Land Cruiser aircon
Submitted: Sunday, Feb 28, 2010 at 23:12
ThreadID: 76434 Views:16052 Replies:11 FollowUps:17
Howdy all, hope all is well
Not a happy chappy at the moment, getting the tray back all ready for my trip to Broome to meet up with an eo member to do our trip to perth for ac/dc and all has come to a warm halt.
Jumped in her to drive to the local club to grab a few bevies for the night and the aircon was blowing hot!! :( I looked under the bonnet to find the belt spinning but the compressor not spinning at all.
I think its the compressor seized but not really sure so maybe someone can fill me in?. Im leaving Tuesday and tomorrow being a public holiday im hoping i can get some info on where to start
Reply By: Top Ender - Sunday, Feb 28, 2010 at 23:19
Hey Tukka
Try the fuse or a loose wire to start, from my experience if the compressor is stuffed it is usually seized.
AnswerID: 406596
Reply By: Member - Stuart P (WA) - Sunday, Feb 28, 2010 at 23:54
more likely to be low on gas,
AnswerID: 406600
Follow Up By: Member -Tukka (WA) - Monday, Mar 01, 2010 at 00:06
If it was low on gas the compressor would still be spinning but, its not spinning at all
FollowupID: 676365
Follow Up By: pop2jocem - Monday, Mar 01, 2010 at 02:06
Try running 12v directly to the compressor clutch, if it starts to spin the compressor you have an electrical problem. If the drive belt starts to slip and smoke the compressor is seized
Cheers Pop
FollowupID: 676374
Follow Up By: Member - Stuart P (WA) - Monday, Mar 01, 2010 at 17:57
no it wouldnt the hi lo pressure switch would cut the circuit to the compressor
FollowupID: 676522
Reply By: get outmore - Monday, Mar 01, 2010 at 02:13
start real simple
if the aircon is on then check the wire to the compressor - its a bit exposed and easily pulled out
AnswerID: 406604
Reply By: The Boss - Monday, Mar 01, 2010 at 02:45
Check for a loose nut behind the steering wheel. Thats probably where the problem lies.
There forecasting the temp to be 32 degrees down to Halls creek, 35 in Fitzroy and 36 here. with a 40% chance of rain, not bad.
AnswerID: 406605
Follow Up By: Member - The Bushwhackers -NSW - Monday, Mar 01, 2010 at 08:22
If he gets the a/c working off the dc battery, he will have ac/dc in the car, saves driving to Perth
Have fun at the concert, I went in 1997, or 1996 not sure, but it was great
Cheers, Dave
FollowupID: 676389
Follow Up By: Member -Tukka (WA) - Monday, Mar 01, 2010 at 12:57
That forcast aint so bad then i spose hey, doing the night rider leaving about 2.30 3.00 am so it shouldnt be too bad.
See you when i get there Boss
FollowupID: 676431
Reply By: Member - Toyocrusa (NSW) - Monday, Mar 01, 2010 at 06:31
G'day Tukka. You should be able to turn the front of the compressor by hand if it is not siezed. (The flat bit in front of the pulley) If this is not turning with engine running and air on then it is either and electrical problem or low on gas. The system has a low pressure switch to stop it engageing when gas is low. If you can find this switch check for power and if there is bridge it to check compressor operation. If this works then possibly you have some sort of gas leak. Regards, Bob.
AnswerID: 406609
Follow Up By: Member -Tukka (WA) - Monday, Mar 01, 2010 at 12:59
Cheers Bob thats the sort of info i was looking for, i can have a look but im not much of a mechanic and im leaving tomorrow and today being a PH i dont like my chances of getting it fixed.
FollowupID: 676433
Reply By: richietheb - Monday, Mar 01, 2010 at 06:57
Wouldn't it be logical that when there is no power to the clutch it'd be disengaged from the compressor......that is...when you want AC you turn on the AC and the clutch connects the pulley to the compressor...Your compressor or compressor clutch is buggered I reckon...I'm def no mechanic..but that makes sense to me.........Let us know
AnswerID: 406611
Reply By: Mikee5 (Logan QLD) - Monday, Mar 01, 2010 at 09:15
If the a/c is low on gas, there is a cut out switch that automatically disables the compressor to prevent damage to the system. Get a pro to check it out.
AnswerID: 406622
Reply By: Member - Lotzi (QLD) - Monday, Mar 01, 2010 at 10:06
Yo Tukka
Hope you get the a/c fixed.
