roof top tinnie
Submitted: Sunday, Aug 16, 2009 at 21:51
ThreadID: 71560 Views:10402 Replies:7 FollowUps:7
Hi all, I am in the market for a roof top tinny and as i am a chicken sh#$, I want the biggest and highest sided tinny I can get.
I have no problems getting it on or off the roof as I use an electric winch for on and off.
Roof weight is max of 200kg I think (GU patrol).
I have been using a 11.6 ft low sided one till now but as I am going to buy one I feel I need something bigger. I have been looking at a 4.1m dolphin but the guy said its to big for the roof.
Any comments welcome good and bad.
cheers Shane.
Reply By: Member - lyndon K (SA) - Sunday, Aug 16, 2009 at 22:06
Hi Shane
We use a 3.75 Topper Tracker from Mako Craft, formerly Stessl.
We find it a good compromise. Do you want a boat for the river or sea?
Cheers Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
AnswerID: 379261
Follow Up By: Member - shane (SA) - Sunday, Aug 16, 2009 at 22:17
Looking for both but mainly sea, and i dont go out that far. I like to see the bottom.
shane.
FollowupID: 646621
Follow Up By: Member - lyndon K (SA) - Sunday, Aug 16, 2009 at 22:26
Ours is mainly for river but is OK when sea is flat.
FollowupID: 646625
Follow Up By: Member - shane (SA) - Sunday, Aug 16, 2009 at 22:28
Just had a look at the Mako, would like higher sides.
shane.
FollowupID: 646626
Reply By: Member - Mike W (NSW) - Sunday, Aug 16, 2009 at 22:07
Hi Shane,
Blue fin make a solid high sided tinny, I've got a Horizon and its ok too
I'm not sure if this is factual but I was told by a rhino roof loaders rep that most roofs can take 80kgs, So any tinny less then that should be ok
Cheers Mike
AnswerID: 379262
Follow Up By: Member - lyndon K (SA) - Sunday, Aug 16, 2009 at 22:24
Weight, boat + roof rack + anything you may want to store in the boat while it's upside down. We carry our fuel tank(empty), life jakets, rope,rabbit ears,oars(plastic), hose for washing motor, you may also want to carry your crab and yabby pots etc. I'm guessing with a Patrol that roof rack max load would be the same as my Troopy, 200kg, But find out.
Welcome to driving a WINDSOCK! :)
FollowupID: 646623
Follow Up By: Member - shane (SA) - Sunday, Aug 16, 2009 at 22:25
Just checked the roof weights again, yes 200kg so most small tinnies will be ok.
shane.
FollowupID: 646624
Follow Up By: Member - John M (NSW) - Monday, Aug 17, 2009 at 07:37
Shane
If you look at my profile you will see the underwater shape of a 3.75m Topper Tracker.
We find this an excellent boat, very stable and dry and use it with a 15hp Yamaha.
Life isn't about how to survive the storm, but how to dance in the rain!
FollowupID: 646638
Follow Up By: youngharry52 - Monday, Aug 17, 2009 at 10:49
Gday Shane.
We looked at the Mako Topper Tracker, but decided on their 3.75 HD Dinghy. A lot more boat than the Topper Tracker but still has the "side sponsons" at the back for better stability.
Chris
FollowupID: 646663
Reply By: age - Monday, Aug 17, 2009 at 12:46
Shane
Have a look at the SeaJay Angler series - 3.75m = 86Kg
Very high sided boat - I flog mine and all is good. Might be a bit light duty construction to bounce around on a roof rack in severe off road conditions though.
For heavy duty look at the Magnum series - 4.0m = 141 kg - bit heavy to load on and off a rack though. Very deep hull and tough constructed
Have a look at some posts by NormC - he did a huge amount of investigation into this and his final set up was awesome.
A
AnswerID: 379316
Reply By: Tessysdad - Monday, Aug 17, 2009 at 16:43
Hello Shane,
You can't go past a Quintrex 3.75 Dart. Good depth for a tinnie, great hull shape for both comfort and safety and weighs about 80kg. It does well in reasonably heavy sea conditions (winds up to say 15knotts in Shark Bay). We carried ours on top of a GU patrol in various road conditions including GRR and the track into Bungles. We have the long shaft transom which is good when you hit the beach but is less convenient when packing the outboard into the truck. had it teamed up with a Honda 15hp, which was good but a little heavy for someone getting a little physically challenged with older age. We now have a 9.8hp Tohatsu which is great.
Hope these notes help.
Mike and Jan.
AnswerID: 379347
Reply By: gbc - Monday, Aug 17, 2009 at 19:31
Being an ex pro fisho I'd seriously question your reasons for wanting a higher sided tinny. In inclement weather ALL tinny's ship water. The higher sided ones just have a heap more windage and get blown about a lot more - oh and they hold more water too when a wave 'drops in', thus requiring more bouyancy (which they don't have over a low sided boat).
Have a look at boats like the oceancraft spear fishing range - on the web. 3.6m lightweight vessel that is self bailing and has sponsons. More seaworthy than most vessels three times its size. Worth a little bit more than a pressed tinny, but you're not going to die in it.
P.S. Never confuse relative comfort with seaworthiness. :)
Good luck, fair weather and good fishing.
AnswerID: 379371
Reply By: Member - shane (SA) - Monday, Aug 17, 2009 at 21:05
thanks for all the replies, will take it on board.
Shane.
AnswerID: 379386
Reply By: Member - Norm C (QLD) - Wednesday, Aug 19, 2009 at 11:47
Shane,
We carry a Sea Jay 3.95 Angler, a large rooftopper, but very comfortable and with it's deep V, performs very well in 'rough' water. We upgraded from a Quintrex 3.75 Dart for extra size, depth and stability. Mine weights 115KG as it has a 2mm bottom.
Another boat worth looking at is the Blue Fin 3.8 m. Not quite as deep as mine, but very good all the same. Nice and wide, very stable and lighter than mine.
The Quintrex Dart 3.95 is also a good option, but not as wide as mine or the Blue Fin 3.8, but light for it's size.
I don't think you need to go bigger than a 3.95 for a roof topper. It is all a compromise - length, depth, width, weight, strength, motor capacity, etc. The bigger the boat, the bigger the motor needed to power it. We carry a 30 HP 4 stroke (73 KG), but for most people, that is way too heavy.
I drew up a spreadsheet of all the specs for the boats I was interested in. Narrowed it down to 2 or three, then looked closely at the build, how I would carry, etc for them. Made the decision much easier.
For a roof topper, get one made with a flat foredeck. Much easier for loading and a good place to stand when throwing the cast net from the boat. For bigger boats, you will need a good boat loader with winch.
Good luck,
Norm C
AnswerID: 379562
