pvc water storage pipe
Submitted: Tuesday, Feb 19, 2002 at 01:00
fred orzel
i would like to install a pvc
water storage pipe under my rodeo. i am unsure about the fittings such as breather valve etc.can anyone advise.
Reply By: Mark - Wednesday, Feb 20, 2002 at 01:00
Hey Fred, what do you mean by breather valve? You need a low point in it (like a 90 deg
junction with a ball valve screwed into a screwed cap) to act as an outlet and a high point (like a 90 deg elbow with screwed cap) to use as a fill point. 100mm would be a good size. Visit you local plumbing
shop and let them know what you want. I'm sure they'll help you out.
2159
Reply By: brenton - Tuesday, Feb 26, 2002 at 01:00
gday fred ive used abs pipe 160mm dia it is 10mm thick walled structualy stronger than pvc drill and tap the end to take galv end plates 25mm hose for the filler 6mm plastic tube breather goes up inside the body work
2202
Reply By: brian - Tuesday, Mar 12, 2002 at 01:00
hi fred if you have a trayback, consider a small caravan/camper
water tank. i have placed a 60lt rectangular
tank between the chassis rails quite easily. just a choice
2356
