The two stroke oil i am using in my 12ht motor
Submitted: Wednesday, Feb 03, 2010 at 20:19
Member - William H (WA)
Evening All.
I have started two use this two stroke oil in the 12HT motor,as it's one of the older engine's from Toyota and the
fuel company's have lowered the sulphur content in the
fuel, since i was reading the thread..75509, about oil in the
fuel, i decided to try it out and the old motor is quieter and has a lot more response since the 300mls of oil was added to the 80 litre's in the
tank, the cost of the oil was $9:99 for the litre and should get three and a half tanks out of it.........so will see how she goes and will get back to you all.Image Could Not Be Found
Cheers for now...Williamh...Bunbury...WA.
Reply By: oldpop - Wednesday, Feb 03, 2010 at 20:51
Redeer
Would you use it in D4D Hilux
Oldpop
402507
Follow Up By: The Boss - Thursday, Feb 04, 2010 at 00:37
I personally wouldnt. Not with any common rail i was told. could be wrong though.
672030
Reply By: Member - Serendipity(WA) - Wednesday, Feb 03, 2010 at 23:11
Hi William
By chance that is the same two stroke oil I am using in my new V8 turbo diesel landcruiser running the common rail system. Same as you it is quieter and more responsive.
It was a big decision to add two stroke oil to a new landcruiser ute but after lots of research and reading lots of other forums and consulting diesel mechanics I came tot he conclusion - it can't hurt and may do some good.
Even toyota state they only support up to a 5% mix in the diesel. Adding 200:1 is only about a 2% mix
well within the toyota specs.
David
402550
Follow Up By: Lex M (Brisbane) - Wednesday, Feb 03, 2010 at 23:16
"Adding 200:1 is only about a 2% mix
well within the toyota specs. "
I believe 200:1 is a one half percent mix.
May I ask where you got these Toyota specs from.
672015
Follow Up By: Member - Serendipity(WA) - Thursday, Feb 04, 2010 at 00:24
Quite correct. My neck top calculations are not that quick anymore.
I was down at toyota and picked up a pamphlet detailing this toyota spec while I was waiting to pick up my car.
David
672024
Follow Up By: The Boss - Thursday, Feb 04, 2010 at 00:36
Are you positive about that. I was told never to add any additives to the new common rails
fuel system. A 5% bio diesel mix is ok, but not too sur about oil. Was strongly warned to stay away from adding anything to the system.
672029
Follow Up By: Member - Wamuranman - Thursday, Feb 04, 2010 at 08:15
Hi Serendipity,
How long have you been using the oil mix in your V8 diesel?
When you say its more responsive - can you quantify that in any way?
Also do you put it in every
tank full - or for example every second fill?
Thanks for info,
672048
Reply By: Bushtrek - Thursday, Feb 04, 2010 at 10:33
William,
I would not use this particular product in a diesel engine, however I do recommend adding some lubricant to distillate.
The product you are using is fine for low output two stroke engines which happen to have a much higher combustion temperature than your engine but with your relatively colder combustion temps you are better using an "ashless" two stroke lubricant.
Two stroke outboard oil is "ashless" (ie less than 0.01% mass Sulphated Ash) and therefore reduces the chance of deposit build up in the combustion chamber and exhaust train.
Penrite make a Marine Outboard oil which should be a suitable alternative.
Have you also tried Flashlube...........it is purpose built for what you are doing.
402604
Follow Up By: The Boss - Thursday, Feb 04, 2010 at 13:41
Is sulphated ash the same as the sulphur people talk of in diesel, ie. Low sulphur Diesel and stuff?
672095
Follow Up By: Member - Christopher P (NSW) - Thursday, Feb 04, 2010 at 15:00
I put the two stroke
water cooled outboard oil from penrite, same price for the litre and within 5 fims of putting in the oil About 300mls hilus was running quieter, will be puttting in some more next
tank just to make sure.
672112
Follow Up By: Bushtrek - Thursday, Feb 04, 2010 at 16:05
Sulphated Ash and Sulphur are two very different things.
