Best time to see Cape York
Submitted: Tuesday, Oct 13, 2009 at 22:45
Kanga1
G'day, we are planning a trip up the Cape in 2011 and would like to try and avoid school hols/ long weekends, in a nut shell, when it's not overcrowded, but obviously not in the height of the Wet. Any tips and must see's appreciated. Cheers Kanga1
Reply By: Member - Josh (VIC) - Tuesday, Oct 13, 2009 at 23:08
We left
Cairns on the 1st June this year and spent 4 weeks on the cape. As we headed south the school hols traffic was heading up. On the way up was usually only 5-6 other vehicles in each
camp site, on the way down most were fairly full. Road was in perfect condition going up as
well. There was a bit of
water in the creeks but most were ok. Temp was perfect and the fishing even better. We camped at
punsand bay which is a great spot to
camp near
the tip.
Stop at
the croc tent on your way up as he has everything you need to know/see on the cape'
Josh
386958
Follow Up By: Kanga1 - Wednesday, Oct 14, 2009 at 00:53
Thanks for the tips, Cheers Kanga1
654557
Reply By: Nath'n'Lynz - Wednesday, Oct 14, 2009 at 02:02
Hi there, were headed up there next year too. Planning around late September. If you search "Capeyork" in the threads you will find plenty of advice as i've been doing the same for the past few months.
Also check out this link that one of the nice EO bloggers posted on my thread.
It has so much info and some awesome pics.
Lynz
http://www.ivanlea.net/photos/CapeYork/default.htm
386964
Follow Up By: Kanga1 - Wednesday, Oct 14, 2009 at 11:24
Thanks very much for info, I will check out those threads tonight. Cheers, Kanga1
654579
Reply By: Member - Tonyb (FNQ) - Wednesday, Oct 14, 2009 at 17:01
It will all depend on what happens with the wet that year as to when you will be allowed to drive on the PDR.
Some years it can stay closed for quite a while depending if there is Cyclone damage. Many people ignore the
road closed signs and pretend they are 5ton Local Traffic only :-)
The earlier the better is what I would recommend, still plenty of
water around and the years first grades are usually underway. Side trips like Iron Range can take even longer to open.
Its at its best when it is wet! You will have to monitor the
Cairns Main Roads Web site to get the latest update on that road...or mm me early 2011 and I will pass on the info as I will be trying to get up there as soon as I can for the Barra.
387053
Follow Up By: Kanga1 - Wednesday, Oct 14, 2009 at 21:41
Hi Tonyb, thanks for your reply, I will keep all the info from this thread and may be in touch in the early part of 2011 we are a bit alfresco with which way we will do our trip, go straight through the middle to FNQ and come back across the top, or go up the coast then across the top and come back through the middle, I am leaning quite heavily on the first option at the moment for the reasons you said, thanks again. Kanga1.
654655
