Stuck Reece Hitch
Submitted: Monday, Mar 08, 2010 at 01:04
Member - Si (WA)
My Reece hitch is stuck tight. We have tried WD40 from all angles, hitting it from behind, leaving the camper trailer attached with the breaks on and
wheels chocked but it is still not wanting to budge.
Anyone have any ideas. Oh and before anyone comments... yes, I have removed the pin ;-)
Reply By: Member - Ed C (QLD) - Monday, Mar 08, 2010 at 01:53
Been there, done that...............
It's the grit & bleep & moisture that gets in there that siezes 'em up;-)
When you say you've tried hitting it from behind, how hard did you hit it, and with what ??
Depending on how badly it's stuck, you'll need to give it a decent wallop, and with a decent 'knockometer' ;-)
When
mine did the same, I positioned a lump of 4x4 hardwood (square end, resting on the ground) against the tongue and gave it a good whack with a 10lb sledge hammer.. Make sure your aim is good;-))
You may also need to give it a whack from each side as
well, to loosen it..
As far as penetrating fluids go, I use (and recommend) good ol' Penetrene...
I now make a point of removing the hitch on a regular basis, thoroughly cleaning both male & female sections, and giving all contact surfaces a good spray with Molybond 122L dry lube..
I have also fitted an end cap to the open (front) end of the female section in an attempt to minimise the entry of dust / mud.. (sor far, so good;-)
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
407764
Follow Up By: Member - Si (WA) - Monday, Mar 08, 2010 at 02:25
Tried a hammer and balsa. It is a bit hard to get a clean angle of attack due the
fuel tank location.
Having said this, I changed my steering damper last week and was surprised at how hard that had to be hit to come lose.
I have tried hitting it from every angle known to man. I might give the fluid a couple of days to penetrate and give it another go.
Might just be a case of needing a bigger hammer
677672
Reply By: Member - Pat (VIC) - Monday, Mar 08, 2010 at 02:00
Hi Si have you noticed a small bolt sticking out of the bottom corner of your hitch. Some have one to take up the movement and can make it hard to pull it out, not sure if yours has it. Or maybe the head of the bolt has broke off and the rest is still in there.
Just a thought.
407765
Follow Up By: Member - Doug T (NT) - Monday, Mar 08, 2010 at 02:07
Pat.
Yes the one the station Triton here has a bolt underneath too, we couldn't get it free for a snatch strap pull yesterday.
677670
Follow Up By: Member - Si (WA) - Monday, Mar 08, 2010 at 02:19
It is a Nissan one and I have looked to see if I missed something, but it doesn't look like it.
677671
Follow Up By: Alloy c/t - Monday, Mar 08, 2010 at 09:23
Some of the Nissan towbars actually have a slight taper in the female section of the hitch, ergo when a standard 2" HaymanReece draw bar is inserted it can jam ,, chain to
big tree stump and low 4x4 will pull er out like the dentist to a back molar, LOL.
677690
Reply By: gbc - Monday, Mar 08, 2010 at 06:46
Lump hammer, a drift, some ear plugs (pretty lound under there eh), and a half hour of swinging from both directions is what is needed.
If you come up with an easier way - pls post it up.
I have heard of individuals attaching the unbolted hitch to a tree via a snatch strap and driving off a few times, but the idea just doesn't sit right with me somehow.
407771
Reply By: Member - res.q.guy (Vic.) - Monday, Mar 08, 2010 at 07:21
Hi Si
A mate of
mine chained his to a large tree and drove off slowly in low range 4x4 and came out for him.
Neil
407776
Reply By: Member - Oldbaz. NSW. - Monday, Mar 08, 2010 at 08:27
I dont mean to be flippant but your problem would be welcome over here in the
east...hitch receivers are pinched all the time unless locked on. I have a lockable pin I bought off this site, but believe they are no longer available. No doubt other
solutions exist. Keep on wacking...:)))....oldbaz.
407785
Follow Up By: Wizard1 - Monday, Mar 08, 2010 at 09:19
There is an easy fix to both the problem of theft and the seizing.
Take the it out when you are not using it.
