Tyre Choice ??
Submitted: Tuesday, Feb 02, 2010 at 21:05
ThreadID: 75718 Views:8658 Replies:14 FollowUps:23
Related Pages
Hi all, just in the middle of organising tyres for the new rig (2005 GXL Landcruiser TD) with 275 70R17. I need at least good AT's and are in the Pilbara. Would estimate the rig would be doing fair amount off road work in mainly rocky track area's. I try to avoid mud as much as possible. So far my preference is for BFG AT's (have had them before as well as Muddies) but have been advised Goodyear MTR's Kevlar are good. After talking with local tyre fitter he said "i have got a heap of them out the back, they keep blowing out" . He then suggested bridestone duellers AT's. My question to the group is what is your prefered tyre doing the same type of country I will be. I know there will be differing opinions but I will at least get an idea of any common issues.
Cheers Deano
Reply By: Member - Myles F (QLD) - Tuesday, Feb 02, 2010 at 21:13
Here we go again. But that’s ok. My preference BFGs.
Myles.
AnswerID: 402367
Reply By: Mick O - Tuesday, Feb 02, 2010 at 21:34
Coopers ST or STT.
AnswerID: 402374
Follow Up By: Mick O - Tuesday, Feb 02, 2010 at 21:37
P.S. Deano, A search of the forum would provide all the differing opinions and issues you'll need. Just search each tyre type individually and see what you come up with.
Cheers Mick
(Sorry Myles, I had to).
FollowupID: 671834
Follow Up By: equinox - Tuesday, Feb 02, 2010 at 21:51
Cooper STT, when you want to get there, on time, every time!!!! :))))
Image Could Not Be Found
FollowupID: 671842
Follow Up By: Member - Myles F (QLD) - Tuesday, Feb 02, 2010 at 22:15
He he he….. Mick.
It was just eating at you wasn’t it.
I forgive you.
Regards,
Myles.
FollowupID: 671848
Follow Up By: 2000 Red Rodeo - Tuesday, Feb 02, 2010 at 22:43
I currently have a set of Cooper ST's which have done 90,000kms. Although they still have about another 10,000 kms in them I am about to replace them with a set of Cooper STT's prior to the outback trip we are starting in April.
ST's - All Terrain with long millage
STT - stronger side wall - for aggressive tread suitable for mud, etc but as is the case with this sort of tyre reduced milage (although still expect to get 70,000+)
I have done about 200,000 kms on Coopers and have only had 1 flat (nail)
See no reason to change
Geoff
FollowupID: 671852
Follow Up By: ajd - Wednesday, Feb 03, 2010 at 08:50
Coopers are overpriced rubbish.
Had both ST and STC - never again.
FollowupID: 671886
Follow Up By: Ian & Sue - Wednesday, Feb 03, 2010 at 18:08
I agree - we lived in Karratha for 15 years and stupidly put Coopers onto our Pathfinder one year, didnt last 20K before we had to change them out! Ask the guys at the Red Dog 4WD Club in Karratha all about them.
Definatley recommend the BFG's
FollowupID: 671965
Reply By: Member - Andrew L (QLD) - Tuesday, Feb 02, 2010 at 21:41
"but have been advised Goodyear MTR's Kevlar are good. After talking with local tyre fitter he said "i have got a heap of them out the back, they keep blowing out" . He then suggested bridestone duellers AT's. "
Well, that would convince me not to shop with him for tyres..
AnswerID: 402376
Reply By: broome time - Tuesday, Feb 02, 2010 at 22:16
would not have coopers in kimberlys .had troubles them with seperating in the heat. would go bfg or bridge stone dueler.
AnswerID: 402381
Follow Up By: Barnesy - Tuesday, Feb 02, 2010 at 22:22
Cooper are a rare breed in the north of WA. The locals think they are rat..it.
FollowupID: 671849
Follow Up By: The Boss - Wednesday, Feb 03, 2010 at 00:41
You took the words right out of my mouth Barnesy.
They were huge at the start, now you hardly ever see them. If you do, there not on a locals car or a real 4wd.
