Yamaha EF2000i v's Honda EU20i Genies
Submitted: Wednesday, Oct 07, 2009 at 12:10
DEANO WA
Hi all, here we go again. I have looked back on archived threads on this subject, most being compared between yamy 2.4 and honda 2.0. with the newer yamy 2.0 just wanted to get the lowdown before i shell out the $2k for either. thinking more towards Honda ??. Any comments on the subject would be great :)
Cheers Deano
Reply By: Member - Fred B (NT) - Wednesday, Oct 07, 2009 at 12:53
Our honda preforms
well without dramas and very quiet. Excellent value for money.
regards
386115
Reply By: River Swaggie - Wednesday, Oct 07, 2009 at 13:13
I am slowly converting everything over to Honda and guess what,no more issues.Although ive only used the 20ui for about an hour over 2 years.
Just waiting for the whipper snipper to go but MTD seems to hav done a good job so far lol..
Goodluck Go Honda..
Oh if you hav it sitting around regularly change the fuel over for fresh stuff..
386119
Reply By: Member - Alan John C (WA) - Wednesday, Oct 07, 2009 at 13:29
Deano,
I been running a Honda for about 5 years use it for running the tank pump when power goes off in WA as
well as
camping my van the lot done around 500hrs and am about to buy a second one to run in parrallel to give 4kva this takes load off when running air con regards Alan.
386123
Reply By: robertbruce - Wednesday, Oct 07, 2009 at 13:49
Heya D,
im a long-term, high usage yamaha owner, i have a mate the same but with a honda....
he complains about the costs of honda parts and servicing.
I have found the yamaha is built for in-field serviceing, easy maintainence and much cheaper parts...
I havnt needed any parts yet, My yamaha has almost 8000hours on it.... lets see the honda'a alloy
bore do that...
Also consider the new yamaha2.0 is the most advanced and freshest design available, all the other design have been around for almost a decade....
386130
Follow Up By: DEANO WA - Wednesday, Oct 07, 2009 at 14:11
yeh, thats my concern. the yamy is new and like all new models i dont know if there are generic problems with them yet. on paper they look identical but the main issues are the
bore construction material and servicability. are the honda EU20i ali
bore ?? or is it just the EU10i
653682
Reply By: shanegu6 - Wednesday, Oct 07, 2009 at 18:57
Hi there ive had a yamaha 2400 for 4 years. no problems at all. Used for
camping and building sites.
386165
Reply By: Racey - Wednesday, Oct 07, 2009 at 19:34
Go the Yammy, it is 2kva nominal rating 2.4 peak, whereas the Honda is 1.6 kva nominal and 2.0 peak. It is also a little quieter.
Racey
386170
Follow Up By: wafarmer - Wednesday, Oct 07, 2009 at 20:06
Err not quite right.
Yammy 2000 is 2000 peak 1600 cont same as Honda 2ui but both good units
I have 2x yammy 2400's and have had no trouble but am looking to change one for a Yammy 2000 as the 2400 will not fit in the camper slot made for it.
By the way the linking cable and box for these units contain no smart tech just the wires joined together and connected to the power point, the smarts are in the inverter part of the gennys.
wafarmer
653735
Follow Up By: Racey - Thursday, Oct 08, 2009 at 19:51
Sorry,
I was thinking of the 2400 noted in the previous post. For the 2000 you are correct.
Racey
653866
Reply By: veight - Wednesday, Oct 07, 2009 at 22:37
Honda Standard warranty 4 years
Yamaha warranty 2 years
386190
Reply By: Nissan Freak - Thursday, Oct 08, 2009 at 10:23
Its very hard these day with so many products on the market to decide which item to spend your hard earned cash on . There are many pro's and Con's concerning Gennys aka performance , reliability , fuel consumption , weight and Decibels it produces . Personally I have a Honda 2.0 EU and it is flawless , I do alot of
camping in the North of WA and really rely on my little Honda , It starts first pull , uses about 4 litres every 12 hours and is extremely quiet only 52 db which when
camping is quite comforting as the last thing we wanted was a screaming Genny while trying to have a beer round the barby. Do a little research before you buy as it really is horses for courses but if it was my money the Honda wins hands down...Hope this helps :-)
386231
Reply By: DEANO WA - Wednesday, Oct 14, 2009 at 10:44
Thanks everyone, bought the Honda.
Cheers Deano
386988