Went to the ACDC concert in Brizvegas on Sat night, with about 10 fellow oxygen assisted, deaf ol fts, top shelf ol mate.
Although deaf, ears still ringing, I think volume was set at about 27 . . grnn, top quality night, worth every cent, couple of rums or 3 prior to going in helped.
Oh, did I say, cant help with the A/C . . .
AnswerID: 406629
Follow Up By: Member -Tukka (WA) - Monday, Mar 01, 2010 at 12:56
Lol cheers Lotzi Aircon is a need up in the Kimberleys this time of year but my needs are to get to perth any way i can to see these guys.
FollowupID: 676430
Reply By: Wherehegon - Monday, Mar 01, 2010 at 13:09
Hi Tukka, my guess is its low on gas, Toyota aircon compressors are a great compressor and dont really fault that much, unless extremely old then they start to seize up. Easy way to check for loss of gas, push a/c button on dash or in your case for memory turn the a/c dial behind the fan switch, turn to max temp clockwise (cold) as you would know, turn on fan then obviously the motor should idle up and the compressor cut in. Is it idling higher then normal when you switch the air on ?? Behind the grill (for memory) will be a low and high pressure switch will be in the middle of a pipe. pull the wiring loom off the switch then grab a bit of electrical wire, strip either end and stick either end of the wire into the two terminals (female) the plug you pulled off, this is bypassing the low and high pressure switch which they put on the vehicle 1, so that if the system gets high pressure (normally from overgasing) it will shut it down so it doesnt blow any seals 2, it also stops the system from working if low on gas as the system has lubricating oil in it with the gas and the gas helps move the oil around the whole system to keep everything lubed up. If the clutch engages on the front of the compressor (you will hear a click) then it is low on gas, will need a recharge usually around the $90 unless you want to put a new receiver dryer filter in it as well (would recomend if it hasnt been changed in a while) If the compressor does cut in DONT leave the wire in there you will stuff the compressor put the plug back on the switch and get it gassed up. Other then that check the relays under the bonnet and possible fuse but I doubt it, Let us know the problem. If it was blowing hot air and the compressor was working then Id say either heater tap of TX valve but this isnt your issue but my moneys on the low gas. The rubber pipes are pourous and will allow a small amount of gas to escape over the years resulting in compressor not cutting in due to the low and high pressure switch doing its job. Regards Steve
AnswerID: 406660
Follow Up By: Member -Tukka (WA) - Monday, Mar 01, 2010 at 13:25
Thanks alot for you info thats great. just been looking into it a little more. when hitting the a/c button the comprerssor isnt kicking in so that must mean an elec problem does it? i checked the fuse under the dash and it was ok, i checked the plugs on the high and low cut out switch because the wires stuffed up there once before but had an auto sparkie sort it out
So maybe a relay or something like that?
So the compressor shouldnt cut in when low on gas correct?
FollowupID: 676438
Follow Up By: Top Ender - Monday, Mar 01, 2010 at 13:32
Was the A/C cold before you stopped ?? if so I doubt it is a gas issue.
Try to get a test light and see if there is power to the plug that connects to the compressor.
Look for a faulty relay and check fuses under the bonnet.
These are easy enough to try by yourself.
FollowupID: 676441
Follow Up By: Member -Tukka (WA) - Monday, Mar 01, 2010 at 13:36
I hadnt used it for about 4 days but decided to use it because the young bloke was coming for a spin with me and it just blew hot from the start. it was cold last time i used it though
FollowupID: 676443
Follow Up By: Wherehegon - Monday, Mar 01, 2010 at 14:07
""when hitting the a/c button the comprerssor isnt kicking in so that must mean an elec problem does it? "" ............
