Independant Suspension
Submitted: Saturday, Jan 16, 2010 at 22:05
Spana
Ok, so I know this topic has come up a few times, and I hope I've read most of these threads.
We have narrowed down our little camper hunt to a Goldstream Wing.
So having agreed to spend a small fortune on the trailer, the only option I'm not sure of, is the independant
suspension.
I know I've read both sides of the story, but what I've come out with is that the main reason not to go independant is the fact that is a costly option.
So if money was not an issue, (it is, but lets pretend it's not) is it a good idea to go this way. Not for towing ease, but for extending the life of the camper and it's contents.
If it'll be easier on the camper and contents, than I'm thinking that for the life of the camper, 2 grand is a good bit of insurance.
I guess I'll be more happy going, "this is one expensive camper, but hell it handles it all
well!" rather than "this is slightly cheaper, but hell! what happened to our fine dinner ware"
Cheers in advance for any opinion!
Enjoy OZ
Troy
Reply By: fisho64 - Saturday, Jan 16, 2010 at 22:53
personally I dont see how independant
suspension makes a great difference on a trailer. Its free to ride where it sits as opposed to a car with 4
wheels. There might be a small reduction in unsprung weight, but a leaf spring solid axle with a shock absorber setup correctly is simple robust and easily replaceable/repairable-and PROVEN.
399794
Reply By: Member - Oldbaz. NSW. - Sunday, Jan 17, 2010 at 08:30
I agree with fisho64, my leaf sprung, unshocked C/t has given no problems &
has done most of the usual outback trips. Your contents will always benefit from
judicious packing, & I'm sure you are joking about "fine dinnerware". You will
be unlikely to find parts for your independant job in the less populated area,
should you encounter problems. Plenty of far more useful stuff could be had
for that $$.cheers...oldbaz.
399819
Follow Up By: Ken - Sunday, Jan 17, 2010 at 14:28
I also agree and feel the benefits of independant suspensions on trailers and vans may be greatly overstated.
A look at the massive size of the wishbones needed should raise questions as to unsprung weight for a start. Add to this the extra weight of the heavier chassis to support the wishbones and things don't look so rosy.
Ken
668859
Follow Up By: Shaker - Sunday, Jan 17, 2010 at 14:36
It seems the only people against independent
suspension, are those without it.
If you have had both, as I have, then you would realise that it is better, although I would have to add, that a good rebound leaf spring set up is better than a poor independent design, but an independent
suspension such as the Track MC2
suspension is hard to beat.
668861
Follow Up By: Shaker - Sunday, Jan 17, 2010 at 14:40
I forgot to add, that usually both leaf & independent suspensions as fitted by most camper trailer manufacturers are far too heavily sprung.
Why would you need a 9 leaf spring pack as fitted by Adventure Campers, or 1500kg coils as fitted until recently by Pioneer?
They have to realise that until springs flex, shock absorbers do nothing & you are relying solely on the tyre sidewalls as your "suspension".
668863
Follow Up By: fisho64 - Sunday, Jan 17, 2010 at 14:47
While Im sure many independant systems are better, mainly cos someone going to the bother is taking more care, the trouble is though Shaker
1/ is it $2K better?
2/ you probably wont know your independant is better til you find that its not.
3/ its a lot easier and cheaper to reduce
the springs on a leaf than a coil, hence to tune it if theres a prob.
A single axle trailer doesnt require flex-thats what the hitch is for.
What is the major advantage ?
668866
Follow Up By: Sir Kev & Darkie - Sunday, Jan 17, 2010 at 14:54
Not all Independant Trailer Suspensions contain coils ;)
Image Could Not Be Found
I love the
suspension set up on my Off Road Trailer. It is far better than the leaf solid axle on the Trak Shak that we also own.
Cheers Kev
| Russell Coight:
668869
Follow Up By: Shaker - Sunday, Jan 17, 2010 at 15:14
I am sure that you didn't really mean this .......
QUOTE>
"A single axle trailer doesnt require flex-thats what the hitch is for." ???
Because if you did, please don't comment any more on suspensions!
668874
Follow Up By: fisho64 - Tuesday, Jan 19, 2010 at 21:18
your right-you need heaps of flex in case your hitch seizes up, otherwise???
669362
Follow Up By: Shaker - Tuesday, Jan 19, 2010 at 22:42
It might be eaiser for you to tell me how the hitch negates the need for good
suspension, as I am sure that you won't understand my answer!
669381
Follow Up By: fisho64 - Wednesday, Jan 20, 2010 at 09:56
stating the obvious-a vehicle with
wheels on every corner needs flex, obviously to avoid the situation of a wheel lifting off the ground. Through this range it also needs to react fast for the same reasons, hence lower unsprung weight is a big advantage.
A single axle trailer with a hitch allows the trailer to follow the level of the ground-meaning the main function of the
suspension is to soak up bumps.