FollowupID: 671866
Follow Up By: Member - mazcan - Wednesday, Feb 03, 2010 at 11:21
hi
i have had 2 sets of coopers the first set went ok but the next set the tread rubber broke up and the casings started to seperate so i went back to
bfg's as michelin own them now and i had an excellent run out of them even before michy;s bought them my choice is ---bfg
have also tried 3 sets of bridgstones but the tread use to wear down rapidly although had no casing problems with them
for what it's worth
FollowupID: 671914
Reply By: Barnesy - Tuesday, Feb 02, 2010 at 22:19
It depends if you are going onto unmarked tracks or simply staying to marked roads that appear on maps.
If unmarked tracks is your plan then the locals use split rims or 1 piece steel skinnies with heavy duty 10-14 ply tyres. Bridgestone vsx (10 ply) on 1 piece steelies is what I used up there and was happy with them.
You will need a tyre with a closely packed tread, not an aggressive mud tyre. The widely spaced tread can 'catch and direct' sharp rocks and branches into the tyre like a spear.
For marked roads then many of the locals use bfg muddies. Good grip on the pebbled roads and 3 ply sidewall.
Whatever you decide make sure you always carry at least 2 spares and a well stocked tyre repair kit.
AnswerID: 402382
Reply By: Member - Fourplayfull - Tuesday, Feb 02, 2010 at 22:43
Well I'll spend 2 cents too - I have been using Toyo Open Country MT for the last couple of years with a great run over all surfaces including long desert runs off track. Sure, I get the odd tiny stake but never a major slash in the side wall.
They are heavier and more expensive but have great casing strength for a radial.
Mate has Kevlars on the rear of 92 Troopie and the tread is ripped off. Dealer advised rubber composition is very hard.
Cheers John
AnswerID: 402386
Follow Up By: Mick O - Wednesday, Feb 03, 2010 at 16:56
Hmmm are you sure that's correct? 19 plugs isn't "tiny" Ha Ha . I'll let you know how they go on the new beast.
Mick
FollowupID: 671958
Reply By: OREJAP - Wednesday, Feb 03, 2010 at 00:31
Follow Pat's lead (Mr 4X4) & go for the tyre that was voted best A/T recently....the Pirelli Scorpion. I've never used them but I would use BFG T/A. They haven't changed the tread pattern in over 25 years....when you are on a good thing....stick to it.
AnswerID: 402401
Reply By: Member - Joe F (WA) - Wednesday, Feb 03, 2010 at 00:38
G'day Deano You don't actually say what part of the Pilbara you are in, but I guess if you intend running your Cruiser off road, it will be carrying a reasonable amount of gear. You might want to consider the image I have posted, I'm sure the bloke who drives the work ute shown in the image has reconsidered his choice of tyres ~ judging by the new spare ~ Image Could Not Be Found But this is a typical work ute in the Pilbara.
Sadly for Cooper Tires I guess ~ they rank close to the bottom of the heap as a good work vehicle tyre choice, but they are top of the heap on the throw away pile.
I don't for one second think the people who come up to the Pilbara, Kimberley or any other part of inland Australia for a holiday trip in the cooler months, get a good run out of their tyres ~ Cooper, Donfangs or what evers ~ good luck to them.
But given your tyres will live their life, on and off road all year round in the region there are better brands to choose from.
If you want a Pilbara tyre business operators opinion give this bloke a call ~ but be mind full that he may just do you a deal of a life time on a set of Coopers or maybe Donfangs, I know he's got sitting in the back of the shed.
Newman Tyre and Battery Supplies
Murray Hall
08 9175 2755
This is not a deliberate post to cause a stir either and I trust it is not taken as a stirring.
AnswerID: 402404
Follow Up By: DEANO WA - Wednesday, Feb 03, 2010 at 00:51
cheers Joe. Am in Port Hedland and do load up a fair bit. I run a vehicle hire company up here so see my fair amount of tyre damage. I wouldnt use Coopers from the reviews and discussions i have had with clients. Will be doing GRR at easter and do local tracks (local could be up to 500kms away). not much sand or mud. from this and other forums plus discussions with clients and friends I am looking at (in order)
1. Goodyear wrangles MTR "kevlar"
2. BFG All Terrains
3. Bridgestone duellers
Again, any input into these (or other) tyre selections would be greatly appreciated
Cheers Deano
FollowupID: 671868
Follow Up By: Member - Joe F (WA) - Wednesday, Feb 03, 2010 at 01:55
G'day Deano.
Thanks for the addition as to where you are in the Pilbara.
