Digital Cameras/video cameras/mobile phones
Submitted: Tuesday, Sep 29, 2009 at 21:50
ThreadID: 72634 Views:2891 Replies:9 FollowUps:5
Just had a sunny week at Fraser and rekindled my old pharft problems of trying to take photos/videos etc in the bright sunlight. I just cant see whats on the display screen no matter how I hold it, so I point it in general direction push the button etc and hope. Tried pulling cap down close/holding hand over screen(shake increases) Is there anyway around this or it is just the way nature intended.
Reply By: Member - Mick O (VIC) - Tuesday, Sep 29, 2009 at 21:54
Unfortunately, no way to avoid it. Viewfinder is the only way in those conditions.
Cheers Mick
AnswerID: 385127
Reply By: Rangiephil - Tuesday, Sep 29, 2009 at 21:55
My PanasonicTZ2 has a setting in "settings" that brightens up the screen to allow for this and also one that changes the angle of the screen so you can hold the camera over your head.
I do not use it much as it chews the battery.
Maybe explore the manual and the settings on the cameras.
Regards Philip A
AnswerID: 385129
Follow Up By: River Swaggie - Tuesday, Sep 29, 2009 at 22:56
Yeah thought the same thing would be good if he could supply camera info !
FollowupID: 652857
Reply By: Member - Allan B (QLD) - Tuesday, Sep 29, 2009 at 22:22
You could try this ..............
Image Could Not Be Found
AnswerID: 385132
Follow Up By: River Swaggie - Tuesday, Sep 29, 2009 at 22:27
Only problem is with the big flash and bang it can cause Incontinence and then he'll be in all sorts of strife !
FollowupID: 652852
Follow Up By: Member - Timbo - Wednesday, Sep 30, 2009 at 13:42
Ha ha, good one Allan.
River Swaggie, you'll be okay as shouldn't usually need the flash in bright sunlight...
FollowupID: 652889
Follow Up By: HGMonaro - Wednesday, Sep 30, 2009 at 14:39
hey go easy! I still use a camera like that!
FollowupID: 652893
Reply By: obee1212 - Wednesday, Sep 30, 2009 at 09:39
I always use the viewfinder because held against my head reduces camera shake to nothing and it saves the battery.
Owen
AnswerID: 385165
Reply By: timglobal - Wednesday, Sep 30, 2009 at 09:41
Mav - What make and model?
Interim tip - don't wear polarised sunnies when viewing the screen.
AnswerID: 385166
Reply By: DIO - Wednesday, Sep 30, 2009 at 10:15
Why not get a camera with a view finder. Easy peesy.
AnswerID: 385169
Reply By: Member - Flynnie (NSW) - Wednesday, Sep 30, 2009 at 22:26
Unfortunately the advice of getting a camera with a viewfinder though correct is getting harder to do. The number of cameras with viewfinders is steadily dropping, particularly in compact cameras. All SLR type cameras have them.
Some compact cameras still have a viewfinder. Canon makes a few of them (G11 and others) and there are some amongst other brands as well.
In the bright Australian sun the display screen is pretty useless. I never use mine but use the viewfinder instead.
AnswerID: 385266
Reply By: Bob of KAOS - Wednesday, Sep 30, 2009 at 23:51
SLRs with optical view finders have come down in price to where point and shoots were two years ago.
Nikon D60 $700 at the Good Guys! There are cheaper units too.
Interesting comment about using the head to reduce camera shake- are you sure it isn't just a perceived reduction? ie the head and camera shake in sync.
AnswerID: 385274
Follow Up By: HGMonaro - Thursday, Oct 01, 2009 at 10:58
no way you can hold a camera at arms length as steady as having it jammed against your head.
Another thing an optical viewfinder is good for is when you're trying to follow an object (pan). Hard to do using a LCD unless you're 'zoomed out' miles.
FollowupID: 653001
Reply By: Mav1 - Thursday, Oct 01, 2009 at 11:07
Thanks for advice people. Is an old Canon S2is - with a viewfinder. So used to using big display indoors etc didn't really think to use vf. Need to keep glasses on to use thru this but is fine. Can sort of hold against glasses/head for steady.
Video camera as such I suppose no way out, just point and panning anyway.
AnswerID: 385303
