The value of rotating tyres,
Submitted: Monday, Jan 25, 2010 at 20:26
Geoff (Newcastle, NSW)
I've always rotated tyres. Mainly because the book "say's so"
Maybe it makes them last a deal longer, maybe it doesn't. My guess is it probably does help.
I did
mine on the Troopy this afternoon, 2 spares to the front. Front's to the rear and rears to spare just like always.
I also check the 6 tyres for damaged sidewalls, nails, nicks etc.
Glad I did, this is the one from right rear,
So I guess the plan does more than extend wear life, it actually extends my life too.
The cut appears to go all the way to the inner belt without penetrating it. No idea where or how I did it, just somewhere, sometime in the last 10,000 k's.
Geoff
| Geoff,
Reply By: Hairs & Fysh (NSW) - Monday, Jan 25, 2010 at 20:32
Hi Geoff,
Yep, rotate
mine every 10,000 as
When I've got it off, I have a good Captain
Cook at them.
I can see how they are wearing, and check out if there are any screws/nails or wire stuck in them as you said.
I also reckon it prolongs their life.
It does pay Geoff to do the simple little things.
401005
Follow Up By: Geoff (Newcastle, NSW) - Monday, Jan 25, 2010 at 20:52
Hi Jon,
It does pay to do the simple things.
Geoff
| Geoff,
670273
Reply By: travelmate2 - Monday, Jan 25, 2010 at 20:35
Geoff
whys it look like it's got goo in it?
401006
Follow Up By: Geoff (Newcastle, NSW) - Monday, Jan 25, 2010 at 20:50
The "goo" is the underlying white rubber for the lettering.
Geoff
| Geoff,
670271
Follow Up By: travelmate2 - Monday, Jan 25, 2010 at 21:08
670277
Reply By: Sir Kev & Darkie - Monday, Jan 25, 2010 at 20:44
Are you running white to the inside or to the outside LOL
Cheers Kev
| Russell Coight:
401009
Follow Up By: Geoff (Newcastle, NSW) - Monday, Jan 25, 2010 at 20:51
I think you already know the answer to that one
young Kev!
Geoff
PS, In case you've forgotten, always to the inside.
| Geoff,
670272
Reply By: kend88 - Monday, Jan 25, 2010 at 21:27
By rotating you are probably going to get some value out of the spare.
Otherwise, you eventually get left with a spare that has a different tread pattern, and/or past it's used by date and you should probably discard it.
So using four tyres only and you get 80,000 km out of them, would have got 96,000km if the spare was in the rotation.
kenD
bris
401018
Reply By: Member - Stephen L (Clare SA) - Monday, Jan 25, 2010 at 21:35
Hi Geoff
Yes it was very lucky that you did them when you did, and not travelling on the open road at 110 kph and bang. I rotate my tyres every 5000 and does it work ? - I will never know as by rotating that way the tyre wear front and back is usually the same. I hope the tyre did not have much tyre life lest, as side wall damage is terminal. On our last trip, I collected a very nice piece of large mulga and straight through the side wall of a rear tyre with
well over 3/4 tread life left.
401021
Follow Up By: Geoff (Newcastle, NSW) - Monday, Jan 25, 2010 at 22:18
Hi Stephen,
Very true on the 110kph comment, I'm off to
Singleton in the Upper Hunter Valley tomorrow. I'll have a reasonable run at 100kph.
The cost isn't to dramatic at all, the tyre is in the last third of its life and I didn't pay that much for it to start with.
I bought 5 Cooper 285-75x16 ST's on eBay from a bloke locally for $900. The 4 on the road still had the tread mould teats on them!
He had fitted them to a late model Nissan wagon. His wife had short legs and couldn't climb in anymore. He had to get rid of them and fit 265-75's for her!
There's a truck, earth moving and mining tyre supply-repair place about 5 minutes from home. I'm going to give them a look at it later in the week. If they say terminal then it's terminal.
Mulga roots and tyres aren't a fair fight!
What's James up to these days?
