Friday, Nov 06, 2009 at 13:36
Nissan 3.0ltr Quote Sheet (Brusnwick Diesels)
1. New component 6.5ltr Diesel Engine $12,750.00
2. Fully Rebuilt 6.5ltr Diesel Engine $10,250.00
Bell Housing Adaptor Kit $980.00
Machined and Balance Fly Wheel $400.00
Mount Brackets $250.00
Engine Oil Cooler Kit $320.00
Modify Air Con Bracket $180.00
Power Steering Pump and Pulley $350.00
Sanden Compressor $420.00
Repipe and Regas $220.00
New Delco 105 Amp Alternator $320.00
Hoses, Belts, Pulleys, Spacers, Fittings $450.00
Genuine Nissan Mounts x 2 $310.00
Glow Plug Timer Relay and Harness $245.00
3" Exhaust System $800.00
Tacho Sensor and Gear $245.00
Electric
Fuel Pump $250.00
Auto Electrical Re-wire $570.00
Donaldson Kit $410.00
Air Intake Hat $150.00
Vac Pump and Pulley $400.00
Labour to fit Chev V8 Diesel $2,750.00
Police Pass Licencing Approval $150.00
Heavy Duty Clutch 12" Turbo Diesel $750.00
3.9 Diff Centres fitted with Speedo Corrector $2,250.00
New Reduction Starter $550.00
Custom Built Radiator $1545.10
Radiator Shroud $300.00
GVM Upgrade if required $880.00
Warranty 12 Months or 20,000kms
It would be easy to spend $30,000 here on the conversion so the first question you ask yourself, why not buy the 200 Series with a V8 Diesel to begin with, when you have your honest comparison afterwards you can make your mind up either way. I am not promoting the Toyo in anyway but the comparison and question why, begs the obvious comparison IMO.
390235
Follow Up By: Member - Roachie (SA) - Friday, Nov 06, 2009 at 13:46
There is NO COMPARISON between the Chev engine in a Patrol and a Toyota 200 series (or even the 79 series with the single turbo V8).
The Toyota is simply a much more modern (ultra modern I would say), computer controlled (nothing wrong with that as long as the computer doesn't have a hissy fit in the middle of nowhere). It produces more power and torque in standard form than the big ol' Chev could ever dream about.
But: on the other side of the equation...... you could pick up a blown Patrol for less than $20K (maybe even $10K) , spend the $30K on it that you mention (and I think $30K is probably at the very upper end of the scale....it would cover say a 2.8 litre Patrol being converted , which requires new gearbox and transfer case{?} I think). So, by your own call, you could have the very top of the line conversion done and be in the rig for $50K (TOPS!!!), compared to a 200 series which I think is around the $80K mark (maybe more).
Now, if you already HAVE the blown Patrol, then the $30K you speak of is "all" that you have to come up with.
Having said that, like most of these conversions, you need to be satisfied that you will keep the vehicle for a good amount of time; because you won't re-coup your cost if you decide to sell it in 12 months (or even 5 years) time.
Roachie
657986
Follow Up By: TerraFirma - Friday, Nov 06, 2009 at 13:53
Yes Roachie you make some very valid points and your spot on in that you would need to keep the vehicle for a period to get some value. To do a fair comparison though you can pick up 2nd hand 200 series diesels for high $60k's so once again the comparison begs the question and the 200 series diesels are holding their value better than anything else on the market.
For someone who loves their GU and the 3.0 litre engine is on the way out and you only need a basic transplant the chevy diesel makes some sense. What will be interesting though is when Nissan introduce their new Patrol as I think buying the new diesel Patrol may be the obvious choice.
657989
