Caravan tool boxes
Submitted: Saturday, Oct 17, 2009 at 16:34
snowy7
Hi I am trying to find some info on making a tool box for the back of my caravan to store my annex etc. I can make one up easy enough but I am wondering about the weight ditribution! if by adding about 50 to 60 Kgs on the back do I have to worry about equalizin the weight at the front to keep the towball weigth the same? Can anyone head me in the right direction Please.
Reply By: Tenpounder (SA) - Saturday, Oct 17, 2009 at 16:56
Hi.
I reckon there are 3 issues:
1 Can you add another 60 kg without exceeding the van's ATM or the overall GCM of the rig?
2 What is the effect on the towball load (this will depend on the design of the van (single axle or tandem; where the axles are in relation to the length of the van, etc.?
3 Is the van chassis strong enough to hang a toolbox a metre or so behind the chassis?
Common sense tells me, if you hang 60 kg off the back, then the front just has to lighten up, but then someone said that common sense is what tells us the earth is flat. So there! If its a single axle van then there's really no question (think of a see saw!) but a tandem rig will not be as susceptible
387489
Reply By: snowy7 - Saturday, Oct 17, 2009 at 18:23
Cheers for that; GCM is fine didn't think about the difference of single versus tandem axle(
mine is single) so yes it will be a seesaw. My main problem is the the draw bar is so short and the gas bottle being in the way, engineering a box for the front would be a real pain (hence thought of the rear). I will keep looking
387502
Reply By: paulnsw - Saturday, Oct 17, 2009 at 19:06
could be one of the worst decisions you could make. 60kg today 85kg next week.
without knowing the positioning of your single axle the effect of the 60kg could easily be 300kg at times going over a hump at speed or pot hole
have to ask the question what are you looking to put in the box?
cannot believe amount of gear some van and m/h travelers take. we take as little as possible to be comfortable
387506
Reply By: DIO - Saturday, Oct 17, 2009 at 19:51
You do need to be mindful that it is illegal to hang things off the back of a van. Apparently it increases the overall length plus weight increases may cause you to exceed maximum. Heard that authorities in QLD were against such additions. Can't be exactly sure of other states.
387510
Reply By: Member - Axle - Saturday, Oct 17, 2009 at 19:55
No room under the Bed ..Beds for a sliding draw?,
Pvc pipe across the front for poles etc.
Cheers Axle.
387511
Reply By: Member - Graham H (QLD) - Saturday, Oct 17, 2009 at 20:06
Another thing that obviously a lot dont consider is by adding an the back you alter the dimensions of the van and there is a limit how far behind the axle you can go
Look back a page or so under oversize van and you will see what I mean.
As has been said when hitting a bump the weight can increase by about 7times Is the van capable of withstanding stresses like that.
We carry the annexe in the back of the Croozer.
The poles in a pipe carrier and the rafters are under the bed.
This keeps the weight distribution good and also the LEGAL ATM is not exceeded in either vehicle.
Just for fun weigh your rig you may be in for a shock Most would be I think.
387515
Follow Up By: Member - DAZA (QLD) - Sunday, Oct 18, 2009 at 08:23
G/Day Graham
We do the same, 100mm PVC pipe for the poles, and another for the fishing rods, and the Annex walls under the bed, any thing that is heavy goes in the truck.
655066
Reply By: Darrin - Saturday, Oct 17, 2009 at 20:53
It may be possible to have the draw bar extended by a certified caravan repairer and mount the tool box on the front. I had the draw bar extended on a 1977 millard in 1996 so that the wheel carriers on the troopy could open fully without touching the van.
387522
Reply By: Rolly - Sunday, Oct 18, 2009 at 13:25
Positioning any extra weight at any distance from the axle/s significantly decreases the stability of the 'van, especially in the yaw and sway axis.
This will create lateral dynamic moments on the towing vehicle and hitch which, it has been suggested, may be a contributing factor to increased tyre wear, reduced economy, and component failure.
Most of all, though, it reduces the controllability of the combination under adverse situations such as swerving to avoid an obstacle and/or heavy braking.
387579
Reply By: snowy7 - Sunday, Oct 18, 2009 at 13:54
Hi All,
Thanks for your advice, Might be leaving things as they are. (Have tube for poles and annex usually goes on top bunk as its easy to get too) Might look at a side access under the lounge
seat next has a dent there anyhow....
Thanks you again
Snowy7
387581
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 18, 2009 at 14:34
A better idea
My last van had a lounge across the back so we put a hatch in the r/h side which allowed us to put poles and rafters and the annexe wall all in there. Safer and drier and closer to the axles as
Later put poles in a pipe at the front to even up weight a little bit.
Even later when starting the big trip found van was a bit overweight so put annexe walls into car. Theve been there ever since.
I think its better to have the load in the car rather than the van as a heavy van will push a light car whereas the opposite is safer.
655097