Geoff
| Geoff,
670284
Follow Up By: Member - Stephen L (Clare SA) - Monday, Jan 25, 2010 at 22:30
Hi Geoff
Yes you are very lucky. James is still working away. He is not at Moomba any more. He was working at Blacktip in the Top End of the NT for 12 months on the new Gas plant for the north west shelf, but that was put on hold. He is now working, still with Fyfe Engineering, but based out of
Roma in QLD. There is a very big
gas pipeline in the construction process at
Injune and they can not get enough tradespeople and he said there is nearly 3 years of work there, so he is spending more time in Queensland than is down hear in SA.
Great to hear from you again.
670287
Reply By: Member - Timbo - Tuesday, Jan 26, 2010 at 15:45
Geoff, you should rotate your tyres because the front (steering) tyres tend to wear more on the shoulders while the rear (driving) tyres (at least on a rear wheel drive or part-time 4WD) tend to wear more in the middle or the crown. If you rotate them, you even out this wear across the tread.
If you don't rotate them, you could have to replace your tyres earlier as the front ones will have worn (illegal) shoulders before the crown is worn, vice-versa for the rear tyres.
The difference is even more profound on a front wheel drive car where the front tyres do all the steering, driving and most of braking while the rear tyres just trail along taking it easy!
Including the spare(s) in the rotation will prevent them perishing (particularly if they are rear mounted and exposed to the sun) before you have a chance to wear them down.
401132
Follow Up By: Hairs & Fysh (NSW) - Tuesday, Jan 26, 2010 at 19:00
Hi Tmbo,
12 months or so after I purchased my 80, which had new tyres fitted as part of the sale, before I had rotated them, I measured the depth of the tread on all four tyres.
Using a piece of aluminum in the tread, & a hack saw blade to cut the depth, I found that the rear tyres had 2mm less tread than the front.
Even though my vehicle is constant 4WD I believe the difference is because the power is still put down through the rear tyres, especially when towing, as my old girl does a lot of the time.
And your also right about the steer tyres wearing more on the outside of the tread.
If you can rotate all of your tyres it can only prolong their life.
670430
Reply By: RV Powerstream P/L - Tuesday, Jan 26, 2010 at 16:33
Geoff
How many people can rotate with 2 spares like you can and get 2 spares to the front so thats a bit lop sided isnt it although the principal is correct.
Ian
401151
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Jan 27, 2010 at 12:32
Shouldn't you be getting moderated somewhere else?
Geoff
| Geoff,
670588
Follow Up By: RV Powerstream P/L - Wednesday, Jan 27, 2010 at 13:11
Dont you talk you swore at me and although it may have been appropriate to do so it was wrong.
How do you know you didnt hurt my feelings or was that what you was trying to do.
Sorry you didnt.
BTW been off the tar lately in your 6 wheeled shopping trolley.
Ian
670595
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Jan 27, 2010 at 13:40
Yep, used it to back the box trailer across the footpath just 4 months ago!
| Geoff,
670604
Follow Up By: RV Powerstream P/L - Wednesday, Jan 27, 2010 at 20:31
Gee Geoff that was a feat in itself anywhere getting a box trailer across a foot path it must have been a skinny trailer and to top it off it was in a short land in the outback Hunter Valley.
I apologise for questioning your driving capabilities and your off road nouse.
Ian
670684
Reply By: Hairs & Fysh (NSW) - Friday, Feb 26, 2010 at 20:35
Hi Again Geoff,
Another example of why it pays to 'rotating tyres' is you get to have a good look at whats doing underneath.
Wednesday night the old girl was due for a Tyre rotation. First of all, I notice the backs are wearing overall a little more then the front set. No biggy, I've been towing the horse float a bit lately as
well as the camper and my work trailer. I also notice the front pads have worn down to the metal arm indicator. No problem, I pickup a front set up and replace them. An easy job to do. I however notice a bubble in the flexible hose that runs down to the caliper
Image Could Not Be Found
An easy fix, But things could of been a lot worst. Just imagine if I was towing the camper or even just trying to stop at a round about.
It pays to do your own maintenance not matter how small it is.
It's just not about tyres, it about knowing your vehicle because you do get under it and get dirty.
A very good thread about being vigilante Geoff
Happy travels Mate.
406205
