Where to fit solar panels and battery care
Submitted: Thursday, Jul 09, 2009 at 07:13
ThreadID: 70509 Views:3628 Replies:4 FollowUps:7
A few of questions.
Q1
I am looking at a caravan which has solar panels.
Are solar panels a good idea?
Would it be best to mount the solar panel on the roof or perhaps get a portable one that can be moved.
If on the roof it is a bit out of site - good and bad I suppose.
I guess the good is that it would be charging all the time except when stored if using a cover and can't easily be stolen.
Bad is it is difficult to clean, check if not broken and may be not be in an optimal position.
Q2 A bit of a dumb one, but I don't know the answer
How do people take care of the caravan batteries when the caravan is in extended storage - say 6+ months.
Richard
Reply By: Member - Willie , Sydney. - Thursday, Jul 09, 2009 at 07:30
Hi Richard,
I have got 4 x 130s on the roof of my 16 ft Bushtracker. A bit of an overkill, but peace of mind on cloudy days.
It would be crazy to put them any other place, even though they are out of the way regarding cleaning. Portable they take up heaps of space and they would have to be too small to be of much use.
I only clean mine at the start of a trip. I use a car washing brush with a long handle and just lean a ladder against the side of the van. Pretty easy really.
Some people rig up a trickle charger for long storeage. Mine is out in the weather, so it's no problem.
Willie.
AnswerID: 373709
Follow Up By: Member - Richard C (ACT) - Thursday, Jul 09, 2009 at 08:35
Willie,
Thanks for the reply.
So by leaving it out you rely on the solar to keep the batteries charged?
Richard
FollowupID: 640850
Follow Up By: Member - Willie , Sydney. - Thursday, Jul 09, 2009 at 08:41
Yes Richard, the panels are constantly charging. The charger and regulator see that the battery is not cooked ( I think ! I am an electronic creton).
Willie
FollowupID: 640851
Follow Up By: Member - Richard C (ACT) - Thursday, Jul 09, 2009 at 09:32
Willie,
I understand your terminology so you are not alone :)
Richard
FollowupID: 640858
Reply By: Maîneÿ . . .- Thursday, Jul 09, 2009 at 09:15
Richard,
Solar panels are in fact an absolutely fantastic idea, ask anyone who has a decent Solar system and it will be readily confirmed, only those with-out a decent Solar system will disagree in some way.
As to where you mount them is ruled by where you park when living out in the bush, if it's under the trees for all the shade you can get, then obviously not on the roof, because they do require copious amounts of sunshine to do what you need them to do - charge your batteries.
When your camped in the shade, you will need to use them on an extension lead and they can be placed out in the sun to charge your batteries.
When on the roof the batteries will be maintained in a fully charged state while your parked in the shopping centre car park, visiting the local scenic areas and sight seeing etc...
I would consider using a combination of mounting two on the roof and one to be placed out in the sun when your camped in the shade.
I've had a Solar system mounted on the vehicle roof since 1996 and has not been removed for more than a week in all those years.
They get cleaned when it rains, and if they look very dirty I use a wet broom on the surface as it removes any garbage quickly and easily, dust etc will be removed as you travel, simply by movement of air over the panel surface.
Maîneÿ . . .
AnswerID: 373719
Follow Up By: Member - Richard C (ACT) - Thursday, Jul 09, 2009 at 09:36
Mainey,
It seems like the roof is the place to go and if I can afford it to also include a portable one.
The caravan I am looking at, the solar is an option but expensive - but from yours and Willie's response it does seem like it would be worth it.
Many thanks
Richard
FollowupID: 640859
Follow Up By: Maîneÿ . . .- Thursday, Jul 09, 2009 at 09:45
You say: "The caravan I am looking at, the solar is an option but expensive"
So check out the price at various other suppliers first before making the decision.
Remember not all Solar panels are created equal, some are much more efficient than others
( as in "oils ain't oils" )
Maîneÿ . . .
FollowupID: 640864
Follow Up By: Member - Richard C (ACT) - Thursday, Jul 09, 2009 at 10:38
Mainey,
Will do - the price includes the wiring and fitting. I need to find out a lot more :)
Richard
FollowupID: 640869
Reply By: Mandrake - Thursday, Jul 09, 2009 at 11:48
In addition to the above try this calculator -
Solar calculator
It will help you determine what size solar unit you require ..
A smaller mobile panel say 50 watts would be a good size for trickle charging your batteries when the van is at home under cover ..
Rgds
Steve
AnswerID: 373736
Follow Up By: Maîneÿ . . .- Thursday, Jul 09, 2009 at 14:06
Can't have too many Watts (Amps) available, but too little will always a very major problem :-)
The van must have an effective 3 stage Solar *regulator* installed near the DC battery system, this regulator allows the solar system to remain operational 24/7, therefore maintaining the DC battery system in peak condition and ready to go away at any time with-out any extra charging required, unless the van is in a garage or under a roof with Solar panels not in sunlight.
Maybe two panels can be attached to the van roof and one panel can be used remotely in the bush and at home too?
If the Solar panels can be installed on a 'quick un-install' frame system it can be removed and used when the van is in the bush under the shady cover of trees and also when the van is parked in a garage or under cover at home too
Maîneÿ . . .
FollowupID: 640894
Reply By: Member - Mary W NW VIC - Thursday, Jul 09, 2009 at 19:03
A quick uninstall frame sounds the goods!
Does anyone have a pic or two of such a device?
Thanks,
Mary
"Some people walk in the rain,others just get wet."
AnswerID: 373808
