Big tyres
Submitted: Saturday, Sep 13, 2003 at 15:26
daviiiMQ
Hi All,
I know most of the posatives of getting larger tyres but what are the negatives of having them when driving on road. I currently have 31 by 10.5 on 15's and am thinking about getting 35' in the near future.
thanx
dave
Reply By: Truckster (Vic) - Saturday, Sep 13, 2003 at 16:14
Your speedo is out by lots
your gearing is shot you will be doing 100kph at around 1rpm
Its illegal in most states, or you need to get your car reengineered at a cost of $$$100's.
Cost of tires
You need different flairs to be legal
you need a lift kit to clear them or hit your guards with angle grinder.
theres a few..
30952
Follow Up By: Member - Bonz (Vic) - Saturday, Sep 13, 2003 at 16:21
Yep it'll be gutless unless you stick some different gearing in, So many
places to go!
So much work to do :0(
21941
Follow Up By: Willie - Saturday, Sep 13, 2003 at 21:27
And your turning circle will be worse than that of a Landrover
Never a dull moment
21959
Follow Up By: Kev - (Cairns,QLD) - Sunday, Sep 14, 2003 at 17:51
Bonz,
Obviously depends what vehical it is !
4.2L T/diesel = no problems !
21980
Follow Up By: Truckster (Vic) - Sunday, Sep 14, 2003 at 17:52
Even with the Turbo
mine suffers, and its auto so, should suffer less :(
I only went from 31->33's
21981
Follow Up By: Member - Bonz (Vic) - Sunday, Sep 14, 2003 at 20:22
yes Kev, Maybe gutless is a poor choice of words but even going from 215/75-16's to 235/85-16's on a petrol Maverick was very noticeable.So many
places to go!
22004
Reply By: Member - Peter - Saturday, Sep 13, 2003 at 17:12
Dave,
Spot on re speedo being out. You will find a reduction in power, probably ending up using more
fuel in the long run, to get the beast rolling. Your top gear may not be the right ratio to let the engine give you best performance.
The cost of having the speedometer recalibrated...
The fines from the Highway Patrol should they report you for the vehicle not complying with the standards....goes on and on.
Re-registration? Try to run your vehicle over the RTA pits and see the attention given by the inspectors......on and on and on.....
Must admit though, the 35's may look good but I'd hate to experience the change of the centre of gravity......an interesting thought.
Finally, out in the bush away from it all and experiencing a staked tyre. There goes the spare. Another flat and try to buy a 35" tyre 'outback'. Don't like your chances in getting one.
Good luck,
Haldo
30956
Follow Up By: Troopyboy-vk3hsc - Thursday, Sep 18, 2003 at 16:15
I had problems getting 32/11.5/15 for my Troopy in SA, so i dont like ya chances of 35's, and all those other problems.. bah humbug to monster tyres... takes the skill out of it anyway!!!! :)
22346
Reply By: tastroopy - Saturday, Sep 13, 2003 at 20:18
Hi Dave,
I guess it all depends on what you are trying to achieve. I have a troop carrier and went from 31s to 35 in one hit.
Negatives where:
Speedo went out.....but callibrated with gps so know 52 is 60 etc
Bump Stops and Guard Clearance...had to fit flares and create new bump stops
to stop the tyres hitting the top of guard
Increased Bump Steer.....replaced steering dampener with heavier unit
Heavier Steering.......had to fit wedges behind axle to help the power steer
replace tyres...have had one unrepairable stake..cost to replace one $350
Positives are:
Better clearance and approach and departure angles
Much better traction...larger tyres improve tread depth
Better overall ride...dont have larger tyres inflated as hard
Looks.....might be vain but eh i love it
Overall better footprint in off road situation
It may be true that you will suffer in the power stakes, but for me i turned up the boost on the turbo from 7 psi to 10 psi and it has made neglegable difference. Having said that you do notice that your low range is not quite as low....but it then comes down to what sort of low range you had to start with...the troopy was great to start with...and with the twin lockers its damn near unstoppable!!!
IN the end i think it comes down to needs vs wants and driving the cheapest thing your ego will let you get away with..............oh hell that sounds like something my wife would say!!!!!!!!
tastroopy
30967
Reply By: Eric - Saturday, Sep 13, 2003 at 21:41
DaviiiMQ.
There are far more negatives than positives running oversize tyres.
Despite the popular belief you don't get more traction.
Brake balance is seriously affected that is why engineering the vehicle is so exspensive, the brake balance has to be changed and tested.
Stability at speed and on side slopes is dangerously reduced.
The increase in unsprung mass makes the ride much rougher.
Stress on brakes, wheel studs and bearings leads to higher miantenance costs.
getting in and out of the vehicle is very dificult for females and loadimg and unlaoding gear is harder.
The resale value of the vehicle is reduced. and insurance is a problem. Eric.
30974
Reply By: Member - DOZER- Saturday, Sep 13, 2003 at 22:16
Eric
some info for you to think about.
My part time 80 runs 31 10r 15 tyres and if i try to reverse up my concrete drive, it spins rear tyres.
Now if i put 35's on it doesnt spin, and i can even reverse up there in the wet. What a difference to traction they make. The contact patch on the concrete is a little wider, but heaps longer than the 10r because there is 4 inches of diameter bigger and smaller amount of pressure in them to keep the sidewalls up.
Now theres a negitive.... sidewalls.... large sidewalls and sticks dont mix.
Andrewwheredayathinkwer mike?
30976
Reply By: Kev - (Cairns,QLD) - Sunday, Sep 14, 2003 at 17:46
Geez, you guys found a lot of negitive things.
But i want to know how many of you actually owned or driven a 4wd with 35" tyres ?
The only negitive things i would mention is the speedo being out. (no big deal)
Slightly different gearing. If they are on a capable vehical engine wise there is no problem.
Insurance.
35's is the best mod iv done so far & never looked back !
31001
Follow Up By: Truckster (Vic) - Sunday, Sep 14, 2003 at 17:55
I have once, the big advantage is clearance in ruts, I borrowed some BFG MT's in 35's for a day trip, and
yea the size made a difference.
They are a good mod depending on what you want to do with the car.
21982
Follow Up By: Kev - (Cairns,QLD) - Sunday, Sep 14, 2003 at 18:11
Yeah true, if your rig is mainly for traveling (as probebly most here) theres no real point having large tyres.
21983
