parallel bearings
Submitted: Wednesday, Aug 05, 2009 at 21:28
ThreadID: 71245 Views:6585 Replies:6 FollowUps:4
was wondering of the benefits of having parallel bearings compared to tapered?
Reply By: Member - Graham H (QLD) - Wednesday, Aug 05, 2009 at 21:39
As used in what.
AnswerID: 377712
Reply By: pop2jocem - Wednesday, Aug 05, 2009 at 21:49
Parallel bearings (roller bearings) such as used in early Landcruiser wheel hubs were used where the end of the axle in the diff was fixed and the hub end could move as the axle heated and therefore expanded. Also the machining tolerances did not need to be as exact as this allowed some axial mismatching.
Cheers Pop
AnswerID: 377717
Reply By: Richard Kovac - Wednesday, Aug 05, 2009 at 21:52
parallel bearings can only take a load in one direction
Tapered bearings can take a load in two directions
AnswerID: 377718
Reply By: Member - Ed. C. (QLD) - Wednesday, Aug 05, 2009 at 21:59
If you're asking about trailer wheel bearings, the (so called) 'parallel bearings' refers to the fact the axle shaft is machined well, umm, parallel.. (fancy that;-))..
The bearings are standard tapered roller bearings, and the inner and outer bearings are (usually) identical.. so ya have 2 larger bearings instead of 1 large & 1 small..
Much, much stronger IMO, and I wouldn't consider anything less on any trailer intended for off-road..
Confucius say.....
AnswerID: 377719
Follow Up By: seqfisho - Thursday, Aug 06, 2009 at 14:35
Actually the inner and outer bearing are slightly different on the inside diameter as the outer bearing shaft is slightly smaller than the inner (so slightly miss named)
I know this as I just purchased a spare set for the camper as cheap insurance for any future bearing problems, as they always say if you have a spare you will never need to use it and hopefully that theory holds out for a long time to come.
I think the naming comes from the fact that both inner and outer bearings have the same outside diameter.
Cheers Glen
FollowupID: 645190
Follow Up By: Member - Ed. C. (QLD) - Thursday, Aug 06, 2009 at 15:59
G'day Glen,
Yeah, I guess that's why I slipped the word "usually" in there... There's always an exception .. (Then again, mine might be the exception;-))
What I described is accurate in relation to my trailer, which has the axle shafts machined to 1 3/8" (yes, parallel;-)) to take the Ford 68149 bearings all round (inner & outer)..
The trailer that this (current) one replaced was similar in that the shafts were again machined parallel, only on that one they were machined to 1 1/4" to take the 67048 Holden inners..
As you point out, the OD of the outer race (cup) for both these bearings is the same (2 5/16")...
I wonder how many more different configurations there are out there?
It would seem that there are a few axle makers who have to be 'different' just for the sake of it;-)
Confucius say.....
FollowupID: 645197
Follow Up By: Member - Oldplodder (QLD) - Thursday, Aug 06, 2009 at 17:51
Like Ed, mine on the CT are the ford bearings, same part number inner and outer.
That outer bearing is a lot bigger than the outer on the box trailer. :o)
FollowupID: 645209
Reply By: Ianw - Thursday, Aug 06, 2009 at 19:24
My van has the parallel bearing setup. All bearings are the same. Tapered bearings with a 35mm internal (axle) and 59mm outer measurement. 6 stud landcruiser pattern. Just renewed the lot before last trip. (8 bearings.)
Ian
AnswerID: 377835
Follow Up By: Ianw - Thursday, Aug 06, 2009 at 19:29
I Also use the L68149 bearings.
Ian
FollowupID: 645219
Reply By: Nomadic Navara - Thursday, Aug 06, 2009 at 19:53
If you are talking about caravan/trailer axle bearings, it is not a case of whether parallel bearings are better or not. What you should be looking at is whether the axle/hub set up is sufficient to carry your load. The parallel bearing setup is about mid range in carrying capacity. See this link -or this link
AnswerID: 377840