I never drive around with either my WDH, standard tow attachement or recovery hitch unless I am towing something or driving where I need recovery.
When they aree out I regularily spray Lanotech into the reciever and coat the tow attachement iwth fish oil or Lanotach as
677689
Follow Up By: DIO - Monday, Mar 08, 2010 at 10:05
You don't need to buy a locking pin, just put a padlock through the hole at the end of the pin - the one that the retaining clip usually goes through.
677697
Follow Up By: Member - Oldbaz. NSW. - Monday, Mar 08, 2010 at 11:21
Removing the hitch will certainly stop theft, but not an "easy fix", easy is leaving
it locked on, always ready in case you need to tow or recover. Not the sort of thing I want to carry around loose in the wagon either. Also prevented any damage to me when a careless hoon couldnt pull up in time & shunted me from
behind. I'll stick to the locking pin...the hole would need drilling out to take a decent padlock & the pin was cheaper than a dustproof lock anyway.....oldbaz.
677710
Reply By: Shaker - Monday, Mar 08, 2010 at 09:14
Sometimes if they protrude from the back of the receiver, the hitch gets stone damaged & burred on the leading edge.
407796
Reply By: Rod - Monday, Mar 08, 2010 at 09:32
My Brother in law had this problem with his patrol. Apparently the OEM Nissan receiver is not designed for Hayman Reese tongues. The Nissan tongue is tapered and the HR is parallel.
407808
Reply By: Member - Graham H (QLD) - Monday, Mar 08, 2010 at 09:35
Was it tight when you put it in.
Nissan hitch receivers have rounded corners inside the square receiver.
If you get it out, get an angle grinder and round off the edges of the tongue till its slightly loose.
This is a
well known problem and easily fixed.
407810
Reply By: Dan - Yal - Monday, Mar 08, 2010 at 10:24
I tried WD40 to free up the linkages in the transfer case. I used lots of spray and lots of brute force but got little result.
Was then told to try Wurths. Sprayed it on , left it for ten minutes and the linkages were like new.
Its obviously a lot better than WD40 for my situation and maybe for yours too.
Was given the spray by a mate so not sure of cost or where to get it, although I was assured it wasn't cheap
Might be worth a try
407819
Reply By: Member Boroma 604 - Monday, Mar 08, 2010 at 10:42
Gooday,
Have you thought of trying a Heat Gun, warming it up and then leave it cool will often break the Freeze. Wouldn't put a flame near it but I have a Heat Gun and it has got me out of trouble on many ocasions.
Borma604
407824
Reply By: nowimnumberone - Monday, Mar 08, 2010 at 11:10
i tried all of the above but couldnt get my hitch out in the end i bought a thin grinding blade and cut through the bottom of the tow bar then rewelded a plate over it. then i ground down the hitch slightly
407834
Reply By: Member - Duncs - Monday, Mar 08, 2010 at 11:28
The other thing that happens is that the edges of the hole that the locking pin goes through burr.
I have
mine out from time to time and have, in addition to the application of liberal amounts of lubricant, ground down the burrs in that area.
As for getting it out.
Years ago I was replacing the shackle bushes on the old MQ. I got out my biggest hammer and lots of heat and hit it as hard as I could. It didn't move. After a couple of hours of sweating and head scratching I gave up and called a mate who is a mechanic. He works on trucks, big boats and earthmoving equipment.
When he pulled up he got out the biggest hammer I have ever seen. I reckon I would have used it to move the car sideways. I really was worried that the hammeer would do damage.
Well he gave it two good whacks and in it went. He did less damage with two big hits than I was doing with my hundreds of little ones.
My father used to quote the "fitters motto."
If at first you don't succeed...buy a bigger hammer.
Duncs
407839
Reply By: nickoff - Monday, Mar 08, 2010 at 12:53
Another idea, used to free taper fits like linkages on steering rods ball joints etc.
Try hitting the reciver housing, from both sides at the same time, with a couple of 4 Lb or better hammers. With taper fits, this "shocks" the tight fit in the taper loose, then try knocking it free.
Agree with the bigger "knockometer". Most people use one that is too light, and tap to softly.
