Data Needed for CSR Plot
Hi Guys
As we are planning to drive up the Canning in the 2 weeks following the gathering I am trying to put together a plot of the CSR.
There is good information already on this site, but it has the Canning in 70 seperate short sections which is not suitable for most GPS'es.
I could use this data, but it would be a lot of cut & pasting & joining and prone to error.
So searching for either a whole plot on even large sections to work with.
(Will have computer at Exploroz Victorian camp this weekend)
Reply By: Peter McG (Member, Melbourne) - Tuesday, Mar 30, 2010 at 10:31
Robin,
I have a plt file I can email you - send me a message with email details.
AnswerID: 411033
Follow Up By: Robin Miller - Tuesday, Mar 30, 2010 at 12:56
Thanks Peter , all worked fine
FollowupID: 681082
Reply By: Member - John Baas (WA) - Tuesday, Mar 30, 2010 at 12:26
Robin, if you hit the download trek button on this site's CSR treknote you'll get the full plot as one file incl the waypts. At least I did.
Cheers.
AnswerID: 411049
Follow Up By: Robin Miller - Tuesday, Mar 30, 2010 at 13:02
Hi John
Yes you can download as one file , but that file consists of 70 seperate tracks , which would have to be joined.
Peter has sent me a file which is continuous, so I have something much easier to work with now.
FollowupID: 681083
Reply By: ExplorOz Team - Damian - Tuesday, Mar 30, 2010 at 12:59
Hi Robin,
Yes John is right.
If you click into the Canning Stock Route trek note, and click the link that says "Download Trek", you will get the choice of downloading a .gpx file or a zip file containing both an OziExplorer .wpt and .plt file. If you kept the default radio button and downloaded the .gpx file, importing this into OziExplorer will create individual plot sections as you mentioned. Please choose the OziExplorer radio button, download the file, unzip the contents and load the .plt file into OziExplorer. You will find, this is ONE plot section. You can then load the waypoint .wpt file into OziExplorer to see all the waypoints.
Hope this helps.
Damian
AnswerID: 411056
Follow Up By: Robin Miller - Tuesday, Mar 30, 2010 at 16:42
Hi Damian
Tried that method and did produce a single file of 6000+ points.
This still requires to be broken into a few parts for Garmin type GPS downloading , but this saves a huge amount of work in joining up all the little tracks sections.
Thank you.
FollowupID: 681120
