lpg injection on turbo diesel
Submitted: Monday, Oct 19, 2009 at 23:43
ThreadID: 73154 Views:18927 Replies:16 FollowUps:17
About 4 mths ago I had lpg gas inj fitted to my 2006 4.2 lt 100series landcruiser. I tow a 3.4 tonne fully laden van and have had outstanding economy results ie between 15-16 litres per 100 ks. (Travelling at 90 klms). Whereas I am delighted with the results someone I ran into, who professes to be an expert, told me that the price i am likely to pay for my better fuel consumption and appreciably more torque, would be that the engine would be "stuffed" by 200,000 klms. He made some mention of this gas injection being responsible in the long term for a bent crank shaft. I am understandibly distraught if this is the case. Can anyone out there give me the comfort of knowing that my engine will last in excess of 400,000 klms and not the 200 as this chap has indicated.
Reply By: DCTriton - Tuesday, Oct 20, 2009 at 02:45
Extra power used in anger will eventually cost, extra power doled out with a little common sense should cause you no heartache...
AnswerID: 387832
Reply By: Rockape - Tuesday, Oct 20, 2009 at 06:31
Was talking to a roadtrain driver a couple of months back who said his company had installed it for economy, he complained that they had also derated the engines back under 500hp for reliability.
AnswerID: 387834
Follow Up By: Rockape - Tuesday, Oct 20, 2009 at 08:05
Didn't say it before but Toll tried it on some of their trucks without derating them and had engine failures, they gave it away after that.
FollowupID: 655428
Reply By: racinrob - Tuesday, Oct 20, 2009 at 07:23
I did some research about twelve months ago on the merits of fitting LPG to a 1HZ engine similar to yours. All the mechanically qualified people I spoke to said, "No, don't go there."
The figures quoted by the company installing them are wildly distorted, a 22% increase in torque with a similar decrease in fuel consumption just doesn't wash.
Since then I have read several tales of woe concerning LPG fitted to diesels in "The Wanderer", the monthly mag of the Campervan and Motorhome Club of Aust.
Sorry to be the bearer of news you didn't want to read.
Rob.
AnswerID: 387839
Follow Up By: Member - John M (NSW) - Tuesday, Oct 20, 2009 at 07:43
Rob
Same as you, I did a lot of research for my 4.2 litre turbo aftercooled motor in the Nissan and after talking to many diesel mechanics was warned to not do this.
I agree with a Pyrometer being fitted after the turbo as in the next comment as this is the most accurate way of monitoring your engine performance and not overloading the engine.
We do this in boats with engines up from 500 to 3000 and 4000 horsepower to ensure the engines are not being overloaded and performing to their optimum performance and economy.
Life isn't about how to survive the storm, but how to dance in the rain!
FollowupID: 655424
Reply By: Member - DOZER- Tuesday, Oct 20, 2009 at 07:25
I wouldnt worry about what he said too much.....i would be fitting an exhaust gas temperature gauge (egt) straight after the turbo so u can see whats going on in the motor temperature wise, and drive by it...ie when it reaches 600 deg celcuis, back off or down shift...that will ensure you dont do any damage.
Id like to see someone bend a hdfte crank.
Andrew
AnswerID: 387840
Reply By: stumbly1 - Tuesday, Oct 20, 2009 at 07:40
My old mate Chook had lpg injection fitted to his '01 mitsy Triton TD last year with less than 150,000ks on it.
We could never prove it was the gas injection, and I'm not saying it definetly was, but that motor was stuffed within 20,000ks of having it fitted.
Rings burnt out and started badly bypassing, turbo sh-t itself aswell.
Chook did have a habit (still does!) of using whatever power is available and tows alot ( camper-not that heavy) so it may have nothing to do with the lpg, but it just seemed a bit suss on a low km motor.
Sorry if that doesn't help your concerns, but after that I decided not to go with lpg injection just to be on the safe side.
I'm sure there is plenty of people out there who have had no problems at all - hope a few of them can give you a better peace of mind than I have done.
Cheers, Keith
AnswerID: 387841
Follow Up By: Member - Donks1 (NSW) - Tuesday, Oct 20, 2009 at 09:07
Pajero's are having similar issues
Donks1
FollowupID: 655433
Reply By: Member - Phil G (SA) - Tuesday, Oct 20, 2009 at 08:08
Which motor do you have - the 1Hz or the 1HD-FTE? Responses above are for both.