I honestly hope it did not come across as if I hate Coopers, because I really don't give an utter rats as to what people drive their vehicles on, and most people buy purely on what information the advertisers bombard you with and Cooper Tires have a bloody good advertising budjet, It is interesting to note though, Mickey Thompson Tires seem to be the flavour of the month in the major 4wd magazines that come out of the eastern states. But thats just an observation.
The fact is, I've seen more dead Cooper STT tyres than almost any other brand. If you look at the image I posted ~ the spare is actually a Cooper ST.
They to are problematic but nowhere anything like the STT's.
I just hope no one ever asks me about my vehicle preferences and why I would not touch certain big brand vehicles with a long stick !! Now there's a stir for you.
I actually had a very honest run out of my previous set of mud tyres, right up until one tyre started to disintergrate in the carcase, I had a brilliant run out of the Mickey Thompson MTZ's until that one tyre killed the dream.
Would I buy them again ~ No not in a pink fit ~
I have only fairly recently had Newman Tryre's supply and fit 6 ~ BFG MTK's.
I've taken the wheels off the Cruiser and left the BFG's in the shed, to cure inflated on the rims, I do this with every set of tyres. Now I know I will cop some flack, but the method has worked for me for many years.
I run Bridgestone Dueler A/T's for highway work, having only last week returned to Newman after a 3700 road trip towing the caravan, yes the Duelers spent six or seven months in hibernation too!!
I travel up to Hedland fairly regularly, I'll be up there in acouple of weeks time.
Cheers:
FollowupID: 671875
Follow Up By: The Boss - Wednesday, Feb 03, 2010 at 04:29
You made me ask? Whats the go with ''curing'' the tyres in the shed?
Just curious.
FollowupID: 671879
Follow Up By: Member - Joe F (WA) - Wednesday, Feb 03, 2010 at 14:04
G'day "The Boss"
I honestly had hoped this tyre thread would not become a slanging match, between tyre brands. The point that should remain very clear is tyre choice and the application of that tyre choice.
I don't think it really matters if you prefer one brand name tyre over another,or one tread pattern over another, the basic and very important thing is to use the tyre brand x, with tread pattern x for the purpose it was designed for at the air pressures the tyre is required to have, doing that required job.
On road or Off road, loaded vehicle or unloaded vehicle.
The pneumatic tyre was first conceived in 1845 by Robert Thomson, the pneumatic tyre principal was refined by John Boyd Dunlop in the late 1800's
so I guess these two Scotsmen started this thread debate, to a degree.
Now to your question Boss, "what's the go with curing the tyres in the shed"
All tyres (tires) are manufactured ~ Green ~ using a large amount of chemicals mixed into raw and synthetic materials bought together in the manufacturing process under extreme pressure and heat, the curing process is achieved to a certain degree in the mold. The word "Green" is the first stage of a tyre build.
Tyre compound materials include: Carbon Black, Sulphur,Latex and anything up to 16 different kinds of rubber, this is all in the making of a tyre, heat and pressure are achieved using steam at some 300*C. "The curing stage" in the mold is measured in minutes, possibly an hour maybe longer.
To me this is the overriding factor : Quote : Sulphur and other chemicals are also used in tires. Specific chemicals, when mixed with rubber and then heated, produce specific tire characteristics such as high friction (but low mileage) for racing or high mileage (but low friction) for a passenger car tire.
Some chemicals keep the rubber flexible while it is being shaped into a tire and other chemicals protect the rubber from the ultraviolet radiation in sunshine : End quote :
Most tyres (tires) are produced in Asia/China for the world market and there are more than 250 million tyres manufactured each year.
Yes America does produce millions of tires (tyres), but American tire companies also have "Brand" name tires (tyres) manufactured in overseas countries too, by the ship load or is that sh-t load ?
The tyres (tires) may well have been manufactured in Asia/China or India, last week, they might carry a "Brand" name, but they might be on your vehicle today. The Toyota Hilux range of vehicles is Japanese designed but built in Thailand as is another "Brand" name vehicle sold in Australia today,as Japanese vehicles !!
I will stand corrected on some of the material in my follow up answer, because this material on chemicals, heat, pressure and time in the manufacturing was gleaned from the internet. I am not a tire (tyre) engineer, I am like you an end user of a product of my choice used at my discretion, rightly or wrongly ~ but it works for me.
