Friday, Jan 08, 2010 at 22:30
Lyndon,
Don as usual, is 100% correct.
I found the only way to get those screws out was with an impact driver.
Keep in mind belting bearings with a hammer isn't good for them.
Then again, the fact there's been moisture in that hub would indicate they need replacing ayway.
Last one of those I pulled apart I took the Phillips screws to the local engineering supplies place (such as Blackwoods) and bought the equivalent in Unbrako socket headed cap screws. No more plasticine Japanese Phillips heads for this little black duck!
Pity you and I live so far apart, you could have had my 3 pronged service tool for as long as you needed to set the pre-load on the new bearings.
Geoff
| Geoff,
667296