407848
Reply By: ob - Monday, Mar 08, 2010 at 12:58
Can you unbolt the whole tow bar,receiver assembly from the vehicle. If so you can set it up on some blocks of wood or whatever and then as has been said give a good whack or ten from the open end.
Cheers ob
407849
Reply By: Member - Allan B (QLD) - Monday, Mar 08, 2010 at 14:48
Sometimes they aint never gunna come out by human effort!
On my son's Hilux we tried all the above then removed the whole towbar, used an oxy/acetylene heating torch on it and put it in a hydraulic press. No go, didn't budge. So he gave up and left it in. At least it won't get stolen!
In my case on the Troopy, I REALLY wanted to remove it to protect my shins but no way was it going to come out. So I used an angle grinder to cut the tongue through at both ends close to the receiver. Then threaded a hacksaw blade through what was left of the hollow tongue and attached it to the hacksaw frame. After a lot of sawing I cut through the bottom of the tube in two
places about 20mm apart and removed the centre scrap. I then used a small cold-chisel to bend-in the sides enough to free the remains of the tongue. Clearly, I am a persistent bastard! A new piece of 50mm tube welded to the gooseneck completed the job.
407863
Reply By: Member - Tour Boy ( Bundy QLD) - Monday, Mar 08, 2010 at 16:06
I found that if you attach a chain (not snatch strap) to the tongue and the other end to a tree or pole and load the chain up by trying to move the car forward and lock car in gear engine off and handbrake on. This will load the chain up, then get a hammer and hit the sides of the tongue alternately it will usually wiggle out. You may need to re load the chain every now and then.
Dave
407878
Reply By: Member - Timbo - Monday, Mar 08, 2010 at 18:45
I had the same problem a while back - it ended up coming out (slowly) by whacking it from behind on each side alternately.
I put a light film of grease on it after that and never had any further troubles.
407918
Follow Up By: Member - david m2 (SA) - Monday, Mar 08, 2010 at 20:52
find a friend with an oxy and pour the heat in. the expansion will loosen it up . if it;s on a taper tap it on the side .
677844
Reply By: Member - Si (WA) - Monday, Mar 08, 2010 at 22:23
Seems like belting the cr*p out of it is the general consensus. Will try attacking it again in the weekend. Failing that, either an oxy torch or a chain with low range might be the go.
It is not a major problem if I can't get it out but would be handy.
Thanks for the reply's and I will let you know how I get on.
407961
Follow Up By: Member - Graham H (QLD) - Monday, Mar 08, 2010 at 22:29
You might get the surprise of your life using a gas axe next to a fuel tank.
You are gamer than me mate.
677869
Follow Up By: Member - Si (WA) - Monday, Mar 08, 2010 at 23:57
Yeh, had the same thought... would definitely remove the whole assembly before trying that.
677884
Reply By: Geoff (Newcastle, NSW) - Monday, Mar 08, 2010 at 22:35
Just get someone to snatch it out!
Guaranteed to shift it!
| Geoff,
407966
Follow Up By: Member - Si (WA) - Tuesday, Mar 09, 2010 at 00:00
Thought of that but am worried about the problem that could arise of the spring loaded snatch effect. I might just drop to the ground or it could become a lethal projectile. There is just no way of knowing and I don't feel it is worth the risk.
677885
Reply By: Member - Royce- Monday, Mar 08, 2010 at 23:10
This is probably too obvious and already done... but
Have you whacked it as hard as you can from the ball end? Bashing it INTO the towbar might crack it and allow it to come back out.
This works with nuts, bolts and star posts...
407972
Reply By: Dion - Tuesday, Mar 09, 2010 at 11:55
Part of the problem could be with those anti rattle bolts. They hold the hitch receiver in place so it doesn't move, and therefore doesn't rattle.
Because it doesn't move, dust and moisture get in there and 'rust weld' the components together, making it damned hard to remove.
I was initialy critical of Kaymar with my new rear bar for the Rodeo didn't have a anti rattle bolt in it. But now I know that if it's rattling, it's going to come out when I want it to come out.
Interesting slight digression, the collection of receiver hitches kept at the
Pink Roadhouse in Oodna that have fallen out of vehicles in that neck of the woods.
Dion.
408030
