jacking 82 15ft viscount
Submitted: Thursday, Aug 27, 2009 at 10:50
kman1
Has anyone had any experience in changing a wheel on an 82 Viscount.Seems to me if you place jack under axle or spring shackle plate you will only jack wheel up into wheel arch and won't be able to get wheel off.Does'nt appear to have jacking points anywhere else.I have just bought van and am yet to buy jack.Any help would be appreciated.
kman1
Reply By: Tenpounder (SA) - Thursday, Aug 27, 2009 at 10:58
Hi/ I have an old '89 Coromal 17'6" van with no jacking points, and I simply use the chassis immediately behind the axle (independent
suspension on the Coromal). I am really sold on using a trolley jack for this, on the grounds of stability, and they are quite cheap these days. I use a heavy ply plate under the jack.
Does this help?
380681
Follow Up By: disco driver - Thursday, Aug 27, 2009 at 23:01
I'll second that.
Use a trolley jack on a 19mm ply base.
A 1500kg trolley jack from any of the Auto parts and accessory
places (Super cheap, Auto One, Repco or even from the 2 big
supermarket chains) will be plenty big enough to handle the van, considering that your all up weight will be in the order of 1600kg max, and you will only be lifting half of that weight at a time.
Sufficient margin for safety IMHO. (But I would also wind down the rear stabiliser leg on that side as a safety measure, JUST IN CASE.)
Disco.
648188
Reply By: Geoff (Newcastle, NSW) - Thursday, Aug 27, 2009 at 11:02
In those old viscounts you need two jacks.
One under the axle to lift the tyre off the ground and another under the chassis to lift the caravan away from the axle.
If you only jack under the axle it just drives the tyre up into the wheel arch and you can't get the wheel out.
Just pick the strongest looking point on the chassis somewhere behind the axle.
Geoff
| Geoff,
380682
Follow Up By: Member - Teege (NSW) - Thursday, Aug 27, 2009 at 18:14
yep
teege
648127
Reply By: vk1dx - Thursday, Aug 27, 2009 at 11:09
I don't know if this will help. We haven't towed for quite some years.
On one occasion I had to do the following;
I took the towbar off the car but left the chain attached. I then let it go as far down as possible on the trolley jack. Then I wind one side (the side with the flat) stabiliser leg down as far as I could. Then wound the trolley jack up again as far as possible. This moved the body far enough away from the tyre so that when I jacked the wheel up iI could get it off. Only needed to do it once thank heavens.
Luckily it was only the one time I had to do this.
Maybe you should conside a getting high lift jack and get some lift points installed on the van. Also extremely helpful for the car. Very helpful part of a recovery kit in any event. I have one now.
Just an idea.
380685
Reply By: Ted G - Thursday, Aug 27, 2009 at 11:39
Hi Kman
On some caravans you need to jack up the axle and instead of trying to move the tyre out from the top try moving it under the axle at the bottom this works on a lot of vans.
Two jacks one under the chassis and second under the axle will work but be carefull to put timber under the chassis jack.
Ted
380691
Reply By: Dave B ( BHQ NSW) - Thursday, Aug 27, 2009 at 11:53
Most people carry various blocks of wood to level up the van/trailer when
camping.
When you need to change a tyre, run the flat tyre up on a couple of blocks of wood to get extra height under the van. You will have lost a few inches, (sorry, I am an old bugger, I should say centimetres) with the flat tyre.
By the time you have pulled up with a flat or buggered tyre, another couple of feet running up on blocks won't matter.
That way, you have more height to play with and you don't even need a special jack.
Works for me.
Dave
380692
Reply By: phil300 - Thursday, Aug 27, 2009 at 12:43
Just put a block of wood between the axle and chassis first.
380695
Reply By: Member -Dodger - Thursday, Aug 27, 2009 at 16:29
If you purchase a Trail a mate jack they come with mounts that can be welded to the chasis. These are a great jack as I use
mine as a jockey wheel as
well and also a high lift jack for the Nissan
Image Could Not Be Found
Or Look Here
Jack
380719
Reply By: disco driver - Thursday, Aug 27, 2009 at 17:31
Where does everyone get the idea that jacking on the axle lifts the wheel into the wheel arch.
It doesn't
Consider this, when the weight of the van is on the wheel, attached to the axle, and supported by the spring onto the chassis
the arch clearance is whatever it is.
Jacking the axle does not alter the load on the spring/axle combination and no spring deformation occurs as a result of jacking..(There is NO load change)
Depending on the tyre and rim size on your Viscount, it is possible to remove the wheel by pulling the bottom of the tyre/rim assembly toward you and sliding the top of the tyre down over the brake drum. Replacement is a reversal of the same operation.
My '82 Viscount 16" poptop has 195x14 LT tyres fitted (185x14LT are standard, according to my owners handbook) and I have no trouble changing tyres just by jacking up on the axle.
Hope this helps.
Disco.
380721
Follow Up By: kman1 - Friday, Aug 28, 2009 at 12:53
Disco, Makes a lot of technical sense,will give it a try at home,before I go anywhere.
Thanks a lot
648256
Reply By: phil300 - Thursday, Aug 27, 2009 at 19:55
I was thinking tandem load sharing,one wheel up other goes down.
380743
Follow Up By: disco driver - Thursday, Aug 27, 2009 at 22:50
Hi Phil,
You are correct when referring to a tandem axle van, but an '82 Viscount 15ft is definitely not a tandem axle rig so jacking on the axle will not alter wheel arch clearances.
Disco.
648183
Reply By: kman1 - Friday, Aug 28, 2009 at 12:56
Thanks a lot to all for your responses they have been a great help.
Katcha kman1
380828
