self inflating mattress for swag??? are they comfortable?
Submitted: Saturday, Nov 28, 2009 at 20:31
Member - G N (VIC)
"Hi all
Just wondering about if any of the self inflating mattresses are any good?
Dont want something thats uncomfortable, can handle 2"HD foam ok but like 3"more so. How do the self inflators compare?
Would be good to have something a bit lighter and less bulky than the foam.
Whats does everyone use / recon?
Kind regards
GN
Reply By: Member - Rob Mac (QLD) - Saturday, Nov 28, 2009 at 21:33
Hi GN, have tried one I bought from Aldi for about $29 or $30 says 5 Cm thick (2") but still felt too thin for my bony hips, plus it was very slippery with just a sheet as it is vinyl both sides, a mattress protector seemed to fix this a bit, but was still too thin and by the time I got to
Alice Springs from
Brisbane via
Birdsville and Simpson I was ready for a change, so bought a Bushmate single 4WD self inflating Mattress with velour on upper side(stopped the sliding around) and is quite comfortable seems to be a genuine 2" mattress,probably a denser foam, just a bit hard to roll the swag trying to expel the air.
Rob Mac
393059
Follow Up By: Member - Rob Mac (QLD) - Saturday, Nov 28, 2009 at 21:39
Should read "more like 3" mattress"
661048
Follow Up By: Member - G N (VIC) - Sunday, Nov 29, 2009 at 09:23
Hi Rob
the too hard was what i was worried about, it does not have to be perfect but if i keep hitting the ground through the mattress i dont sleep
How hard is it to roll up the bushmate?
regards'GN
661113
Follow Up By: Member - Rob Mac (QLD) - Sunday, Nov 29, 2009 at 21:53
Hi GN, it take a few minutes as there is a fair bit of air to get out of the two bungs, so I do a roll sit on it for a while, do another roll sit, etc.
Rob Mac
661233
Reply By: Member - Mark E (VIC) - Saturday, Nov 28, 2009 at 21:59
If you want the best, don't discount self inflators until you try one of the thicker thermarests.
Camp and comfort series
or
Dreamtime series
I have one of the base
camp ones and it is better than my bed at home!
They're not cheap, but worth every cent.
Mark
393061
Reply By: Member - Old Girl (QLD) - Saturday, Nov 28, 2009 at 22:30
I have one im my swag. Had it for a couple of years. Therenis so many different sizes available now.
393064
Reply By: rocco2010 - Saturday, Nov 28, 2009 at 23:19
gidday
I've swagged it on the 50cm foam and now we tent it on the basecamp thermaraest also 50cm ... and as much as i hate to say it i'm not convinced the thermarest is better. Maybe the problem is you can dig a hip hole under a swag but it is a bit hard tio do it under a tent or maybe it's because I'm older..
i guess the bottom line is we are all different shapes and if you are comfortable in the swag I would stick with it, $200 does not always buy a better night's sleep.
If you can hire before you buy go for it
Cheers Rocco
393074
Follow Up By: Member - Flynnie (NSW) - Saturday, Nov 28, 2009 at 23:58
Agree Rocco
Still have a couple of Thermarests. One is fairly thick and is a lot better than an air bed.
Since I got the swag I only use the mattress that I ordered with it. To me the Thermarest makes sense when packing to a small volume, say a car boot, but if one has the space a good foam mattress is better.
Flynnie
661078
Follow Up By: Member - Mark E (VIC) - Sunday, Nov 29, 2009 at 08:01
When I was silly enough to be using a swag down here in s u n n y (????) Victoria, I found that the thin Thermarest wasn't as comfortable as the original foam mattress, but I was colder without the thermarest, so I used them both :-)
Now I have one of the thicker ones, it is the best of both worlds...warm and comfortable and the thing rolls up nice and small. No great big roll of bedding on the roof... :-)
Mark
661097
Reply By: Member - Sigmund (VIC) - Sunday, Nov 29, 2009 at 08:01
The min thickness of padding you need is the difference between your hip width and waist width.
Apart from that you can vary firmness by changing the air pressure in a self-inflator.
But another function is insulation, and traditionally to get more of that you had to go for a thicker mat. (Try sleeping in sub-zero temps and you'll find that though you may have enough padding in a 1.5" thick Thermarest you'll still have an uncomfortable night).
That nexus has been broken by Exped mats that are a cross between an air-mattress and a self-inflating foam job. For insulation one model has down and another has some kind of synthetic. Both need to be blown up, no drama, and both pack down to about half the size of a 1.5" thick Thermarest.
