Thursday, Jul 23, 2009 at 23:00
From what I have been able to find out the 2007 oil consumption problem on some early ones was to do with scavenger pump issues and not piston ring problems. Could be wrong but found this on Google searches, credibility unknown. Am I wrong to think it is 2009 and to think that some early problems are now corrected. My 2009 model does not use oil, does not blow turbochargers etc etc. The others I know of are mainly 2008, one might be a 2007. Must ask the owner next time I see him.
The Manual that came with my vehicle stresses the need for diesel without
water. I am not a mechanic but I would
hazard an opinion that if you hit any common rail system with
water you will have problems. So if one fills up out of industrial or dodgy farm tanks with lots of
water there will be problems. This is not a Toyota problem but more an issue of abuse of the equipment. Even my diesel ride on mower manual warns on this and as far as know it does not have a common rail engine.
There is a light on the dash of the landcruiser that warns if the
fuel filter has picked up too much
water and it requires IMMEDIATE attention and damage will follow if it is ignored (that is my interpretation of the manual). It is not hard to clear it. The manual explains how. Yes I did take the time to read it. The manual states the filter cannot cope with an abnormally high amount of
water in the
fuel. That said I do know personally of one bloke who did use pretty dodgy
fuel and had some rough running that was fixed. It did not cost much either. It was not a big deal.
I prefer to fill up at truckstops and not out of drums. If filling out of drums, is it not standard practice to use a filter that will catch
water and other muck? If this is not done then don't whinge about the consequences.
The common rail engines do require cleaner
fuel and better filters than before. This is a bit of a disadvantage, no doubt. Offsetting this disadvantage is better power, better
fuel economy and cleaner emissions.
Love my cruiser!
643277