AnswerID: 387847
Follow Up By: racinrob - Tuesday, Oct 20, 2009 at 08:36
I have a 1HZ with an after market turbo water cooled, goes well, vehicle weighs 3.8 tonne all up.
Rob
FollowupID: 655431
Follow Up By: Member - Phil G (SA) - Tuesday, Oct 20, 2009 at 09:21
Rob,
You're asking a lot from a motor that was never designed to take a turbo. You could do a search on 1Hz and cracked pistons. Combined mass of over 7 ton and a large power increase with turbo and LPG.
Also, the standard temp gauges on the Landcruisers are designed to sit in the same spot between 70 and 95 degrees C. So "the gauge never moves". When the motor gets too hot, the gauge moves late. Thats one reason why the TM2 gauges (that give you a temp measurement and audible alarm) are getting popular.
FollowupID: 655439
Follow Up By: sweetwill - Tuesday, Oct 20, 2009 at 12:03
racinrob
a little off track here but had to ask. your car and trailer all up weighs 7.2 tonne? just a thought do you hold a heavy vehicle license cheers bill.
FollowupID: 655463
Follow Up By: sweetwill - Tuesday, Oct 20, 2009 at 12:05
sorry racinrob ment the above comment for the bull.
FollowupID: 655465
Follow Up By: racinrob - Tuesday, Oct 20, 2009 at 14:51
Phil G, had the turbo fitted 120,000 Ks ago and have had no dramas since. Engine still runs better than ever and I rarely add oil between changes every 5,000 Ks.
I carry a slide on camper and all up weight, long range tank plus 135 litres of water etc puts me at about 3.8 tonne. Fuel consumption varies, about 15 litres 100 K's at 95 kph.
Rob.
FollowupID: 655493
Follow Up By: Member - Phil G (SA) - Tuesday, Oct 20, 2009 at 22:40
Rob, you're confusing us, we thought you were the original poster!
FollowupID: 655571
Reply By: Rossco 09 - Tuesday, Oct 20, 2009 at 08:49
Don't engines have to be rated for LPG? A mechanic told me once that one problem with LPG is it doesn't have any lube qualities. I was thinking that diesel displaced in the engine by LPG will result in less lubrication in the cylinders, valves etc.
So the next question is, will diesel fuel additives counteract this? We all know the off the shelf ones, as well as those who run things like 2-stroke or vegie oil. Will this give the engine what it needs to keep the wear and tear at a point where you get an 'expected' lifespan from the engine?
AnswerID: 387850
Follow Up By: Member - mazcan - Tuesday, Oct 20, 2009 at 11:58
hi
a guy that was living close by had an au falcon fitted with gas and i dont know what brand of system it was
but he had a flashlube unit fitted as well which injects a manually selected amount of engine oil per 100km from its own reservior the oil is metered by a needle type system and is injected into the intake manifold
this was an additional $100 and was invented to stop the cylinders burning out dry while running on gas so hope this imfo helps someone make up there own minds
FollowupID: 655460
Follow Up By: fisho64 - Tuesday, Oct 20, 2009 at 14:43
Diesel and petrol does not in any way provide lube for cylinder walls, in fact a poorly atomising injector/carb or over-rich mixture washes lube off the walls causing increased wear.
The issue is that LPG (and ULP) in an older car doesnt contain lead which cools/cushions valve seats.
Flashlube wont cause any harm (emmissions maybe?) in a newer vehicle though and any help is probably worthwhile.
FollowupID: 655490
Reply By: Member No 1- Tuesday, Oct 20, 2009 at 08:59
when gas first came out for petrol engines didt they have have a lot of dramas??, although they seem to have it fixed now.
used to do work for a hospital that had natural gas engines.....lot of troubles they had....i was there one day when one of the engines began making a horrible noise and let go.....scared the be geezes out of me...
wonder if its cos diesel type engines just still are'nt built for gas???
AnswerID: 387851
Follow Up By: Member - ross m (WA) - Tuesday, Oct 20, 2009 at 13:45
That was mainly on the old engines that ran on leaded petrol.
These engines relied on the sulpher dioxide coating on the valves to cushion them as they closed.
