12 volt pump
Submitted: Friday, Aug 21, 2009 at 07:45
ThreadID: 71665 Views:4244 Replies:7 FollowUps:6
Can anyone recomend a 12 volt water pump that would be suitable for pumping water from a creek. It would need to have lift capability.
Reply By: GoneTroppo Member (FNQ) - Friday, Aug 21, 2009 at 07:52
Have a look at the shurflo range depending onhow much capacity you need it may do the trick.
these people seem to have lot of infopumps
AnswerID: 379793
Follow Up By: Member Boroma 604 - Friday, Aug 21, 2009 at 08:39
Gooday,
have a look at Whale Marine pumps, 12 volt they have a good range.
I picked up a 240V submersible like a lift well pump all S/S casing etc from Aldi about 9 months ago for $100 & will use it off our Generator.
Just another optionv
Jheers,
Boroma 604
FollowupID: 647177
Reply By: Ray - Friday, Aug 21, 2009 at 09:08
BCF have a range of sump pumps. They are submersable and run off 12v DC
AnswerID: 379806
Reply By: Member - Porl - Friday, Aug 21, 2009 at 09:49
If money is not an option then I think you need a bore pump, eg
Sun Pump Submersible Bore Pump
http://www.sundriven.com.au/pumps.htm
no affiliation. But shop around, there are a few types of varying quality and lift levels.
AnswerID: 379816
Follow Up By: Member - Porl - Friday, Aug 21, 2009 at 11:16
The reason I recommend the above pump is they can take dirt and grit, other simple water pumps are not designed to have sucked in twigs, leaves, other debri found in creek systems.
Though of course, you may not need such a pump depending on the quality of the water you know you will be accessing.
FollowupID: 647195
Reply By: DIO - Friday, Aug 21, 2009 at 10:20
Simple - go to your local marine supply shop and get a 12 volt bilge pump. They come in varyiing pumping capacities per hour. Not expensive and very efficient.
AnswerID: 379825
Reply By: Moose - Friday, Aug 21, 2009 at 13:15
Don't forget some sort of suitable filter on the inlet and a way to keep it out of the crap at the bottom of the creek otherwise it will probably cark it fairly quickly.
AnswerID: 379860
Reply By: Member - Clay S (NSW) - Friday, Aug 21, 2009 at 13:38
To stop it gunging up buy a meter of nylon flyscreen at bunnings for a few bucks then tie it as a big bag around the whole pump. You will need to be gentle with it so you dont make holes in it but by having a larger area there in less flow per cm sq and less "gunge suck".
By the way - love the photo of the J.
AnswerID: 379866
Follow Up By: GoneTroppo Member (FNQ) - Friday, Aug 21, 2009 at 14:11
I love that expression "gunge suck" !!!!
tells it exactly like it is without being techo
FollowupID: 647212
Reply By: Boobook2 - Friday, Aug 21, 2009 at 18:20
GeeTee
I have this set up. It consists of a flowjet pump like this one.
http://www.caravansplus.com.au/catalog/product_info.php?products_id=6490
It is connected to a normal garden hose about 5 m long with a filter on the end, a 7AH battery and a 18m length of wind up hose like this.
http://www.caravansplus.com.au/catalog/product_info.php?products_id=1416&osCsid=01dc458d94c45e2bfe4a80c0b9dedda3
And a normal garden spray trigger handle jet.
The flowjet has a pressure switch built in.
If the river is clear and flowing I just throw the hose in it and put the pump and battery on the river bank. Then run the wind up hose to the camp site.
I just press the trigger when I want water and it flows at about 12 l per minute. ( 2 1/2 buckets per min.). It self primes and lifts the water 2 - 3 m to the pump and a further 4 - 5 m to the end of the hose.
The water jet will go about 10m in the air. It is like low pressure water mains.
the 7AH battery will last about 2 - 3 days.
AnswerID: 379900
Follow Up By: bruce - Friday, Aug 21, 2009 at 19:32
If you put a 400mh Projecta solar panel on that 7ah battery you will probably never run out of power....we do not....cheers
FollowupID: 647253
Follow Up By: Boobook2 - Saturday, Aug 22, 2009 at 06:22
Thanks Bruse, that is the plan.
FollowupID: 647304
Follow Up By: Member - GeeTee (NT) - Saturday, Aug 22, 2009 at 15:29
Sounds like the way to go. Thanks to all who responded.
I have a flowjet in the vehicle for the hot water shower. Maybe I could incorporate that in a delivery system.
FollowupID: 647342