As a final word on my tyre choice(s) : The Mickey Thompson MTZ tyre that had carcase seperation, was bought to the tyre sellers attention, the tyre seller happens to be in Perth and their expert conclusion after consultation with the manufacturers representative (aparently) was that the tyre was running under inflated over a period of time, I told them they were talking out of their arse, because I had been using the "Smart Tire" electronic monitoring system in all tyres from day one of the MTZ's going into the rims, the "Smart Tire" units were an internal sensor, with a hard wired in cab display and they were accurate to the point of annoyance.
The silence was deafening ~ but I could hear the bugger breathing.
Sadly the "Smart Tire" system seems to be off the market now.
I now use the "Tyredog" TDX2200A-X system, the sensors are external, so I can use them on either of the sets of tryes that I use at the time.
Bridgestone Desert Dueler A/T 694 on road.
BF Goodrich MT/KM2's off road
Mickey Thompson MTZ x 3, on the trailer used for the tip run "I don't trust them" for anything else.
Cheers ;0)
FollowupID: 671936
Follow Up By: Mick O - Wednesday, Feb 03, 2010 at 16:57
Deano,
you're not Thrifty out at Wedgefield are you?
Mick
FollowupID: 671959
Follow Up By: DEANO WA - Sunday, Feb 07, 2010 at 21:23
no mate, McLaren
FollowupID: 672663
no mate, McLaren
FollowupID: 672664
Follow Up By: DEANO WA - Sunday, Feb 07, 2010 at 21:24
no mate, McLaren
FollowupID: 672665
Follow Up By: fisho64 - Sunday, Feb 07, 2010 at 21:58
you kind of lost me a little with the curing thing Joe.
I understand they are in the mold for only an hour or so but do they stop curing after they come out and then start again when they are in your shed? How do you get them to start curing again?
FollowupID: 672671
FollowupID: 672672
Reply By: Member - Tony (ACT) - Wednesday, Feb 03, 2010 at 07:54
having travelled that part of WA towinng our camper, a lot of it north & east of Newman, on BFG MT and now Geolander AT.s, the AT.s are the only tyre I have never had a puncture in (apart from a tec screw in Port Headland, and that was on the camper running BFG MT)
There has been a change to the pattern on the Geolanders, but still a very good tyre.
AnswerID: 402417
Reply By: bockstar1 - Wednesday, Feb 03, 2010 at 09:05
BFG ATs for me.
AnswerID: 402425
Follow Up By: Dave(NSW) - Wednesday, Feb 03, 2010 at 09:44
They have problems too.
GU RULES!!
FollowupID: 671898
Reply By: Member -Tukka (WA) - Wednesday, Feb 03, 2010 at 09:59
Bridgestone dueller AT's all the way mate!!
AnswerID: 402432
Reply By: Member - Fourplayfull - Wednesday, Feb 03, 2010 at 11:53
A large amount of tyres are destroyed when they are run to fail after only getting a small puncture causing a slow leak. If it is not noticed then the tyre is blamed.
The best accessory I have fitted is a reliable tyre monitor with audible & visual alarm for tyre pressure variation & temperature. Purchase price is soon recouped in the number of tyres saved plus if you have a slow leak it can be monitored & pumped up as reqired during the day's travel.
Cheers John
AnswerID: 402443
Reply By: Nik & Dee - Wednesday, Feb 03, 2010 at 12:32
I recently bought a set of Yokohama Geolander AT-S. I got them off family who own a tyre dealership and they reckon they are the way to go, comparable to the Duelers. I have heard nothing but good things about them from people who have run them for years. Many up in the Kimberly.
There is a deal running with Yoko that they will replace your tyres if you get a blow out, puncutre or staked sidewall within the first 25% so it's like insurance. You might have to shop around to check the details of that though.
Cheers.
nik
AnswerID: 402447
Follow Up By: fisho64 - Sunday, Feb 07, 2010 at 22:01
"There is a deal running with Yoko that they will replace your tyres if you get a blow out, puncutre or staked sidewall "
please tell me its not like that Cooper load of bollocks of "only if you live in a capital city"
FollowupID: 672673
Reply By: Yadaki - Wednesday, Feb 03, 2010 at 16:54
Bridgestone Desert Dueller, 694 pattern which is a 10 ply rating, not the 693 pattern.
AnswerID: 402468
Follow Up By: Yadaki - Wednesday, Feb 03, 2010 at 16:59
I do have Yokohama Geolander AT-S on the 100 series TD [won at a rodeo Raffle, nice] they are going well.
FollowupID: 671960
