Older Honda Generator EX650 - What can't they be used on?
Submitted: Tuesday, Nov 24, 2009 at 23:25
ozwasp
Hi All
I've got an older 4 stroke Honda EX650 generator and am wondering what equipment it can't be used on?
So far I have just used it for lighting and power tools.
I understand that the newer type of generators (Inverter or sine wave?) can be used on Laptops, TVs, Microwaves, Engels and pretty much all electronics; but am not sure what the older type could be used on without eventually wrecking the equipment?
Reply By: Member - Fred B (NT) - Wednesday, Nov 25, 2009 at 00:00
talk to your local honda dealer and get the specs for it. That will tell you what the output is and what you can run on it.
regards
392506
Reply By: Member - Pesty (SA) - Wednesday, Nov 25, 2009 at 00:01
I use
mine to run my 25 amp ctek to charge batteries, and it will run all those other things up to about 450 - 500 w.
I run most things like that on my 300w or 1000w inverter, mostly for convenience so that i only need to run gen when batteries get down.
It is a very stable power supply.
Pesty
392507
Reply By: Matt(WA) - Wednesday, Nov 25, 2009 at 08:48
ozswap,
I have a GX500 that I use as a back up for my solar setup. It runs my ctek 25000 battery charger. It will run my Evakool or engel and also my laptop and any battery charger I have.
This may or may not work for you but it does for me.
Matt
392523
Reply By: Robin Miller - Wednesday, Nov 25, 2009 at 10:55
Hi Ozwasp
That model is rated to run anything at all (within its power rating)
Can be used to charge batteries as
well , but not reccomended for long term use here as CTEK and other converters do a better and more efficent job.
392540