In what scenario would a single axle trailer lift a wheel off the ground cos it didnt have enough travel?
Your last followup seems to be presupposing that independant
suspension is "good suspension" and leaf is "bad suspension", I merely say that either can be if poorly setup.
I'll leave it at that as it appears to be making you a little jumpy and Im not interested getting into a slanging match.
669422
Follow Up By: Shaker - Wednesday, Jan 20, 2010 at 19:24
Earlier I said .....
"If you have had both, as I have, then you would realise that it is better, although I would have to add, that a good rebound leaf spring set up is better than a poor independent design, but an independent
suspension is hard to beat."
I have just returned from doing the CSR & have seen the damage caused by poor
suspension, almost everything in the trailer was damaged including steel cans of food bursting!
I also know that it had a very good hitch, but that didn't save anything!
669515
Follow Up By: fisho64 - Friday, Jan 22, 2010 at 12:36
note difference between "flex" and "travel".
My comments were on FLEX, which is taken care of by hitch being able to swivel. As with a scraper or front end loader I guess. They have no
suspension yet flex to keep all
wheels on the ground.
669761
Reply By: zigdog - Sunday, Jan 17, 2010 at 15:27
Well Troy,
The phrase 'you get what you pay for' comes to mind here, closely followed by the annoyingly true 'buy cheap, buy twice' which I have experienced far too many times.
As I type this I can see the underside of my new KK and I'm thinking to myself, yep it was expensive but heck, it looks bloody tough. I'm also reassured by the fact that KK will back their quality by the long warranty, no matter where I take it. To me that says a lot about the quality of the product.
How many of us on here have taken their 4wd's to
places the brochures claim they're designed for only to be knocked back by the dealership department when you try and get them fixed under warranty. "sorry sir, you went where with it and did what... ?"
399866
Follow Up By: Off-track - Sunday, Jan 17, 2010 at 17:05
I dont think those statements have much relation in this argument, you are comparing 2 different types of
suspension and just because independent is usually more expensive it certainly does not mean that it is better. Just the same as you cant take this argument to Patrol utes which you can (or used to) have either coil or leaf.
Otherwise you could just as easily throw in "There's one born every day".
668900
Reply By: Crackles - Sunday, Jan 17, 2010 at 15:31
Troy you just need to follow a leaf sprung & an independant coil trailer over some rough tracks at speed to see the difference. When a trailer with a beam axle hits a pothole it tends to skip around & bounce more. The vast majority of coil setups have longer wheel travel & therefore soak up large potholes without bottoming out. I would go as far as to say a quality coil sprung trailer would ride smoother than any car towing it which has got to be easier on the van & it's contents.
Deciding whether it's worth spending the extra cash would come down to how much rough driving you expect to do & at what speed you like to drive.
A good eye to eye leaf
suspension with shocks will still work
well & be reliable.
Cheers Craig..................
399867
Reply By: Spana - Sunday, Jan 17, 2010 at 17:41
Thanks for the input guys!
The main reason I am even considering the independant coils, is due to the choice of the camper. Had we been going for a tough offroad camper trailer, I'd be thinking they will just go anywhere regardless of
suspension.
We (wife, and 2 little fellas, 3 and 1.5 years old) are planing on our around Oz trip, so for a bit more comfort to the kids and wife, (and possibly the only way I managed to convince her to come) we opted for a less offroad, more comfortable, pop top camper.
Doing the research, and physically seeing the build quality's and difference, we are going for the Goldstream Wing1 offroad.
Now comes the reason for my questions on independant. Being not so dedicated to offroading, will the independant relieve some of the stress encounted with long stretches of corrugations, rocky tracks and the like.
As for fixing on the side of the road, what reall difference is there? Coils can be found everywhere these days, and if it's welds being busted, it'll be equally hard to fix. I guess on one side you may have broken or bent axle's to bother with, the other broken wishbone. Is either way better or worse to fix, and in what way?
The main issue is, I can put what ever options on the camper now, so I'd hate to find out later that I should have.
Thanks again for the differring opinions, and sorry if I've just repeated myself, I just thought I'd give a bit of insight into the reasons for my questioning.
Even differing opinions on the camper would be great!
Cheers again
Troy
399889
Follow Up By: Member - Mark E (VIC) - Sunday, Jan 17, 2010 at 21:56
Have a look at this clip:
(Hope this works. First time embedding video)
There is a much longer version of this video showing far more of the military testing of the MC2 independent
suspension. It shows several comparisons with various military trailers with leaf
suspension. It is very impressive and I agree with Shaker that it is about the best
suspension around....... I am however biased.
BTW the military did purchase this
suspension on their track built trailers for transporting sensitive electronics over severely corrugated roads
Mark
668992
Follow Up By: Spana - Sunday, Jan 17, 2010 at 22:49
Cheers Mark,
That is unreal! would not have expected the trailer to handle better than the tow vehicle!