no,
if its low on gas it wont kick in at all, BUT if you put a bridging wire into the 2 female slots on the high and low pressure switch (the plastic plug you pull off NOT the 2 male connections on the pipe work) then turn on your air as normal and it still doesnt kick the compressor in then its an electrical issue, as I described in previous reply this is only testing for low gas, and if the system is low then by doing as above the compressor should kick in but you need to have your fan and a/c switch on the dash turned on and bridging wire in place. You said it was cold last time you used it, but was this on a 40d day,25d or muggy weather ?? Some times it will still come through feeling cold but at the same time has been losing gas over a period of time so you dont notice it not as cold as say when it is full of gas. For example my prado was cycling on and off at around 5 to 8d, meaning coming out the vents at 5, thermostat would cut it off, it would climb to 7 when the compressor would cut in by then it was sitting on 8 then would start to drop back down again towards 5, knowing this is warmer then normal for the prado, the sight glass also had a tad of white flowing through it when cycling, I topped the system up with only 250g of gas it now runs at 3 and 5, doesnt sound like much but on a 40d day it makes a big difference. Maybe you just didnt realize it wasnt as cold as is could be ?? Regards Steve
FollowupID: 676451
Follow Up By: Member -Tukka (WA) - Monday, Mar 01, 2010 at 14:12
ok i get ya
It hasnt been as cold as it should be for a while now, the auto sparkie did tell me it would probably need gas soon. It was the same temp coming out last time i used it and yes it would of been a stinking hot day. Its a pain in the back side thats for sure..
Ill trying the bridging idea like you say and see how it goes
FollowupID: 676455
Follow Up By: Wherehegon - Monday, Mar 01, 2010 at 14:23
Just reread your post, you say .........I looked under the bonnet to find the belt spinning but the compressor not spinning at all"" at the front of the compressor is the clutch (in front of belt like a round disc) was this spinning or not ?? The pulley that the belt is around will spin all the time wether clutch is engaged or not, the clutch part of the pulley the bit in front of belt will lock engage when air is working pulling itsefl back intowards the pulley, if clutch is not engaging this will be sitting still BUT the pulley the belt is around WILL BE spinning. If the compressor is stuffed when the clutch engages (locks into the pulley) the belt would be screaming its head off BUT unless you test for low gas first you wont be able to tell if compressor is stuffed or not. Regards Steve
FollowupID: 676462
Follow Up By: Member -Tukka (WA) - Monday, Mar 01, 2010 at 14:27
No the round disk is not spinning, just the pulley around the compressor is
FollowupID: 676467
Follow Up By: Wherehegon - Monday, Mar 01, 2010 at 15:15
Thats a good sign, still dont know 100% its not siezed unless you do the bridging with the wire, if the compressor cuts in and no squeling from the belt then problem is low gas, if the compressor doesnt cut in after bridgong it and having all switches turned on inside then its electrical. Doesnt sound like genuine air to me ?? I thought for sure the cruisers like yours and the troopys had the dial behind the fan switch and was a dial that turned clockwise depending on how cold you wanted it not a button ?? Been a while since I fitted them back in 1988 to 93 when I worked for Toyota. Regards Steve Let us know how you go after bridging it.......
FollowupID: 676490
Reply By: Member - Geoff H (QLD) - Monday, Mar 01, 2010 at 17:19
My 80 series started blowing hot air and it turned out to be the little alloy cannister situated just behind the front bumber on the left hand side.
Geoff
AnswerID: 406717
Follow Up By: Wherehegon - Monday, Mar 01, 2010 at 20:45
Hi Geoff, thats called a receiver/dryer, its a filter and will absorb moisture over the years if not replaced. They say to replace them every 2 years but I dont touch them for generally 5 when your aircon will roughly possibly need a regas, especially genuine Toyota air, if fitted correctly from new give very little trouble, wifes car we bought new and is comin up for 4 years old this year, havnt touched the aircon and dont intend to till it gets low on gas, still freezing cold, sometimes by continually undoing pipes and things you end up with problems then become expensive to repair. Regards Steve
FollowupID: 676568
Reply By: Wherehegon - Monday, Mar 01, 2010 at 20:46
How did you go Tukka, any luck yet.........Regards Steve
AnswerID: 406764
Follow Up By: The Boss - Tuesday, Mar 02, 2010 at 04:47
Nah he had no luck, i think he did everything you told him to and he is pretty sure its the actual compressor, though it is ok, low on gas i think he said. Will soon see, will get the aircon guys here to have a look when we get back from AC/DC.
I remember a while ago, i posted a A/C problem also, to do with my old 2004 Prado. It was blowing hot out passenger side, but cold on drivers side. Was very weird, i asked around for everyones verdict, and thought bugger it the aircon guys can do it. Well, i thought it was just going to be the mixer flap or something, which i was told it would be. $1800 later, it turns out that i somehow had hit something on my travels, and it had punctured the condenser and the radiator. When the system detects a leak or low gas, it only pumps cold air to drivers side. Pretty nifty i thought. Lucky for me only had to pay $400, insurance covered the rest.
FollowupID: 676600
