Stone shield
Submitted: Wednesday, Mar 24, 2010 at 18:11
ThreadID: 77151 Views:4903 Replies:6 FollowUps:3
I am interested in making a stone shield for our caravan. Does anyone have details on a mesh stone shield that is fitted under the 'A' frame. Details and pictures would be appreciated. Cheers
Reply By: Notso - Wednesday, Mar 24, 2010 at 18:41
If you want to protect the van from stones you'll need more than the under A Frame version.
There are heaps of versions around most of em have something like Shade Cloth stretched not too tightly over a framework.
This stops the stones bouncing off the fabric and into your back windows as well
AnswerID: 410231
Reply By: dirttracker - Wednesday, Mar 24, 2010 at 20:14
George,
take a look at this.
http://www.stonestomper.com.au/
I have one behind a Prado and in front of a Jayco Eagle Outback. All good. Simple and straight forward. They are a good mob to deal with. I am not affiliated, etc...
regards
Martin
AnswerID: 410250
Follow Up By: Member - George (WA) - Thursday, Mar 25, 2010 at 00:37
Thanks Martin, I will check it out. May be just what I need. Cheers
FollowupID: 680172
Reply By: Member - Toyocrusa (NSW) - Wednesday, Mar 24, 2010 at 20:18
Hi George. This unit belongs to my brother and has travelled around 30000Km so far. At least half on dirt with no stone damage to van or car. It is heavy shadecloth doubled over a frame to suit the width of the van. Bob.Image Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
AnswerID: 410252
Follow Up By: Member - George (WA) - Thursday, Mar 25, 2010 at 00:40
Thanks Toyocrusa, not enough room on top of my A frame. Cheers
FollowupID: 680174
Reply By: brushmarx - Thursday, Mar 25, 2010 at 10:14
If you are not too fussy about appearance, a piece of concrete slab arc mesh with shade cloth over it works fine.
You can cut a hole on the mesh to allow the A frame to protrude so it hangs under the A frame as well as over for protection, and a couple of occy straps will hold it in place.
Only takes a few minutes to make, very few dollars, takes 2 minutes to fit or remove, and you can modify the shape and size easily to suit your caravan if you wanted to make a more professional looking stone guard.
Ours has lasted 25 000 k's so far over 3 years, but the shade cloth needs replacing.
We held the shade cloth on with the wire mesh fence circle thingies that squeeze on with special pliers.
Cost about $10 including the fence pliers and clips, and we have had no stone chips, broken rear window, or tail lights yet.
AnswerID: 410302
Reply By: MEMBER - Darian, SA - Thursday, Mar 25, 2010 at 11:09
I just tossed one together George - used pvc conduit and shadecloth - in my view, not worth making something "el-swisho" because it gets very dirty at times and damaged eventually. With the vehicle and van hitched up, I simply measured the area in between the van's front and the car and got some shadecloth to suit.
I made cutouts to suit the various objects on top of the draw bar area (gas etc.) To hold it all, I have a piece of PVC conduit crossways for and aft to hold the cloth - the cloth is fastened to the tubes with a host of small cheap cable ties.
The PVC tubes are tied to points on the van and car with ockies to keep the whole thing elastic, for turning etc. I store it in the poles tube built into the van - Whatever - has worked ok for us so far. Used the same setup on our hardfloor camper trailer too. BTW - it could of course be made to go under the draw bar, but would get damaged in no time at all as I see it, on those long gravel roads.
AnswerID: 410307
Follow Up By: CJ - Thursday, Mar 25, 2010 at 12:47
Looks easy enough to make yourself.
BTW I like the idea of it being under the drawbar, the whole idea is that it gets damaged (as opposed to damaging the trailer)
CJ
FollowupID: 680211
Reply By: PradOz - Friday, Mar 26, 2010 at 21:12
Hi George
few of them here: stone guards and more to give you some ideas on where to start. Just scroll down and you should find them, cheers....
AnswerID: 410562
