heater for roof top tent
Submitted: Sunday, Aug 16, 2009 at 18:12
ThreadID: 71549 Views:9562 Replies:9 FollowUps:2
hi gang,
i have been looking at getting a 12v bed heater for my ARB roof top tent.
after some research, i have found that Kimberley kampers have what is called a di-electric membrane heater. it is placed under the mattress, heats the bed up and reduces condensation as well. perfect!!
the only problem is that they (Kimberley Kampers) only sell their accessories to Kimberley kamper owners, they even ask for the campers chassis number or VIN number....
my question is, is there any thing else out on the market similar to this
Kimberley Kamper heater ?
Reply By: Tenpounder (SA) - Sunday, Aug 16, 2009 at 18:40
Interesting question!
At 1.2 amp at 12.5 volts per person (their words) that's 15 watts per person. Two observations: that's less than one brake light globe (21 watt) per person - how much warmth would that create? But twice that may have an impact overnight on battery capacity unless you have plenty of battery capacity (ie, on top of fridge etc.)
But why would you bother anyway? I cannot see how it would have much impact on condensation, with such a low energy output, so maybe a hot water bottle would be a better answer.
AnswerID: 379212
Follow Up By: viz - Sunday, Aug 16, 2009 at 19:15
The Kimberley Kamper electric blanket has an option that includes a separate battery (gel?) and solar panel. Quite nifty,as long as there is sunlight available...
viz
FollowupID: 646595
Reply By: vk1dx - Sunday, Aug 16, 2009 at 19:09
Why not just cuddle up!!! A lot cheaper and heaps more fun.
AnswerID: 379214
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Aug 18, 2009 at 09:36
Phil, a common sense approach.. I agree.. ;) Michael
FollowupID: 646791
Reply By: Dunedigger - Sunday, Aug 16, 2009 at 21:20
This what you are looking for . . . link below . .
Features 12-volt Electric Blanket
With two heating stages
Integrated temperature guard
Strain-relieved connection cable
Heating elements of extremely flexible, coated wire
Suitable for mobile use
Two heating stages:
Stage I = pleasant permanent heat
Stage II = heat-up
Material:
Easy-care micro velour fleece, 100% polyester
Operating voltage 12 volts from cigarette lighter socket
Capacity
Stage I: 20 watts
Stage II: 45 watts
Dimensions (L x W) 1550 mm x 1050 mm
Test mark e-approved to 95/54/EC (EMC guidelines for vehicles)
MagicComfort MH25B Universal Electric Blanket
AnswerID: 379251
Reply By: Haza - Sunday, Aug 16, 2009 at 21:40
I just use my full length thermos and seem to find my neighbouring campers are gone before I get up in the morning.
AnswerID: 379255
Reply By: dieseltojo - Sunday, Aug 16, 2009 at 21:42
Hi Greg T,
i
In cold areas I use a single elec blanket from a rear socket ,through a 300 watt inverta.Turn it of once in bed.Never had a problem yet and nice and warm.I believe that there are now 12 volt blankets available. Some may knock it but it works for me.just pay attention to all the wiring and make sure the 12 volt socket has appropriate size wiring.
Regards Paul.
AnswerID: 379256
Reply By: Member - MUZBRY(Vic) - Monday, Aug 17, 2009 at 07:30
Good morning
I have an electric blanket in my left hand , otherwise i could not type if it was in both hands.
12v 1.47 long and 1.1 wide.4 amp draw.
Never used as i have not needed it yet. I may give it a go at the Pyrenees weekend.
Murray
AnswerID: 379284
Reply By: slave - Monday, Aug 17, 2009 at 21:34
a quick familly survey came up with the simple answer -toughen up a bit and get a better quilt
AnswerID: 379388
Reply By: Michael ( Moss Vale NSW) - Tuesday, Aug 18, 2009 at 09:38
We just have 2 hot water bottles in sleeping bags, the heat they produce is excellent.... and safe.. and you can re use the water the following night. Michael
AnswerID: 379422
Reply By: Member - Greg T (ACT) - Wednesday, Aug 19, 2009 at 07:15
Hi all,
thanks for the advice about the blanket and hardening up.
for me, there is nothing like going camping in the middle of winter in the high country with a couple of glugs of warming juice while the fish are on.
however, getting the bride to consider camping in -5 onwards again, an electric blanket is on the cards.
the water bottle doesn't last that long, especially when the bride has raynards (spelling?), so it is quite difficult for her to get warm. even with my manly snuggles.
ill be looking into that electric blanket a bit more, and see if i can get away with it on the spare battery.
AnswerID: 379544
