Blue Airbags ?
Submitted: Monday, Mar 29, 2010 at 12:02
ThreadID: 77284 Views:4490 Replies:2 FollowUps:8
Hi all, i know this topic has only recently been discussed but my new vehicle has with Blue air bags already installed and there was no mention of that particular colour.Red and Black were covered in discussion.
My question is, what type of air bags are they and what would be the recommened air pressure required when towing.
Reply By: pmk03 - Monday, Mar 29, 2010 at 12:26
G'Day,
Mine are Blue, They are Firestone. They have been in now for almost 3 years & I have not had a problem. Fitted to a GU Patrol.
Not sure right now, but I think the max pressure is 30 psi. That might differ depending on the vehicle.
I drop mine down to around 5psi when I have no load in the car.
PMK
AnswerID: 410888
Follow Up By: jeep cherokee - Monday, Mar 29, 2010 at 13:35
Thanks for that. I do keep them at 10 psi when not loaded, but the max pressure is the one i'm not sure of.
Cheers.
FollowupID: 680912
Reply By: Alloy c/t - Monday, Mar 29, 2010 at 13:56
Red are generally PolyAirs , 5psi to 35psi , Blue are generally Firestone Coilrites , 10psi to 100psi , Black a generally stand alone AirBags that can and do take more weight.
AnswerID: 410895
Follow Up By: pmk03 - Monday, Mar 29, 2010 at 14:10
Having said that I only need to put around 25 psi in my Firestones when towing a Jayco Eagle Outback camper.
PMK
FollowupID: 680915
Follow Up By: pmk03 - Monday, Mar 29, 2010 at 14:29
Just found the installation instructions online for the Firestone Coilrite Blue Airbags & it says pressure range from 5-35 psi .( similar to the polyaire)
Maybe there are other Firestone Airbags around but the ones I have are Max 35 psi.
PMK
FollowupID: 680917
Follow Up By: jeep cherokee - Monday, Mar 29, 2010 at 15:25
Thanks for the replys, i will try 35psi at first and see if they require more as i go.
FollowupID: 680922
FollowupID: 680923
Follow Up By: jeep cherokee - Monday, Mar 29, 2010 at 15:26
Oops doubled up on that one :(
FollowupID: 680924
Follow Up By: Peter McG (Member, Melbourne) - Tuesday, Mar 30, 2010 at 11:29
Instructions for the Firestone bags are here:
Firestone Coil-Rite instructions
FollowupID: 681070
Follow Up By: jeep cherokee - Tuesday, Mar 30, 2010 at 13:56
Thanks Peter, very interesting.
FollowupID: 681087
