Electro BC1215 charger query
Submitted: Tuesday, Nov 03, 2009 at 11:13
ThreadID: 73491 Views:10625 Replies:2 FollowUps:5
Gday...
Have an Electro BC1215 which came with our new van. The van is connected to 240V house power all the time, and occasionally to a Honda 2kva Genny, and with nothing in use except fridge, it remains on Float. However, if I have the fridge and, say, 3 lights on it drops to Absorption and seems to stay there. Switch off one light and it goes pretty much straight back up to Float and stays there - switch a 3rd light on and it again reverts to Absorption. Is this normal?
Julie & John
Reply By: Maîneÿ . . .- Tuesday, Nov 03, 2009 at 12:32
It changes because the accessories are drawing power from the battery, the modern 3 stage type chargers sense the charge level in the battery and change their charging current accordingly.
Maîneÿ . . .
AnswerID: 389816
Follow Up By: Member - Mike DID - Tuesday, Nov 03, 2009 at 21:47
No, in Absorbtion and Float modes the charger sets the charging VOLTAGE, not the current. The battery determines how much current it will draw at those voltages being fed to it.
That's why you can safely charge a battery with the Float Voltage, even while there's a load connected to the battery.
FollowupID: 657625
Follow Up By: Maîneÿ . . .- Tuesday, Nov 03, 2009 at 22:06
""Modern chargers can sense the level of charge in the battery and taper the charging current accordingly."" taken from the Electro BC1215 charger website
Maîneÿ . . .
FollowupID: 657629
Follow Up By: Member - Mike DID - Tuesday, Nov 03, 2009 at 22:14
. . about as accurate as the Waeco website which can't tell the difference between Amps and AmpHours.
FollowupID: 657630
Follow Up By: Member - Julie & John (VIC) - Wednesday, Nov 04, 2009 at 17:04
Gday...
(this is the 3rd time I have tried to post this reply - so sorry if it appears more than once)
Thanks again for the interest and advice.
Therefore, I assume you are confirming that it is normal for the charger to drop to "absorption" when under load to compensate for that load, and to then return to "float" when the load drops (eg the 3rd light is switched off) and keeps the charge of the batter where it should be.
WHEW - hope I said all that so it could be understood.
Thanks again
Julie & John
FollowupID: 657716
Follow Up By: Member - Mike DID - Wednesday, Nov 04, 2009 at 17:56
Yes. If the charger isn't programmable for battery capacity, then it normally drops from Absorption to Float Voltage when the current drawn by Battery+Load drops below 10% of the rated charger current.
The reverse also applies. Since the current drawn by the battery will drop when the voltage drops, there's no need for hysteresis in the current switch-point.
FollowupID: 657730
Reply By: umopap!sdn - Tuesday, Nov 03, 2009 at 12:47
Hi guys
I've got a BC1220, it has a switch which lets you select "battery charger" or "power supply". From what I've seen, I thought your model may be similar.
Here's the part of the manual that refers-
Power Supply / 2-Stage Charger Mode (see Fig.3)
At this mode the Charger On (5) LED becomes red colour and only Bulk and Float LED will function. The bulk LED will be off
when battery is charged to about 80% full.
The 3-stage charger becomes a 2-stage charger or as power supply in this selected mode because 3-stage charger overcharges
battery with external load.
This selected mode is intended for use to charge battery with external load such as caravan or other battery and external load
combination.
A 2-Stage charger can be used as a combination charger/power supply. An external load can draw current from the charger while
the charger is recharging a battery. The charger does not care how much current is being diverted by an external circuit as it
switches from Bulk mode (constant current ) to Float mode based only on the battery terminal voltage.
However, a 2-Stage charger cannot completely charge the battery when the charger switches from bulk mode to float mode. After
switching to float mode, the battery will, in most cases, be about 80% recharged. The battery receives the remaining recharge
while in float mode over several days.
It is highly recommended to switch back to the 3-Stage Charger Mode periodically when the external load is disconnected.
Also the external load should not be more than 50% of the max. current of the charger, unless the battery is fully charged up. If the
bulk LED is on most of the time then the load is too large.
Hope that helps
Andy.
AnswerID: 389818
