Part time 4wd question
Submitted: Tuesday, Jan 26, 2010 at 21:18
ThreadID: 75519 Views:3205 Replies:9 FollowUps:1
Hi all. Could someone please let me know if it is possible to select low 4WD without engaging front hubs on 2000 troopy for moving heavy caravan on bitumen driveway ? Am unsure and don,t want to do damage to vehicle.
Reply By: Madfisher - Tuesday, Jan 26, 2010 at 21:35
Had a mate who was a diesel mechanic and he use to do it to move his heavey boat, I do it in the Jack yo back my boat up by drivewayto savethe clutch, so I cannot see any issuses.
Cheers Pete
AnswerID: 401208
Reply By: Member - Duncs - Tuesday, Jan 26, 2010 at 21:41
I used to do it on my GQ for backing the trailer up a tight dirveway and it never seemed to cause a problem.
I figure it engages the front diff but if the locking hubs are not in then the drive is just spinning and you won't get windup.
If you don't steer too much and the drive is not too long you should be able to put the hubs in and do it in 4L. The big question is what is too much?
It won't break the second you do it. Provided you give the transmission an opportunity to un-wind when you are finished things should be OK.
Duncs
AnswerID: 401209
Reply By: ob - Tuesday, Jan 26, 2010 at 21:57
Hi toyo13
I think the reason Toyota and probably most 4wd manufactures engage 4wd with low range is that by doing this you have effectively halved the gearbox output speed and doubled the torque. In a scenario where the driver is using the clutch rather abruptly together with a large application of right foot you could conceivably damage rear driveline components. To spread this increase in available torque drive is also diverted to the front. I personally use low range with the front hubs disengaged to manouver our caravan into or out of tight situations but always use the accelerator in a judicious manner and have never done any damage
Cheers ob
AnswerID: 401214
Reply By: Wilko - Tuesday, Jan 26, 2010 at 22:40
Hi Toyo 13,
I do this to my rodeo and (as long as you keep your speed down) I cant see how youd do any damage.
Some people on this site put there troopys in low 4th gear to take larger caravans down steep hills
Cheers Wilko
AnswerID: 401225
Reply By: Member - Keith P (NSW) - Tuesday, Jan 26, 2010 at 22:42
I do this all the time in my GQ Patrol. As soon as I enter the driveway...straight into low range -hubs unlocked. .... just to make clutch life easier and can just idle about the yard slowly and safely.
Also when I need to park / back up my camper trailer...straight into low range ...usually with hubs out..unless muddy or steep. This is a big help as I can swing from lock to lock easily and quickly ...and back just using clutch and brake without touching throttle. I also believe that doing this prolongs clutch life immeasurably.
Cheers Keith
AnswerID: 401226
Reply By: Stu & "Bob" - Tuesday, Jan 26, 2010 at 22:52
I do it to reverse trailers up my driveway.
AnswerID: 401229
Reply By: Member - Gizmo-Tron - Wednesday, Jan 27, 2010 at 05:59
Hi Toyo13
In the 100 series cruiser you can engage low range without engaging diff lock, need to modify the wiring on pin 7?
May be similar on the troopy.
AnswerID: 401251
Follow Up By: Mikee5 (Logan QLD) - Wednesday, Jan 27, 2010 at 10:02
You are talking about the 100 series with full time 4WD and no FW Hubs. The troopy is part time 4WD. A different kettle of fish.
BTW my 100 series (105) has FW Hubs and no diff lock.
FollowupID: 670555
Reply By: Member - Timbo - Wednesday, Jan 27, 2010 at 13:57
If you're going to do it, make sure the vehicle is stationary before shifting the lever.
AnswerID: 401300
Reply By: Member - Oldbaz. NSW. - Thursday, Jan 28, 2010 at 13:53
Of course it is possible & a very wise move for moving your van. I have done over
half a million clicks in low range, with hubs free while spraying ,without any issues.
cheers...oldbaz.
AnswerID: 401475