Offcourse, goldstream's independant isn't the same, but it does give a clear and honest example of how good independant can get!
Troy
669006
Reply By: Doggy Tease - Sunday, Jan 17, 2010 at 23:10
Our previous camper was a Jayco Dove with beam axle.
Our new camper is a Goldstream Storm with the independant
suspension.
Is there a difference....YES,,,and its a bloody big one.
With the dove even tho it towed reasonably
well, i always knew it was there.
With the Storm i only feel it when we hit the rough stuff.
Hire a camper with a beam axle for the weekend,,,then do the same again with a camper that has independant
suspension and FEEL the difference for yourself.
meow.
rick.
399948
Follow Up By: Spana - Monday, Jan 18, 2010 at 19:11
Hiya Rick,
Cheers for that!
We originally started on our camper hunt looking at the Dove, mainly for the compact size, then figured maybe for a year long trek, a bit more room might be nice.
So What made you change in camper makes and size?
Does the bigger camper limit you much in the tracks you decide to take?
And how capable have you found the new camper to be offroad compared to the Dove?
Any help is great
Troy
669186
Reply By: Off-track - Sunday, Jan 17, 2010 at 23:14
I wonder how many people with with independent
suspension on their trailers have IFS and even IRS on their tow vehicles?
Just a thought...
399951
Reply By: Doggy Tease - Tuesday, Jan 19, 2010 at 01:20
We have found that the larger goldstream really makes no difference to where we go, we just take our time and enjoy the trip..:)
Upgraded from the Dove when the two eldest left home and have never looked back.
When we got the Dove, we spent about three years doing bits and pieces to it to get it the way we wanted. When we got the Goldstream i simply said i want this and this and this and this,,,lol and the list went on. Simply put i wanted a camper that had all the little additions we had put on the Dove,,,,,,but straight from the factory and Goldstream were only to happy to help....(and take our money as
well lol :) ).
At the end of the day we are very happy with what we have and it goes where ever the Patrol does. :)
meow.
rick.
400120
Reply By: Keith Berg - Tuesday, Jan 19, 2010 at 20:11
Troy,
I am about to get started on building a camper trailer and have been giving the
suspension question a real hard look. There are two aspects to consider: the way the trailer is sprung and damped and the way the axles are located in position.
Leaf sprung beam axles and independent trailing arms both allow the axle to move back as it is deflected upward but, in the case of independent trailing arms, both
wheels continue to point straight ahead, But the beam axle steers to the left or right momentarily, which can set up a sway, or make the trailer bounce around a bit.
Independent setups with coils or air bags tend to offer a lot more wheel travel and therefore a potentially smoother ride, provided that they are properly damped with the correct shock absorbers.
Whatever you chose, the spring and damping rates have to be a compromise, matched to the loaded and unloaded weight of the trailer. The best
suspension geometry in the world won't perform if the spring and damping rates are wrong. I think this is where the off-the peg independent units have an advantage in that they have long wheel travel and have already been tuned for best performance. But they seem to be limited to about 1500Kg for off road work. One manufacturer even advises that you pull the bushes out once a year for inspection! Bugger that!
Without any first hand experience, I'd shell out for the independent
suspension and look to recover a good deal of the extra money at resale.
Keith
400227
Follow Up By: Spana - Tuesday, Jan 19, 2010 at 20:55
Thanks for the info Kieth,
That all makes sense, never thought about the beam axle 'steering' as it compresses. I know fellas will tell you that it's been working for so long, so why worry about it, but if there's a better option, why not look into it!
As for max load beaing about 1500kg, we will be trying our hardest to minimise weight and excess baggage, and would hope we don't get to close to the mark anyway.
Cheers for your informed opinion!
Troy
669360
Reply By: joff1 - Friday, Jan 22, 2010 at 22:12
Independent does ride smoother but to what end?? so your eggs get a nicer ride? big deal. My leaf sprung camper (and the 2 before this) have been all over the country and never broke an egg so, since my eggs don't complain, I save my money.
Your choice of
suspension (provided whatever you get is good quality) is far less important that you choice of brakes.
400657
Follow Up By: Spana - Saturday, Jan 23, 2010 at 09:59
Thanks for your input Joff1,
I do realise that thoughtfull packing will save any breakages, and to be honest, a few breakages isn't my biggest concern.
I guess the whole reason for this thread is more due to design of the trailer we plan to get. Basically, being not purpose built for offroad, I'm hoping that more thought to the
suspension might limit stress to the camper. Were we to get a typical off road camper trailer, the
suspension would not be a big issue, I'd be confident of there strength due to the simplicity of there design.
It's all about compromise
As for brakes, I think all the camper's in my range tend to go with the Alco electric, don't know too much about these as such, but guess electric is the way to go.
Troy
669923
