Dragon Tree Soak
Submitted: Wednesday, Oct 14, 2009 at 16:43
Pete Mac
Hi All,
Searching back through the forums, there has been mention of people contemplating tackling this - but as far as I can see no reports of success. Though it does look like Mick O and friends got into Joanna/Griing Springs which is damn close.
Has anyone been there? What is the country like there currently - burnt out or thick?
I see the Connie Sue and Mick (Beadells) have a trip planned for next year so must be doable...
Pete
Reply By: ExplorOz - David & Michelle - Wednesday, Oct 14, 2009 at 16:50
Good question Pete, If anyone has any information please update the place page here -
Dragon Tree Soak Nature Reserve.
387050
Reply By: Member - Mick O (VIC) - Wednesday, Oct 14, 2009 at 17:08
Peter,
It’s a tough run believe me. The conventional wisdom at this point is to attack it from the top (northern) side. There is reputedly a track running to the north from The Anna Plains Track but we could find no trace of it as we passed this year.
I have spoken with one of the last successful groups that I was aware to have “almost” reached the soak area back in 2001. Their route took them past
Joanna Spring and further to the north on old cut lines. From there they proceeded west on a line above Dragon Tree and then tried to access it by heading south. They struck a lot of
water at that time. The country is pretty tough to say the least. Much of it is thickets of acacia and turpentine. There are the occasional swathes of burnt out country but they are largely regrown and present their own difficulties in the form of fire hardened stakes.
Water is at a premium. You also have a lot of BIG dune crossings to contend with. The old cut lines are often so overgrown as to provide easier going off them. Take plenty of tyre repair equipment and a means of accessing
water from old exploration bores.
I am looking at a south-north crossing of the Great Sandy as an option next year and will be doing a bit more research on identifying the best way in. I believe from what I have seen of Mick Hutton’s Plans that he will follow
Warburton’s route as closely as he can. Again I think the best option is to try on the route I’ve mentioned above.
Only in the early planning stages at present so unfortunately spend far too much time working.
Cheers Mick
387054
Follow Up By: Pete Mac - Wednesday, Oct 14, 2009 at 18:18
Great info - thanks Mick. Have read those posts quite a few times :)
Just to clarify your post above, the track mentioned in your first paragraph which heads north off the Anna Plains 'track', is that to the east or west of Dragon Tree soak?
Great Sandy crossing sounds intriguing - where would you go 'off-track' from and where would you return to?
Cheers!
Pete
654622
Follow Up By: Member - Mick O (VIC) - Wednesday, Oct 14, 2009 at 18:47
She's an amazing piece of country Peter. I must get some video into those
blogs. It's the only way you can truly get an idea of how tough the scrub is. Don't expect to come back with any duco.
Have a few possible
routes under consideration dependant largely on
water and permissions. Feel free to drop me an email addy to mickolsen13@hotmail.com if you wish to discuss further.
Cheers Mick
654625
Reply By: Willem - Wednesday, Oct 14, 2009 at 19:50
Pete
I have put quite a bit of research into this one as it remains the most elusive place to get to. I started way back in 2004 with the idea to travel there just for the sake of it and I have been in contact with a variety of desert travellers looking for info from them
This year I underestimated the country and the capability of my travelling set-up and decided to turn back after a short foray into the scrub. I had based my preparation on a trek of 420km cross country through the eastern reaches of the GSD in 2008. A years worth of planning came unstuck due to factors which I shall not divulge here but needless to say a different approach will be taken in the future.
The countryside is unrelenting being thick scrub, mulga, gidgee and other flora, soft sand and huge dunes. Getting the right mix with power to weight ratio to cross the dunes and tyres that will give you a better chance of survival is paramount to a successful attempt on Dragon Tree Soak.
A small number of people have been there and I have been in touch with some of them and have some photos of their adventures. Their entry to the area has been from the north in the past but getting access these days across station properties may be more difficult than before.
Planning is underway for a second attempt in the near future.
387079
Follow Up By: Pete Mac - Wednesday, Oct 14, 2009 at 20:04
Thanks Willem,
Yep - 400+ K's off-track is nothing to be sneezed at that's for sure. You are very correct with regards to getting the right vehicle/tyre combo and I guess there is no one perfect solution....
If it was easy everyone would do it :)
Pete
654636