Sulphur is present in mineral oil and its derived products (eg Distillate) as both organically derived material bound up in mainly ring structured molecules, also as inorganically derived Sulphur both as free Sulphur and sulphides of metallic contaminants. About 0.5% of Crude Oil is Sulphur and its derivates.
Sulphated Ash is a measure of the ash depositing tendency of an oil and indicates the residue on ignition of the oil/
fuel mixture.
The higher the Sulphated Ash, the higher the residue left in the combustion chamber and exhaust train.
672124
Reply By: trainslux - Thursday, Feb 04, 2010 at 18:06
Dont use the synthetic stuff, its the mineral oil you want.
Other forums also have pages and pages on this, and it works
at 200:1 and being designed to burn, will help lubricate your pump and injectors without causing issues with overly high combustion temps.
Even tho the current diesel is low sulpuhur, they have to add lubricants to it to bring it to a minimum lubricity level, so low sulphur is not lower in lubricating properties.
However using 2 stroke mineral oil can only help.
Trains
402669
Reply By: Member - barry F (NSW) - Thursday, Feb 04, 2010 at 19:28
I guess iam just curious As to why you would want to add anything to the
fuel in a reasonably current model CRD. I would have thought that the people who designed the system ( CRD) would have been aware of the current chemical content of today's
fuel & its suitability for the system? Not so?
This suggestion of adding 2 Stroke oil to Diesel was on the
Forum a few days ago & I was at first interested but then I spoke to our local Mazda Service Manager & he simply said "no way" if you are interested in looking after your motor & he suggested that such matters a better left to design engineers.
Think I will stick with his advise!! Anyway, I like the sound of the rattle of a diesel, tells me she is ready to grunt.
402682
Follow Up By: Madfisher - Thursday, Feb 04, 2010 at 21:24
Barry I think you will find it was MB that was doing research into using 2 stroke as they consider our diesel to not be up to scratch.
All dealers will say this to cover their backsides, but at .5% would be totally undetatable
Cheers Pete
672185
Follow Up By: Geoff (Newcastle, NSW) - Thursday, Feb 04, 2010 at 22:05
Barry,
The idea of using 2-Stroke oil in a diesel engine is to replace the
fuel system lubrication the move to Ultra Low Sulphur diesel removed.
Very late model diesels, say in the last two years of world production have been designed to handle the loss of lubrication from the Ultra Low Sulphur
fuel. Engines built for Low Sulphur or shall we say "Standard" Sulphur aren't designed for the loss of Sulphur as a
fuel system lubricant.
It's really the old unleaded versus leaded petrol argument revisited. The lead lubricated the valves, valve guides and valve seats. The loss of lead meant older engines needed for their normal expected life an upper cylinder lubricant such as FlashLube.
The end user expectations of any motor vehicle are somewhat opposed to the expectations of the modern manufacturer. We expect to pay a low price for a vehicle with infinite life whilst the manufacturer expects to pay the lowest price for a vehicle ideally (for the manufacturer) requiring replacement at the end of the warranty period.
For us the end user anything that prolongs the life and maintenance period of expensive
fuel pumps has to be a good thing.
Geoff
| Geoff,
672203
Follow Up By: Member - Serendipity(WA) - Thursday, Feb 04, 2010 at 23:13
Geoff
I doubt that even the very late model diesels in Australia would be designed to handle ultra low sulphur diesel. ULSD was only introduced in Europe in 2006 and Australia only lowered their sulphur to 10ppm in 2009.
The development of the V8 engine I have would have been up to 10 years ago with prototype production at a guess probably in 2005. The first models were released about March 2007.
Could the designers really have catered for this change in diesel
fuel. And if they have how
well will it work.
The whole thread from the Freelander site started from someone who had inside knowledge into what Mercedes Benz was doing in their research into designing engines to cope with ULSD. Their most appropriate solution they came up with was to add 2 stroke oil. This was only 3 years ago.
From what I read on the Freelander
forum.
David
672227
