Tyre Pressure
Submitted: Friday, Mar 19, 2010 at 22:50
ThreadID: 77014 Views:3200 Replies:6 FollowUps:1
I know this probably been over done in many other threads however I would like your advice
I usually run around 40psi on the Highway to help tyre wear and stability
On gravel or rougher roads I will go down to around 28 to 30 psi
On the beach I let them down to 15 to 18psi.
Are these pressures around the mark
Thanks for your advice
Wayne B
Reply By: Lex M (Brisbane) - Friday, Mar 19, 2010 at 22:53
If you want an intelligent answer you probably need to include vehicle type and load, tyre brand and size etc.
AnswerID: 409546
Follow Up By: Member - Wayne B (NSW) - Friday, Mar 19, 2010 at 23:11
Sorry
HJ80 Diesel 15 by 7 rims (Standard) with FBGoodrich A/T 31/10/50 tyres
Moderate loads fro camping only nothing real heavy. Although I will be towing a Camper Trailer which is around 650kg
Wayne
FollowupID: 679478
Reply By: Member - Bucky - Saturday, Mar 20, 2010 at 04:51
Wayne
Rougher roads you can go down to 22 psi...
Everything else is good
Cheres
Bucky
AnswerID: 409564
Reply By: molzy - Saturday, Mar 20, 2010 at 09:13
I use 28 on dirt, 22 on slower rough/rocky roads( max speed 60klms/hr) and 18 on beach. never had a flat touch wood except the time i was to lazy to reduce pressures........mmm.
AnswerID: 409584
Reply By: Wayne (NSW) - Saturday, Mar 20, 2010 at 09:39
Wayne,
The tyre pressures sound OK. One thing to remember is the lower the tyre pressure the slower the vehicle speed.
I let my front tyres down 4psi lower than the back, just because of the Troopie can be heavy in the back.
I would assume that when adjusting tyre pressure they are cold.
The other thing that I have come across is the accuracy of tyre pressure gauges.
I am not saying that the two tyre pressure gauges that I have are correct but the difference between mine and some others that I have seen is quite a lot.
Wayne
AnswerID: 409592
Reply By: Off-track - Saturday, Mar 20, 2010 at 12:06
I have run those tyres on 80 and 100 series with 40 - 42 psi on the highway. Keeps the wear even across the tread while still providing a firm ride with some degree of suppleness. Any lower the sideblocks wear too quickly.
I dont lower them for the dirt/gravel considering the weight in the back and the camper trailer but will lower the speed for the conditions. No punctures in 3 sets that endure 100,000km of mostly highway but certainly many thousands of km rough gravel roads and tracks.
AnswerID: 409605
Reply By: Member - Wayne B (NSW) - Saturday, Mar 20, 2010 at 13:08
Thanks guys.
I thought 22 may be too low for rough roads however I can see that you need to keep the tyre as supple as possible . I can believe max speed would not be very high at this pressure. I imagine I would have to pump then back up as soon as the going got better.
28 COLD seems a good compromise for a reasonable speed, grip and stability on loose surface.
I know you have to keep the pressure high on the Highway simply to reduce edge wear on the tyres.
Thanks again for all your advice.
Wayne B
AnswerID: 409610
