Wednesday, Dec 16, 2009 at 15:16
If the
fuel concerned was an Ethanol mix (E10), it absorbs
water from the humidity in the air. The longer the time the more
water. The
water then goes to the bottom of the
tank, taking some of the Ethanol with it.
Ethanol is also a great solvent and will clean all the gunk out of the
fuel system and take to they filter and sometimes beyond, causing all sorts of engine problems.
Ethanol also gives less power per litre than standard
fuel, so uses more to go same distance (3% to 7%).
As for the
fuel treatment, there are such items and they do work within reason. What happens is the dry
fuel treatment forms a coating around the
water molecule's, allows to travel through the system and get inducted in the normal cycle with clean
fuel vapour. There is of course a limit to the amount of
water it will treat and allow to be effective in the induction cycle. These products "Dry Fuel" by Quicksilver is one, have been available for many years for Marine use and do work
663746
