stuffed engel
Well the " legend in reliability" has died. Only 4 years old and the beers are WARM, the icecream has melted and if you said I was not happy=that would be the understatement of the year. So my question is- does anybody know where I can take it to get it repaired in Bunbury? ta, doc.
Reply By: Member - Stephen L (Clare SA) - Sunday, Jan 03, 2010 at 22:28
Oz doc
sorry to hear of your trouble, and lets hope that it is something simple. Below is from the Engel site, and as you can see, there are a few places to take your fridge.
BUNBURY Outdoor Sports & Leisure Homemaker Centre, 10 Mervyn Street 6230 08 9721 6366
BUNBURY Coventrys 63 Spencer Street 6230 08 9721 4722
BUNBURY Sportsmarine 113 Victoria Street 6230 08 9721 4961
BUNBURY Sportsmarine Boat Centre 57 Strickland Street 6230 08 9721 4390
BUNBURY CJD Equipment Cnr Jookson & Poat Roads 6230 08 9725 4885
BUNBURY Retravision - Bunbury Cnr Blair & Strickland Streets 6230 08 9721 5111
BUNBURY Retravision - Fridge & Washer City Sandridge Road 6230 08 9721 9733 Click Here
BUNBURY BCF - Bunbury 146 Blair Street 08 9791 5233
I hope this helps you out.
AnswerID: 397518
Follow Up By: oz doc - Sunday, Jan 03, 2010 at 22:40
Thanks Stephen. The places you listed look like engel stockists- and I assume they will need to send the unit on to somewhere else. I was hoping there might be a refrigeration place down here that does the service/repair work, if not I might have to take it to Balcatta.doc.
FollowupID: 666370
Follow Up By: Maîneÿ . . .- Sunday, Jan 03, 2010 at 22:52
Down the road in Busselton we have a refuse tip that accepts all sorts of throw-away rubbish, trash and garbage, yes even stuffed Engels too :-)
but on a brighter note, do you know if it's a lack of gass problem, or an electrical fault ??
Maîneÿ . . .
FollowupID: 666374
Follow Up By: oz doc - Sunday, Jan 03, 2010 at 23:01
Good grief Mainey- you must have read my mind. I was just saying to my partner that at this moment I fell like throwing it up the tip! My opinion of engel has sunk as low as my opinion of " neverkool". I think it may be a gas problem- makes all the right noises - only it is not getting cold.Fridge is at 20 and freezer is on 17. (insert sad face here).doc.
FollowupID: 666377
Follow Up By: Member - mazcan - Monday, Jan 04, 2010 at 00:23
hi oz doc
those places listed above are all retailers dont waste your time
all due repects to stephen l
i recommend you to go straight to dm & s curtin refridgeration repairs
1 george st bunbury
phone 97215126
a/hrs 016301288
been there for years and reliable
domestic and commercial
FollowupID: 666385
Follow Up By: oz doc - Monday, Jan 04, 2010 at 00:45
Thanks mazcan - I'll give them a call tomorrow and tee things up. doc.
FollowupID: 666388
Follow Up By: landseka - Monday, Jan 04, 2010 at 11:25
I agree with Mazcan, the place is also known as Vaccum World, cnr Bourke & Stuart Sts Bunbury. (not far from home)
FollowupID: 666434
Follow Up By: Who was that again? (Vic) - Monday, Jan 04, 2010 at 22:30
Last year I got a new unit put in the Engel and it was a lot less than a second had one to buy on eBay. One way or another, that is probably your best option, unless you are likely enough to follow the Mainey option. To buy on eBay frequently over $600-$700 for a 40 litre Engel several years old, $540+/- to fix it with new compressor, and everything.
Mind you, some had a five year warranty. Did yours?
FollowupID: 666550
Follow Up By: oz doc - Monday, Jan 04, 2010 at 23:08
WWTA - unfortunately mine did not have a 5 year warranty- only 3 years. It is a 57L fridge/freezer combo. I guess all decisions will have to be based upon the diagnosis and estimated cost of repair. In my current mood- I suspect only two options will be considered- fix it and sell it off, or bin it and put the money saved towards a new fridge. Have to wait and see what the 'man' says tomorrow. In the meantime we will have to dust off the esky and 'slum' it.doc.
FollowupID: 666558
Reply By: mowing - Sunday, Jan 03, 2010 at 22:50
There is Lyons Air conditioning in Kewdale that are a Engel repairer/service agent.
Mark
AnswerID: 397522
Reply By: Richard Kovac - Sunday, Jan 03, 2010 at 23:17
doc
I had a 21 l crap itself a couple of years ago swing motor stopped swinging.. :-((
the cooling part of the fridge comes as one pre gassed pull out old unit throw in new unit plug it in and all go.. sound easy.. so I took it to Lyons Air conditioning in Kewdale... LOL paid them the 1 hours labour and got the full years warranty.
at the time it worked out about a 1/3 of the price of new.
Richard
AnswerID: 397527
Follow Up By: Member - Tezza Qld - Monday, Jan 04, 2010 at 21:05
Pick it up and give it a shake, especially if it has been stationary and running on 240 volt . Then give the fridge ten mimutes or so and turn it on.
What have you got to loose?
Cheers Teza
FollowupID: 666537
Reply By: Member - Alan John C (WA) - Monday, Jan 04, 2010 at 11:15
Doc,
Let us know how you went when fixed I have a 40lt about the same age it stopped I sent it into gunmart and tackle Midland a day later and $500 I got it back the gas curciut was blocked, they asked me if I had taken it on rough tracks I thought that was what they were built for not just bitumen.