Unleaded engines have harder valves and dont need the coating of sulpher dioxide which makes them suitable for LPG.
FollowupID: 655480
Reply By: Member - Wamuranman - Tuesday, Oct 20, 2009 at 10:38
I am researching this issue at the moment so this post is very valuable and timely for me. One issue that has not been raised is the type of system - there are 3 types of gas injection. The earlier ones can "over inject" under some driving conditions and probably in the long term do harm to the engine. the one that propmpted my interest was the one that won the Inventors (ABC TV) episode earlier this year. their technology appears to better than the earlier ones. My point is that the type of system used can play a big role in how successful or not the process is. As someone else has already said the earlier gas petrol conversions had problems but they appear to have been sorted out. If the injection of gas provides better combustion of the diesel fuel - all other things being equal - it suggests to me that the principle of gas injection should give more power and better economy.
What system did you install The Bull?
I would like to hear from anyone that has installed gastek system.
Here is an extract from their web page regarding the 3 types of systems:
"Oils aint Oils
On the market there are three main types of diesel/LPG systems.
Solenoids and Jets
Stepper and Venturi
True Gas Injection
The solenoid/jet method is the oldest and most crude system available on the market. Basically the system consists of a solenoid to turn the system on and off and a jet to control the flow of gas.
The problem with this method is that while the system is on, the flow of gas is constant when the engine is not. This mean that while the vehicle is idling, there is too much gas going in, damaging the engine. While pulling a caravan or horse float, the engine is working hard, there is not enough gas, giving poor performance and fuel savings.
Unfortunately the majority of diesel/LPG systems on the market use this method because it's cheap to make and fast to install, allowing the manufacturer and installer to make a quick buck before it all turns pear shaped. Tuning is done by unscrewing the jet and replacing with a bigger or smaller jet. These systems damage engines and give poor fuel savings.
Being the cheapest to make also means these are the cheapest to buy and give truth to the phrase “Buyer Beware”. "
I have no association with gastek.
The stepper and venturi method is an improvement over the solenoid/jet method but still falls way short of a true injection system. This system uses a stepper to open and close a valve gradually to meter the gas flow and a venturi to allow the gas to be sucked into the engine.
The killer with the stepper/ventrui system is the response time. These systems make take up to 20 seconds to catch up with the engine. Just think how long it takes you to turn your garden hose on from fully open to fully closed and back again. These systems work just as fast.
With a response time like that, you have already overtaken the car ahead before the gas has caught up with the engine. If you hit the brakes hard, the system is putting gas into the engine long after the diesel has stopped, damaging the engine.
A true injection system uses a needle injector, which is the same injector used in all modern petrol/LPG systems. The flow of gas is metered by pulsing the injectors rapidly. This rapid pulsing allows the gas to be exactly measured while giving an almost instantaneous response time.
The faster, more accurate delivery means that better performance and fuel savings can be achieved using less gas and without damaging the engine.
All of these systems claim to “Inject” in their marketing but only a true injection systems use a needle injector. When selecting a system ask your installer if they use a jet, ventrui or a needle injector cause "Oils ain't Oils".
AnswerID: 387864
Follow Up By: The bull - Tuesday, Oct 20, 2009 at 20:38
My gas injection system was installed by Diesel Gas Australia and is a sequential vapour injection which seems to be the 3rd option you mentioned. I have had the percentage of gas changed a couple of times to what I think is now ideal and this is done by the improved installer who “plugs” his laptop system into the vehicle and changes it while the engine is running. It does seem to be somewhat sophisticated. I have also been told by the installer that the gas injection system does not inject any gas into the system while the engine is only idling and in fact it only operates under acceleration. I hope I have got “the best” system but wonder what you think about what I have just said.
FollowupID: 655546
Follow Up By: Member - Wamuranman - Tuesday, Oct 20, 2009 at 21:18
Have a look at this website:
Gastek
The pictures did not come out when I copy(ied) and paste from their web page.
I suspect you have got the second type (not third). Apparently Gastek have invented this needle injector system and are the only ones with that technology.
But that does not mean your system will not work properly - it just means that you need to get it calibrated correctly by a laptop in the workshop.
Best of luck with it - I still believe there are benefits and that it will not harm the longevity of the engine provided the gas is callibrated correctly into the engine and you don't abuse the extra power.
