why do my trailer wheels make such a squeaking / grinding / rubbing noise
Submitted: Sunday, Feb 07, 2010 at 17:43
ThreadID: 75855 Views:15323 Replies:5 FollowUps:0
Hi everyone,
Ok so it's brand new, only done 500km's on shake down long weekend. Driving back up the drive going slow with windows down we heard the wheels making a squeaking sound. Thought it was dust from the gravel roads so power hosed it all out. Jacked the wheels up to spin them and still rubbing noise, same on both sides. No electrics connected.
Dexter electronic drum brakes.
Any idea folks?
Reply By: DesF - Sunday, Feb 07, 2010 at 18:02
Hi , The magnets rub on the drums all the time on my Jayco, I dont hear them going along but when you spin them by hand, mates vans do it also,
Cheers Des.
AnswerID: 403129
Reply By: ken triton - Sunday, Feb 07, 2010 at 18:02
I think you will find the noise you can hear is the magnets rubbing on the face of the drum. The magnets have a spring behind them, this spring keeps slight pressure on the magnets that keep them in contact with the surface on the face of the drum. When you actuate the brakes on the vehicle with the controller send a electrical current to the magnets which once energized actuated a lever which in turn actuates the the brake shoes. So to cut a long story short the magnets need to be in contact with the drum face so they can work. Over a period of time the magnets do wear out and will need to be replaced and eventually the drums will need to be replaced as the magnet surface becomes very rough and doues not allow the magnets to work efficiently. Hope this helps
Ken
AnswerID: 403130
Reply By: Rossco 09 - Monday, Feb 08, 2010 at 08:35
I'm not that mechanically minded (don't you just love a disclaimer) but, after a drive check to see if the rims/drums are smoking hot. I'm guessing they are going to be warm to hot normally however, you want to make sure the sound isn't anything causing the wheels to overheat. I've lost count of the number of times I've seen a trailer ditched on the side of the road with a wheel broken off the axle.
AnswerID: 403217
Reply By: Member - Vic S (VIC) - Monday, Feb 08, 2010 at 09:54
As most of the replys have said the rubbing is normal,you should also find that after a few more hundred kms it should improve as the irregularities on the drum and magnets will match each other.
Vic
AnswerID: 403227
Reply By: brushmarx - Monday, Feb 08, 2010 at 14:02
The previous responses seem to indicate brake noise, if the sound is a rubbing noise.
I put bearing buddy (or similar ) bearings and seals on a box trailer, and the rubber seals rub on the hub making a squeak noise, and have done so for a few months.
May be nothing like yours, but it may depend on the definition of squeal and squeak.
AnswerID: 403260