One drawback however is that when you sit up on them your bum is on the ground.
I've camped for 30 years with a std Thermarest but recently moved to an Exped Synmat and find it very comfortable.
393090
Follow Up By: Member - G N (VIC) - Sunday, Nov 29, 2009 at 09:28
Hi Ern
Sounds interesting, but if your bum hits the ground when sit up, how does a double go? if one gets out then one hits the bottom? or is one rolls over the other gets a show ride?
How much do you realy save over a 75mm foam mattress?
regards
GN
661114
Follow Up By: Member - Sigmund (VIC) - Sunday, Nov 29, 2009 at 10:16
Don't think they come in doubles GN.
As for space saving, compared with a full length std Thermarest (ie. 40mm thick) they're about half the volume. From memory the Synmat has a thermal rating of 5.9.
The target market is really light weight campers, not car campers.
661124
Follow Up By: Member - Sigmund (VIC) - Sunday, Nov 29, 2009 at 10:19
Here's some guff on them:
click
661125
Reply By: MEMBER - Darian (SA) - Sunday, Nov 29, 2009 at 12:07
We have the 1.5" thick Thermarest self inflators - used them off and on for some years and they are good - bloke who sold them said the 2" thick units are meant for sleeping on ice ! He said any more than 1.5" would be overkill for campers in moderate climates. Think he was right. They are very compact of course when rolled up, though getting them as flat as they are new ex factory would be a bit of a struggle. While they look too thin to be comfortable - we were pleasantly surprised on first use. Have not used ours for years now and have moved to a van formula but we intend to be tenting on occasions while on van trips, so they still have some work to do for us.
393115
Follow Up By: olcoolone - Sunday, Nov 29, 2009 at 21:12
Can't praise the Thermarest enough, they are expensive but worth every cent.
The cheap ones around a $100 are not worth the money but a Thermarest around $400 are, it's the difference between a bad and good nights sleep.
But then again some people on here think all mattresses are the same and you would be wasting money on a good one.....how wrong.
661227
Reply By: Member - Carl and Pamela - Monday, Nov 30, 2009 at 09:07
Hi GN,
I have found the self inflating harder to roll up and work better when you allow them to rest inflated for a while. My thoughts are that people tend to get sold the wrong foam from shops. So perhaps some back ground here.
Foam is described by 2 sets of numbers. 23-130 is perhaps the most common foam found in a Clarke Rubber or
camping mattress. 23 is the weight of a 1 cubic metre block of foam. That is, it would weigh 23 kilos. The higher the number, the higher the density of the foam. 36 is about the highest density foam available in stores. This has nothing to do with the hardness of the foam but is the "quality".
130 is the hardness of the foam. To be technical it is the force required to push a round dinner plate into a 40mm thick piece sitting on a solid suface, to a depth of about 25mm.
So you can have a entire range of different numbers. If you had a 36-80 mattress, it would be very comfortable but you would have to make it 100mm thick for a swag. It would be very heavy and hard to roll. Therefore not practical.
If you had a 16-400 mattress, it would be lightweight and easy to roll but very hard. You would not sleep and also therefore not practical.
You can also mix and match as
well. A thin layer of hard on the bottom and a thicker layer of soft above. My mattress is 3 layers laminated together.
You can head to the local foam guy and get him to lay different foams on the floor to try. See how they feel, roll up, cost and weigh. He can also cut it to the size of your swag or you can also do it with an electric bread knife. Look at 23-130 X 75mm, 36-130 x 50mm, 35-130 x 50mm, 16-100 x 100mm.
Laminated perhaps 29-200 x 25mm and on top 16-100 x 50mm. This is low cost, lightweight and yet comfortable. If he tell you it is not suitable for a mattress he is wrong.
Hope this helps.
393201
Follow Up By: Member - G N (VIC) - Thursday, Dec 03, 2009 at 07:41
Hi Carl + Pamela
many thanks for a great peice of info on foam. I will keep this for future reference as often when you ask in the
shop they dont know much and its difficult when you dont know yourself.
there is more to it than you would expect.
we will experiment.
we have our main swag with 75mm green type foam which is very comfy and great but a bit bulky all up.
we still have an old swag which we got repaired recently and are thinking of keeping it set up as our "light weight" option. it has 50mm green type foam and is almost ok but sometimes you seem to hit the bottom and not sleep
perhaps we could laminat e a thin sheed of higher density under the existing 50mm?
kind regards
GN
661681
