Padlock on safety chains
Submitted: Thursday, Dec 17, 2009 at 12:43
ThreadID: 74469 Views:5142 Replies:12 FollowUps:9
My camper has only 1 chain to connect to the to my Patrol. It was made this way and from what I have read it is all that is legally required.
What I want to do is weld on another chain that I can padlock to the Patrol as a theft deterrent. I will use the same type of chain as the safety chain (in case the missus padlocks the wrong one...).
My question is - will having 2 chains require me to use shackles on them both or can I padlock 1 of them, considering it only legally needs one chain?
Reply By: landseka - Thursday, Dec 17, 2009 at 12:55
Provided the padlock is at least as strong as the chain you would not have a problem.
I laugh sometimes when I see a caravan weighing over 2 tonne having its obligatory 2 safety chains secured to the tow vehicle with mild steel shackles that, if they were given a rating it would be 10kg max.
Neil
AnswerID: 395417
Reply By: Sir Kev & Darkie - Thursday, Dec 17, 2009 at 12:56
I would shackle both chains and get a lock for the hitch mechanism.
Cheers Kev
Russell Coight:
AnswerID: 395418
Follow Up By: landseka - Thursday, Dec 17, 2009 at 15:31
Good idea with the hitch lock, but with that there would be no need for the second chain.
FollowupID: 663951
Reply By: Ray - Thursday, Dec 17, 2009 at 13:01
Just to be sure you don't weld the chain the the A frame unless its mild steel chain. If rated chain is the legal requirement you can weld a bracket to the frame and attach the chain with a hammerlock.
AnswerID: 395419
Reply By: ajd - Thursday, Dec 17, 2009 at 13:53
Why not use a shackle and a padlock on the one chain, then you are covered.
AnswerID: 395426
Follow Up By: landseka - Thursday, Dec 17, 2009 at 15:28
Because anyone could undo the shackle and steal the trailer??
When I worked in a garage years ago we had one guy would drop off his car early for servicing. He would lock the car carefully then put a big sign on the windscreen for us "KEYS ON TOP OF L/H FRONT WHEEL". Always got a giggle.
FollowupID: 663950
Follow Up By: ajd - Thursday, Dec 17, 2009 at 16:27
In parallel not in series.
FollowupID: 663967
Follow Up By: landseka - Thursday, Dec 17, 2009 at 16:39
Ahhh through the same link, of course. D'oh.
FollowupID: 663969
Reply By: ozjohn0 - Thursday, Dec 17, 2009 at 15:28
Unfortunately whether using one or two chains they must be attached to the Tow Vehicle using 'D' Shackles. If you only require it for security purposes when parked somewhere then you could use a piece of chain looped through the A-frame and attached with a padlock.
ozjohn.
AnswerID: 395442
Follow Up By: Shaker - Thursday, Dec 17, 2009 at 16:55
Be careful locking unattended trailer with padlock & chain or cable, insurance companies do not regard this as 'secure storage'.
I often see boats on nature strips chained to a pole or a tree, they would most likely have a theft claim rejected!
FollowupID: 663971
Reply By: Alan S (WA) - Thursday, Dec 17, 2009 at 15:34
Occasionally i ahve had to park at the train station with my trailer, all i do is , go around remove the shackle and replace with padlock. When i get back I remove padlock and replace with shackle. Only takes a few minutes.
AnswerID: 395444
Reply By: landseka - Thursday, Dec 17, 2009 at 15:36
Does the camper have a 'ball' type hitch or the 'offroad uni' type?
If the ball type then you can buy, quite cheaply a hitchlock which will lock the trailer to the car and also van be fitted to the ball to prevent it being stolen when not connected to the vehicle.
They come complete with padlock and can be bought from most caravan parts outlets or even Supercheap and the like.
AnswerID: 395445
Reply By: Member - Oldbaz. NSW. - Thursday, Dec 17, 2009 at 15:57
If your hitch is the treg type, replace the "R" pin with a lockable type. Lock it through the treg when trailer is disconnected & you are secure on & off the vehicle. You can buy them on this site for very little moola.
PS wrap some leco tape around lock when fitted..keeps dust out & prevents
lock vibrating loose on rough roads......oldbaz.
AnswerID: 395451
Follow Up By: Dave B ( BHQ NSW) - Thursday, Dec 17, 2009 at 20:02
I use a bit of bicycle tube over the body of the lock to stop the dust.
Just push it off to one side to unlock it, it saves unwinding leco tape each time.
Dave
'Wouldn't be dead for quids'
FollowupID: 663999
Reply By: OREJAP - Thursday, Dec 17, 2009 at 15:57
In Victoria (don't know about other states) one chain is OK but two are recommended in reuirements for a trailer to be registered. Safety chain(s) must be fitted unless a braking device has been fitted where the vehicle & trailer seperate. The safety chains are fitted to keep the A bar off the ground & NOT to allow a trailer to become an out of control weapon. I had to read the Vic Roads requirements for rego again because on one s/ment they say safety chains must be fitted to keep A bar off the ground if vehicles seperate however on the other hand it states if a brake controller (wire that activates trailer brakes) is fitted there is no need for chains!!! By the way fellow travellers & four wheel drivers. Use shackles on your dogs collar when you are walking same. That's all they are good for. People constantly use shackles bought in a hard ware shop or supermarket (D Shackles I am talking about) and wonder why, when under load they explode and become possible fatal missiles. My advice, use a load rated Bow shackle with the rating stamped on it.....towing your van? Use a 4.5 tonne rated BOW shackle. Hope this helps.
AnswerID: 395452
Follow Up By: Stu-k - Thursday, Dec 17, 2009 at 20:12
One chain in QLD and two in NSW..seems there the odd one out
FollowupID: 664001
Reply By: CJ - Thursday, Dec 17, 2009 at 16:25
Why not put the padlock and shackle together on the one chain? Padlock for safety against thieves, shackle as normal strenght sagety.
You usually shackle the chain leaving a few links free, you can use a free link for the padlock
CJ
AnswerID: 395458
Follow Up By: Fatso - Thursday, Dec 17, 2009 at 21:14
Simply put CJ.
That is exactly how I do it with my boat trailer at the ramp.
FollowupID: 664020
Reply By: nickb - Thursday, Dec 17, 2009 at 16:31
Cheers for the ultra-quick replies!!
I currently have a standard tounge type towball with a hitchlock. I am looking to upgrage to an offroad hitch soon hence the questions.
Some good ideas there. It seems whichever offroad coupling I get I should be covered.
AnswerID: 395460
Reply By: MEMBER - Darian (SA) - Thursday, Dec 17, 2009 at 17:24
Sorry if it's been said above - with one chain in use, you can shackle the chain to the car (decent rated shackle of course) and then padlock that chain to the car, just a link or so short of the end, through the other shackle hole - if the padlock breaks, the shackle is still there...... that should negate the need for your second / security chain.
AnswerID: 395473
Follow Up By: puttputt - Friday, Dec 18, 2009 at 01:07
Don't expect the chain to offer any security, takes 5 seconds to cut with bolt cutters.
FollowupID: 664064
