negative.
Robert
AnswerID: 373481
Reply By: Member - Ian H (NSW) - Tuesday, Jul 07, 2009 at 17:35
Maybe ask a neighbour if you can connect to his trailer/van to try it.
AnswerID: 373485
Reply By: Tenpounder (SA) - Tuesday, Jul 07, 2009 at 18:20
Hi there. Please don't overlook the fact that a heavier trailer may have electric brakes. These are NOT powered by the brake light wire which is part of the 'normal' 7 pin payout. The electric brake actuation will have to be provided separately. In my case, they used the 'normal' reversing light connectors, and wired the controller to that.
So be ready, if you pick up a ready wired CT with electric brakes: you'll need a controller (unless they have fitted a drawbar controller) and suitable wiring to the connector.
The electric brake wiring will not b shown in the usual pin layout diagram.
Does this make sense?? Hope so.
AnswerID: 373491
Follow Up By: Tenpounder (SA) - Tuesday, Jul 07, 2009 at 21:21
Hi Please see Graham H comments below. He's righ, and I was wrong: as Graham says, the brakes are wired to the blue wire, NOT the red brake light wire. And the (black) reversing light circuit (in my case) was used for the 12v supply to the van. Sorry if I confused you.
FollowupID: 640649
Reply By: Member - Royce- Tuesday, Jul 07, 2009 at 18:29
If you have never towed, then start carefully and do some research on correctly loading your trailer. Try braking and cornering and different surfaces at different speeds.
I amazes me that we don't have to have specially endorsed licences before we tow. Even 6x4 trailers are killers until experienced.
Good luck...
AnswerID: 373492
Reply By: Member - Richard C (ACT) - Tuesday, Jul 07, 2009 at 19:15
To see if the car attachement is working I bought a new 7 pin attachement - the bit that goes on the caravan. It has lights on it to tell you if the car ones are working. I just plug that one in.
Not the best way to do it but it tells me if the car is at least working OK.
Would be good the other way around ie plug in to the camper but would need a power source
Richard
AnswerID: 373501
Reply By: Member - Toyocrusa (NSW) - Tuesday, Jul 07, 2009 at 19:56
G'day Porl. The standard plug these days is flat so I'm assuming that is what you have.I use a test light but a multimeter does the same. The centre pin is always earth.The RH outer is Right blinker,the next one in is tailights. LH side is Left blinker and the next one in is brakelights. The two either side of centre are auxilliary and reverse lights. The caravan brake controller normally operates through the auxilliary pole. Hope that helps. Bob.
AnswerID: 373507
Follow Up By: Member - Graham H (QLD) - Tuesday, Jul 07, 2009 at 20:11
The electric brake wire is usually on Pin 5 and should always be blue.
It is on a 7 Pin large round
FollowupID: 640630
Reply By: Member - Porl - Tuesday, Jul 07, 2009 at 21:57
uhm, i hope you have all confused each other cause I am whacked, though will faithfully try every post before I give up and find a trailer to plug it into. Electric brakes hmmm, ok, will put that one on a postie on the dashboard ...
AnswerID: 373530
Follow Up By: Member - Porl - Tuesday, Jul 07, 2009 at 22:00
Of course that was tongue in cheek and I am enormously grateful for the responses which although makes everything more complex does make me far less ignorant and far more knowledgeable about what I don't know which is a good thing for finding out something I should know.
FollowupID: 640660