AnswerID: 397555
Follow Up By: GerryP - Monday, Jan 04, 2010 at 21:49
Within the refrigeration circuit, there is a small "pencil" strainer/dryer which joins on to a very small diameter capillary tube (standard refrigeration design). In the past, there have been a number of cases where the internal strainer material has come adrift and blocked the capillary tube. It's a relatively easy job (for a fridgie with the right gear that is) to replace the strainer, clear the capillary and regas it. If this is the problem, there is definitely no need to replace the whole unit. This was apparently a reasonably common problem with some o the earlier models.
Gerry
FollowupID: 666542
Follow Up By: oz doc - Monday, Jan 04, 2010 at 22:19
Um, can I ask GerryP, what would this 'pencil' strainer/dryer be called in another language? and where would one look to find it? Not that it will help me at all. I hate having to take things to the 'man' to be fixed.You never really know if you are getting diddled or not. doc.
FollowupID: 666548
Follow Up By: GerryP - Monday, Jan 04, 2010 at 22:39
Hi oz doc,
It's actually called just that, a "pencil dryer". It is fitted in the liquid line, which is a tube (probably 1/4") coming from the condenser. The pencil drier is tubular, copper and probably around 100mm long and near 20mm diameter. From the pencil dryer there is a capillary tube (probably around 1/8" diameter) which then goes to the evaporator (freezer coil).
Unfortunately, it's not a job that one can do yourself as you need the proper gear like high vacuum pump, gauges and of course, refrigerant gas. It's a licenced trade with heavy penalties (around $10k) if you get sprung - all to do with saving the ozone layer and global warming.
However, you may be able to diagnose if this is the problem. Run the fridge for say 10 or 15 minutes and feel the capillary tube where it leaves the pencil dryer - it should be warm. If it is cold, (sometimes even frost may be evident) then there is a partial blockage. If it's totally blocked, then this won't work - it will just be warm all over. Worth a try though.
Hope this helps mate.
Gerry
FollowupID: 666553
Follow Up By: oz doc - Monday, Jan 04, 2010 at 23:12
Thanks Gerry, having a good look around I can identify the 'pencil dryer', and I can also see what looks like a dried fluid trail sitting underneath the compressor. I suspect this may be the lubricant left behind from when the coolant leaked. Nothing for it I'm afraid- will drop it off tomorrow and see what 'the man' says and go from there.thanks, doc.
FollowupID: 666560
Reply By: Member - Cantiva Clay (NSW) - Monday, Jan 04, 2010 at 13:20
I don't mean to hurt your feelings but as they say, only Waecos Work out West!
AnswerID: 397573
Follow Up By: Ozrover - Monday, Jan 04, 2010 at 15:39
Had a bloke in the other day with a dead Waeco (2nd one in two years) wasn't happy, no cold beers until he got here!!
FollowupID: 666481
Follow Up By: Member - Stephen L (Clare SA) - Monday, Jan 04, 2010 at 21:34
Hi Cantiva Clay
There is a classic saying from the movie "The Castle" which applies to your post....You must be dreamin'
FollowupID: 666540
Reply By: Holden4th - Monday, Jan 04, 2010 at 21:37
This is slightly off topic but for those of you who have had an Engel/Everkool/Waeco die on you I have a question. What do you do with your fridge when it's not traveling?
The reason I'm asking this is that an old mate of mine who's been in the refrigeration/whitegoods business for decades has a theory about fridges that give up the ghost. He's seen so many 'dead fridges that had been left unpowered for a period of time then restarted only to die that he thinks that the best way to treat any fridge is to leave it running continuously for as long as possible. He also says that if you do have to turn it off get it back up and running asap.
Based on this my Waeco FF40 is my beer fridge at home and is never turned off until I have to take it traveling with me.
AnswerID: 397653
Follow Up By: oz doc - Monday, Jan 04, 2010 at 22:12
Hi Holden 4th- I was of the same opinion about fridges- keep them running. Our engel acts as a beer and overflow fridge when not travelling around with us. It normally sits in air conditioned comfort in the kitchen. It was working fine over new years- we took it up to Perth with us. I then turned it off when it was empty and defrosted it/gave it a clean. Turned it back on- all good- even managed to freeze the oj I put in the freezer side. Came home with it- plugged her back in - and then it failed- can hear the motor running but only one small area of the freezer plate is getting cold.I hope it is not going to ge expensive to fix- if so I may just safe my money and put it towards a deposit on another fridge- maybe a Bushman.doc.
FollowupID: 666546
Follow Up By: get outmore - Monday, Jan 04, 2010 at 22:34
whilst i dont do this im pretty sure the destructions for my Engal specifically recomended continous running as a second fridge when not in use
FollowupID: 666552
Follow Up By: Member - Ed. C. (QLD) - Tuesday, Jan 05, 2010 at 04:04
Well, I haven't had an Engel die on me (touch wood;-), and my experience with these has shown me that it is _not_ necessary to run them full time...
My 29L, which I bought 2nd hand more than 31 years ago is living proof of this (powered up only when needed, and several times in it's life it has sat unused for a year or more), and it'll still ice up ya beer at # 2 on the dial ;-))
same applies to the newer (6½ y/o) 57L 'combi', used as required (and only when required)..
The way I see it, If you have a use for the thing, then by all means use it, but if not, Why waste electricity ??
(YMMV)
Confucius say.....
FollowupID: 666570
