SHURFLO Mains Press Regulator - Leak
Submitted: Thursday, Jan 07, 2010 at 14:27
Matt Watson
My fan has one of these on it, and it leaks behind the finger screw/tap. so not inside the van, just all outside. When tightening it, I can't get it tight enough for the tap not to feel loose, it still wobbles about. Is this part meant to be tight/wobble free when connected? I'm wondering if there is a washer missing, I can't see any obvious spots where one would be missing.
Any suggestions before I go
fork out for a new one? Is this the best type of connector to use for connecting mains
water to a van?
Thanks.
Matt.
Reply By:- Thursday, Jan 07, 2010 at 14:38
Hi Matt, from memory you need to buy a double ended male thread in 3/4inch to screw in to the pressure reg and then screw the tap fitting on the other end of that. The one i have in black poly but they come in brass also. Bunnings or a plumbing supply
shop will carry them.
cheers Troy
398089
Reply By:- Thursday, Jan 07, 2010 at 16:54
Matt , thats not the one i was talking about. The one i have used is generally used in irragation and is threaded on both ends it would be about an inch long. it will screw in to the reg all the way and then on the other side you will need a female tap fitting (like you would use on your house tap) to screw to the other male tread end.
Sorry i dont have photos but some else may help, the one you have always leak
cheers Troy
398116
