12v deep cycle
Submitted: Tuesday, Jan 19, 2010 at 21:38
Samuls35
Got a 12v deep cycle battery and one of those cheap multimeter wondering how i would go about measuring the voltage output and what voltage is full and empty . thanks
Reply By: Peter_n_Margaret - Tuesday, Jan 19, 2010 at 21:55
Samuls35, a multimeter is a very unreliable method of measuring state of charge.
The battery must be rested some hours before a guess can be made, then 12.0 is as low as you want to go and about 12.6 is full, but even those numbers can vary according to the battery type.
OKA196 Motorhome.
400255
Reply By: ABR - SIDEWINDER - Tuesday, Jan 19, 2010 at 22:05
SOC can be measured with volts if the battery is rested.
As mentioned above it is not 100% as it does not show the true capacity but at a glance you can diagnose SOC and any related problems.
400257
Reply By: Samuls35 - Tuesday, Jan 19, 2010 at 22:08
Thanks for your replies what would be the best way to find a soc with know rest time
400259
Follow Up By: CJ - Tuesday, Jan 19, 2010 at 22:15
no easy way - you must rest them
669371
Reply By: PradOz - Tuesday, Jan 19, 2010 at 22:31
A couple links that if read in full may help you understand a little more
multimeterbatteries etc
cheers....
400267
Reply By: RV Powerstream P/L - Wednesday, Jan 20, 2010 at 12:42
A Battery Bug can do the job just fix to pos and neg post and set .
They come in 90A 150A and 300A.
300A currently out of stock.
An explore oz member bought the last one yesterday so Im told.
Just Google Battery Bug by Argus and read about them.
Ian
400319
Reply By: Moose - Wednesday, Jan 20, 2010 at 14:34
If you want to know whether it's charged or not and if it's not a sealed unit buy a hydrometer and check each cell. You can get one for a few bucks from
SuperCheap or similar.
400335
Reply By: ss--ss - Wednesday, Jan 20, 2010 at 17:17
I came across this when I was doing some investigations ..Bit different for the type of battery you have.
400352
