1983 Toyota Landcruiser hj47
Submitted: Thursday, Oct 02, 2003 at 22:36
stephen
I recently read that the late HJ47,s (10/82-10/84) where manufactured with a 5speed gearbox .I own an earlier model with a 4speed gearbox ,I was wondering if any one knows whether the 5speedbox is more economical on fuel and whether it reduces the revs by a signicant amount ,as
mine tends to rev at about 2,700 in 4th. when on the highway at 100kph and boy is it noisey, regards Stephen.
Reply By: Member - DOZER- Thursday, Oct 02, 2003 at 22:49
Gday
You will get the best economy from the 2h at 1800 rpm (max torque rpm) and the 5 speed will drop the revs to roughly 2500 rpm at 100km/hr. 5th gear is 0.85/1, an overdrive of 15%.
The 5th gear in these boxes was an add on, is situated on the end of the layshaft, and fails under excess loading. The 5 speed is 60mm longer and will need its own transfercase aswell (different attatchment to the 4 speed) as everything else moving back 60mm after the box. (driveshafts/crossmember)
Another option open to you is Marks 4wd transfer gears, that make high range higher, and low range lower. This coupled to larger diameter tyres will be a better option IMHO
Andrewwheredayathinkwer mike?
32653
Follow Up By: Taipo - Saturday, Oct 04, 2003 at 03:08
Marks OD are around 23% over and about $1500
23418
Reply By: Joe - Friday, Oct 03, 2003 at 08:30
Hi Stephen, I owned a couple of HJ 47's in those years & none had 5 speeds. The SWB FJs &BJs did have 5 speeds.Dozer knows his Cruisers,on another page a bloke asked about a 3B into a FJ40 .Dozer's reply indercates a 5 speed from a FJ 40 should fit a 2H?. I do recall a 5speed from a 60 serious does'nt fit as neatly as the gear sticks sit in different position. The Marks over drive might be the way to go.
Joe
32668
Reply By: floyd - Friday, Oct 03, 2003 at 12:40
Been there done that priced every option for a HJ 47. The cheapest option is simply to get 33 inch tyres next time your tyres need replacing. The upgrade will only cost a couple of hundred dollars more than standards and you get these benifits:
Reduced final drive by about 500 rpm. 100 kms = 1900 rpm
Higher ground clearance for off road
Way better economy
A more useful 1st gear. (you will actually be able to get somewwhere when starting)
Better overtaking in 3rd
No messing around with driveshafts, diffs and transfer cases
Reduced engine noise when on trips (heaps quieter)
I had a 9/84 trayback with the 2H and the 33's totally changed the performance of the vehicle and got me almost 100kms per
tank more.
Did come with these negatives but I could live with them:
About 1 1/2 inches higher (not easy for granny to get in anymore)
Speedo was a bit out (15 kms at 100, 8 at 80 and 5 at 60). Can get a new gear to correct this but didnt bother.
The alternative is very expensive and a lot of effort. 60 series gear will not go strait in as some may tell you, diff ratio changeovers is costly and 40 series are so rare to find and not that strong.
Hope it helps.
32682
Follow Up By: Jim - Monday, Oct 06, 2003 at 21:09
Floyd,
Did your trayback have a four or five speed gearbox?
With the figures you quoted I assume that your truck had a five speed box.
I currently own a HJ47 Troopie with a four speed box and went through the same process as above and settled for the taller profile tyre option in the end.
I fitted BFG All Terrains 33x9.50R15's where I had the stock 7.50R16 which were worn down to a diameter of 31 inches. I worked it out to be a 7% increase in tyre size overall. The result on my speedo and tacho were not that great. In other words when I am cruising at lets say 50 kph according to my uncalibrated speedo I add 7% to this figure which gives me an actual cruising speed of 53.5 kph. The figures rise exponentially as the speed increases, i.e at 70 kph on my speedo I am actually travelling at 74.9 kph and so on. I found that my truck now cruises on the open road at 96.3 kph when my speedo reads 90. This is a good compromise that I have settled with because my 2h is working at the theshhold of being economical still. As soon as I push the girl harder the fuel consumption goes through the roof like a scared cat on steroids. If there is a mild to strong head wind I back off a little to achieve similar fuel consumption results. Remember you are driving a rolling brick with no aerodynamic shape whatsoever and the venerable old 2h isn't the most powerfull of motors. Maybe my diff gears are a little shorter than usual because initially at 100 kph my tacho was reading about 2900 rpm. Now at 100 it sits on about 2700 rpm.
stephen,
Another thing I did to my truck to reduce engine noise was install sound deadening material under the bonnet and on the interior side of the firewall and on the floor between the vynyl. The product is called soundshield and I found it in a popular auto accessory
shop. there are three types, under bonnet, engine side of firewall and under carpet. The first two types are self adhesive and the third isn't. This product helped tremendously in reducing the noise from the engine which made my trucks engine noise acceplable at speed but I stress that it won't be totally effective if you don't cover as much area of the firewall/bonnet as possible. I am considering buying the engine side firewall sound deadener to reduce engine noise further.
23527
Reply By: Member - Peter- Friday, Oct 03, 2003 at 18:09
I agree with Floyd, I had one of the last hj47's to be made, 12/84 first reg 3/85 and it was a 4 speed and his comments are spot on, fit taller tyres, mind you that wasn't an easily available option in the 80's, there was not a lot available in tyre sizes bigger than standard back then.
I investigated using the entire transmission from a 75 in the late 80's but everything from the bellhousing back to and including the rear diff had to be changed (due to no handbrake on the transfer on a 75 series) so decided that it was cheaper to just get a 75.
32717
