How do you work out
Submitted: Wednesday, Mar 03, 2010 at 20:40
Jedo_03
the amps pull on a battery when connected to an inverter..??
Say you have a f/c 100Ah batt connected to a 300W invertor connected to a 240v 100W light bulb.
In one hour - how many amps will be pulled from the battery?
How do you calculate this..??
Jedo
Reply By: Member - Boobook - Wednesday, Mar 03, 2010 at 20:59
The load is 100W.
Amps = watts / volts so
Amps - 100/12.8 = 7.8Amps.
Plus add 15% for ineffeciency = 8.5A
So in one Hour you will have used 8.5 Amp Hours.
Im other words get LED or Flouros, you will have only used about 1 - 1.5 Amp hours for similar light.
407161
Reply By: Member - joc45 (WA) - Wednesday, Mar 03, 2010 at 21:05
For a fully charged battery, we'll assume 13v.
The capacity of the inverter (300w) doesn't really come into the calculation, only the load.
If the inverter was 100% efficient in conversion, then the input watts would be the same as the output watts.
Therefore, with Amps=Watts/Volts,
Amps = 100/13
= 7.79A
so if you're running it for an hour, you'll have used 7.79 Amp-Hours.
But the real inverter conversion efficiency is 80-90%, so let's assume 80%; the draw will be
7.79/0.8 = 9.6 amps.
Also, the inverter has a fixed power consumption regardless of the throughput (when you have no output load, there will be some current draw from the battery), so max efficiency is usually at max power; it will be a bit less efficient at small load current.
Not sure why you'd run a 100w bulb from an inverter tho :-)
Gerry
407162
Follow Up By: Maîneÿ . . .- Thursday, Mar 04, 2010 at 09:30
Gerry,
Yes, the inverter "capacity" does come into the equasion :)
Maîneÿ . . .
677072
Reply By: Member - Phil G (SA) - Wednesday, Mar 03, 2010 at 21:23
As above, but best way is to measure it with an ammeter.
Out of interest, my 300Watt inverter pulls 110 milliamps when idle (connected with no load).
407169
Reply By: Member - Cantiva Clay (NSW) - Wednesday, Mar 03, 2010 at 23:43
Agree with Phil the only real check is with an ammeter and voltmeter.
407190
Follow Up By: Member - Cantiva Clay (NSW) - Thursday, Mar 04, 2010 at 00:07
I should be a bit more helpful, Jaycar have a range of meters, you can pick up a basic multimeter for $10 and a very usable one for $30, interestingly there is not much improvement in accuracy until you buy the $400 job! (The $30 is fine for auto use) if measuring current more than 10a you will really need one of their shunts though.
677048
Reply By: Geoff (Newcastle, NSW) - Thursday, Mar 04, 2010 at 00:20
One of
these will answer all your automotive questions exactly!
No if's, no but's, no maybe's.
All you need is someone to give some hints on their use (provided you don't know yourself)
Otherwise on the calculation front others have supplied some great information.
| Geoff,
407194
Follow Up By: Member - Boobook - Thursday, Mar 04, 2010 at 06:54
You gotta put it in context tough.
1 x 100w light bulb 85 cents
1 x cheap inverter $$50.00
1 X multimeter $140.00
You could buy a lot of 12v flouro's or LED's that would use less power for that.
677058
Reply By: B1B2 - Thursday, Mar 04, 2010 at 07:22
G'day Jedo,
I am sure you are not planning on running a 100w light, it is the calculation of power consumption you are after.
I use a clamp dc amp tester, I think Dick Smith or Jcar had them for around $100, they used to be closer to $300.
It has a range of 400A dc. and you put the clamp around one wire.
This is useful for checking say a laptop computer power consumption, as it is variable depending how flat the batteries are. The dell laptop I use pulls 12A dc when the battery is low. This is handy to know when your inverter has a 10A fuse and you dont expect it to use that amount.
It has a lot more applications on your vehicle, you can check the charging rate of your alternator without disconnecting anything.
Bill
407204
Follow Up By: Member - joc45 (WA) - Thursday, Mar 04, 2010 at 13:08
Just make sure you get a DC/AC clamp ammeter. The cheap clamp meters only read AC, and will be of no use for your purpose.
677098
Reply By: Jedo_03 - Friday, Mar 05, 2010 at 18:43
Thanks all
So if I'm running 3 x 100W light bulbs I just multiply by 3...
It was the calculation I was after.
Jedo
407434
