Selecting low range in 2009 Prado
Submitted: Monday, Feb 15, 2010 at 15:08
ThreadID: 76044 Views:6956 Replies:4 FollowUps:2
G'day all,
A question for Prado owners ...
Is it true that you can only engage low range after stopping and selecting park, in this year model? If I stop, foot on the brake, select neutral, it is impossible to select low range without the gears grinding, yet if I'm in park and select low range, it selects smoothly with no grinding. In the manual it states that low range can be selected when in neutral, and that's the way it worked on my 03 model. I've never heard of this before on the Prados.
Has anyone had this same experience with the 09 model? Is the service guy correct, or is he pulling my chain and I need to explain the meaning of life to him.
Regards,
Bazza.
Reply By: DesF - Monday, Feb 15, 2010 at 15:19
Hi Not sure on prado's , but my mates Pathfinder is the same, we were halfway up a hill and he went to select low range and no go, but after putting it in park with the handbrake on to check it out , it went straight in ??
No mention of this in his handbook,
maybe the same with the Prado,
Cheers Des.
AnswerID: 404317
Reply By: Member - Tour Boy ( Bundy QLD) - Monday, Feb 15, 2010 at 16:10
My 105s were the same had to be in park (4 speed auto)
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 404322
Reply By: Member - Barnesy - Monday, Feb 15, 2010 at 18:25
If the service guy says it needs to be in park, and you can't get it into low range if it isn't in park. Well it seems the service guy is correct?
AnswerID: 404334
Reply By: RobAck - Monday, Feb 15, 2010 at 18:39
I am assuming you are talking about the 120 Prado. Not the new 150. I will reply for both vehicles
120 Prado
The information is incorrect. You can select LR in neutral or park but in an auto preferably stopped. If you try selecting LR in neutral and still moving you have a good chance of breaking something. A good 4Wdriver will select the correct gear and range before ascending or descending something
150 Prado
With the move to electronic selection of LR and the use of a rotary selector along the same lines as the LC200 then you must be stopped and in neutral
RobA
AnswerID: 404336
Follow Up By: Bazza - Tuesday, Feb 16, 2010 at 09:49
Thanks RobA,
Yes it is the 120. After further investigation, it seems that this issue is not uncommon. Some guys are unable to shift to LR in neutral, others can. All can shift from park. In all situations, the vehicle is stopped when this is tried.
I think there may be a problem with the mapping of the auto transmission. Mine increases revs when in neutral, not in park. This would cause a meshing problem. I will take it up with Toyota, as the service tech originally told me that it was a safety procedure, and it had to be in park.
Thanks again.
Regards,
Bazza
FollowupID: 674086
Follow Up By: Bazza - Wednesday, Feb 17, 2010 at 10:41
G'day all,
After further investigation, I have determined that temperature has something to do with this. It's either oil or component temperature, or a combination of both, that causes this to happen. When the 120's at normal operating temperature ( after driving it home from work ) it will change to LR from both park or neutral, with no effort and no gear grinding, but it's left to go cold, gear grinding from neutral comes back and only changing to LR from park is possible.
Still very strange, as this never happened in the 03 model. I will be speaking to Toyota about it and will post the outcome.
Regards,
Bazza.
FollowupID: 674214
