Sunday, Mar 14, 2010 at 14:20
Hi again,
Thought I had this problem licked.
I decided to go the way of the new regulator as I mentioned in my last post - only after that didI decide to put a meter across the solar panels terminals just to make sure of the output volatage. When I did, it read a constant 20.5 volts, not the 36 as mentioned on the back panel. Is this indicative of only half the panel working (diode short) or is "Nomadic Navara" correct in his summation...
"FollowupID: 678169 Submitted: Wednesday, Mar 10, 2010 at 13:29
Nomadic Navara posted:
Ed - I know that, however he is charging a 12 V battery (which is also a little more than 12 V most of the time.) However, a 36 V panel is an unusual size. Smokey said "the regulator the correct one for that voltage and panel." As the regulator does not appear to be an MPPT type things are not adding up. It could
well be the correct voltage panel, someone has confused the 36 cells with it being a 36 V peak power point panel and calculated the current out by dividing 200 by 36.
Smokey - you could clear this up by providing the manufacturer and full model number of the panel."
Details listed on the back of the panel are -
(Tong Lin) PMW 200 PW
Watts = 200
Voltage = (VWP) 36.0 volts
current = 5.56 amps
I opened the connection box at the back and the terminals are covered in a foam like substance. I have started to carefully remove the foam (with plastic tool) and have uncovered so far 3 large diodes. The chap from Esolar suggests to remove all wiring from the panel terminal block and measure the short circuit current and open circuit volts. If I get same voltage, then I have 100 watt unit only. It could also be a diode short - in which case he suggests to remove both diodes and check them and then the panel current and voltage again. When I get all the covering off, I'll send a photo of the terminal block.
I am not overly confident with the above, so would appreciate some direction and ideas.
678721
