Cleaning plastic water tanks with bicarb
Submitted: Wednesday, Sep 23, 2009 at 12:07
ThreadID: 72477 Views:13426 Replies:5 FollowUps:1
Does anyone know the ratio of bicarb to water for cleaning plastic water tanks?
I have some plastic jerry cans I want to clean and wonder how much bicarb to use.
Cheers.
Reply By: Steve Ellis - Wednesday, Sep 23, 2009 at 12:57
GDay. About a tablespoon full and fill the jerry. Leave overnight. Rinse well. Done
AnswerID: 384304
Reply By: Member - Ed. C. (QLD) - Wednesday, Sep 23, 2009 at 14:17
If the jerries have any algae or staining in them, the most effective way I've found to get rid of that, is to pour a couple of generous handfulls of coarse sand (or fine road base, or similar) in there, add a couple of litres of water, put the lid on, and shake the cr@p out it (literally).. It'll come up 'squeaky clean' ..
You can then do the bi-carb thing if you wish (not essential, IMO)..
If you have any lemons handy, I'd suggest adding the juice of a lemon to the final rinse, to give it that 'fresh smell'...
Confucius say.....
AnswerID: 384318
Reply By: Member - Michael P (QLD) - Wednesday, Sep 23, 2009 at 15:52
Hi Ben,
I clean/sterilise the water tanks (poly) on my caravan once a year with sodium metabysulphite. Available from Home Brew shops or home brew sect of larger supermarkets.
Mike
AnswerID: 384328
Reply By: Roughasguts - Wednesday, Sep 23, 2009 at 17:40
Might be easier to use Milton for the tanks.
It's used for sterilizing baby bottles so must be safe to drink out of later, anyway it's basically Bleach and the ratio's are on the bottle.
AnswerID: 384346
Reply By: disco driver - Wednesday, Sep 23, 2009 at 17:46
The best way to clean plastic jerrycans is a handful of sharp pebbles or granite chips.
Add a couple of litres of water and as previously replied, shake vigorously tll all the crap is loose.
Flush a couple of times with water, then add a couple of litres of water and the recommended amount of "Milton" (the stuff used to sterilize baby bottles) and shake around.
Flush once more and it will be guaranteed clean and safe.
Disco.
AnswerID: 384347
Follow Up By: DIO - Thursday, Sep 24, 2009 at 09:24
The BEST way to clean the inside of jerry cans is with a Karcher (or similar) - brings them up like new.
FollowupID: 652184