FollowupID: 655551
Follow Up By: Member - Wamuranman - Tuesday, Oct 20, 2009 at 21:20
That link appears not to work although it was inserted correctly. So just go direct to:
www.gastek.com.au
FollowupID: 655552
Reply By: Member - Graham H (QLD) - Tuesday, Oct 20, 2009 at 12:18
Firstly does the 15-16 per 100 include LPG usage.
Secondly your rig, unless vehicle has been certified for more than standard is seriously overweight.
The weights are for a 1 HZ motor
payload 824kg
GVM 3180kg
GCVM 6680KG
Roofrack 200kg
Dont have a prang.
My GXL tows 2800kg and driving at 90k averages 17l per 100km so dont know how you do better with the thirstier motor and an extra tonne
AnswerID: 387873
Reply By: PhilZD30Patrol - Tuesday, Oct 20, 2009 at 14:31
I have LPG injection to my ZD30 TD Patrol. Travelled about 45,000 kms in the 3 years since installation.
Total average fuel consumption over 10,000 kms (all types of driving conditions) remained the same at 12.2 lts/100kms.
However, diesel consumption dropped to 10.9 ltrs/100 and LPG 1.3 ltrs/100.
Engine performance enhanced significantly, especially 0 to 40 kph and in low range hard work situations.
Vehicle now travelled 182,000 kms since new with no engine problems. Runs like new, starts easy, heaps of power, quiet and smooth and no oil consumption.
My service mechanic (not LPG installer) says LPG injection cleans up the combustion chamber resulting in more efficient fuel burning and less engine oil contamination which should result in longer engine life. I hope his information is correct.
I have not met any one with diesel LPG injection who has experienced engine problems.
I have met a few who know of people who have next door neighbours 2nd cousin twice removed etc who have had terrible trouble with diesel gas. The problems get worse after they have had their 6th stubbie.
Hope this helps
AnswerID: 387889
Reply By: Member - mazcan - Tuesday, Oct 20, 2009 at 15:43
hi
with that weight in tow and cvm hope you've got a keen eye great reflexes and above all extremely good brakes and a slow crumple rate
AnswerID: 387897
Reply By: Member - Flynnie (NSW) - Tuesday, Oct 20, 2009 at 18:47
To me fitting gas injection is against the KISS principle. Regardless of its merits or otherwise on fuel economy power and engine life it adds complexity and the need for two fuels instead of one.
The benefits would need to be sizable to offset this disadvantage. Doubt very much that any significant advantage has been demonstrated by going down gas injection path for a motorist. A few percent theoretical advantage is not enough IMHO.
AnswerID: 387932
Follow Up By: fisho64 - Tuesday, Oct 20, 2009 at 22:41
whether for or against LPG one thing it doesnt ad is "the NEED for 2 fuels".
If you run out of LPG it simply runs as it always did, with no difference. The LPG system is completely standalone as I understand.
FollowupID: 655572
Reply By: Max10 - Tuesday, Oct 20, 2009 at 21:29
the 4.2 will be lucky to make it to 400,000 especially towing a van around. I would have said 350,000 tops. The gearbox will go first as these are the weak link in the chain. Expect it to jump out of 5th by 300,000 and have all the wining noises by about 275,000. It will need a rebuild at 350,000 tops as thats about all they are good for.
AnswerID: 387958
Follow Up By: Member - Graham H (QLD) - Wednesday, Oct 21, 2009 at 01:08
Humping that weight around it will probaly give a big sigh and die of overwork long before that.
LOL
FollowupID: 655589
Reply By: harry5 - Wednesday, Oct 21, 2009 at 08:23
Hi Bull have had diesel/gas on my Did Pajero for3+ years and have done over70000ks car starts easy uses no oil i have never heard of anyone personally who has had a problem,the expert told you it would bend the crankshaft where as some one else claims it will burn out valves i had mine fitted by Diesel/Gas technologies i also went back a few times to get the flow cut back it runs about 2.60l per 100k. I get around 200ks extra per tank of diesel at the cost of gas. I would be very interested to hear of any 1st hand problems
AnswerID: 388003
Reply By: acdc - Sunday, Oct 25, 2009 at 21:05
In victoria fitting lpg to diesel's make them unroadworthy, as they no longer meet emission standards, this is in the latest tech bulletin from vicroads.
AnswerID: 388695
