Thursday, Jan 21, 2010 at 17:55
All Clear,
This 6 millilitre (ml) wire you speak of which I assume is meant to be 6 millimetre (mm) is it measured as per the standard layman philosophy of diameter including insulation or the correct electrical measurement of cross sectional area of the copper at 6 square millimetres?
I know this may sound like splitting hairs but in your problem and most extra low voltage problems (12 and 24 V DC are Extra Low Voltage) it is an extremely significant question to answer correctly.
The cable wont be square, it'll be round but the copper cross sectional area should be measured in square millimeters and ignore the insulation.
My guess is exactly what a few people have been telling you, far to much voltage drop in the cables caused by cable that is far to small for the job.
Let me guess, the Waeco Mobitronic unit is mounted either inside the fridge or that close to it there is almost no difference but the batteries are a distance away.
This bizarre and dangerous notion people have of measuring the overall diameter of a cable including insulation and assigning it a blanket current carrying capacity is a recipe for at best failure and at worst fire.
Insulation does not carry power, copper does! How in any basis of common sense can people include the PVC in the current carrying equation?
I guess common sense isn't all that common.
Geoff
| Geoff,
669641
