Changing Damaged Caravan / Camper Trailer Tyres While Travelling.
Submitted: Friday, Apr 09, 2010 at 12:39
ThreadID: 77577 Views:9002 Replies:7 FollowUps:9
Just wondering how people change their Damaged Tyres while travelling?, what procedures they go through ect, what type of Jacks do they use, Wheel Chocks, Base Plates, Saftey Triangles, and more importantly keeping the passengers in the vehicle especially kids, so they don't wander around beside a busy road,
*I use a Side Winder Jack with a Base Plate, there are two Jacking Points on either side of the caravan, they are located behind the rear tandem wheel.
*I also have two Reflective Saftey Triangles in case I can't get right off the road to do it in saftey, and also switch on the Vehicle Hazard Lights.
*It's a different thing if your Vehicle has a Damaged Tyre, and having to disconnect the Van or Camper Trailer before jacking the vehicle up, re: less weight on the jack, I use a Windup Bottle Jack for the 4by.
As I said, just wondering how you all do it.
Reply By: Member - Beatit (QLD) - Friday, Apr 09, 2010 at 12:54
G'day Daza,
Your post reminds me of a traffic snarl a few months ago. The problem was that a van with a flat tyre had come to a stop in the middle of the road (M1 just north of Brisbane airport). The chap was changing the tyre in the middle of the road on a bridge in very busy and irate traffic. It was hard to believe when just a little further he could have pulled over. So I want to add "pull over" to the list.
I've not had a flat on the van but have had one on the camper trailer. I guess it was easier to just come to a stop on the Kalumburu road then the M1!
Image Could Not Be Found
Kind regards
AnswerID: 412250
Follow Up By: Member - DAZA (QLD) - Friday, Apr 09, 2010 at 13:17
Yes I agree pull over, for us having the Tandem Wheels it's not such a drama as you can still travel a distance and find a suitable place to do the job.
FollowupID: 682221
Reply By: Member - Oldbaz. NSW. - Friday, Apr 09, 2010 at 13:05
G'day Dazza, I carry a 2 ton trolley Jack & use it for 4by & C/t. Many consider
these too bulky & heavy, & they are both, but very easy to get in the right spot
without having to crawl underneath. The lifting is easy & I never disconnect the
C/t. I still carry the screw jack that came with the wagon & a small bottle jack as
well as back up. I carted a high lift on my first outback trip, but never again. Too
big ,too heavy & too dangerous. I still use it around the farm but most are little
more than ballast on most 4bys. I carry a base plate for the trolley but rarely need to use it. cheers....oldbaz.
AnswerID: 412251
Follow Up By: Member - DAZA (QLD) - Friday, Apr 09, 2010 at 13:20
It seems like you have thing sorted with the 2 Tonner.
FollowupID: 682222
Reply By: Member - Doug T (NT) - Friday, Apr 09, 2010 at 14:02
I think most pull over to a stop rather than do it while travelling...Cough...cough.
AnswerID: 412261
Follow Up By: Member - DAZA (QLD) - Friday, Apr 09, 2010 at 16:07
Geez Doug you have to stop, can't do it on the move mate lol lol. that Territorian Wit is getting better and better.
FollowupID: 682238
Reply By: Dave B ( BHQ NSW) - Friday, Apr 09, 2010 at 14:23
Daza, I only use the normal jack that comes with my 60 series LC, and if I can't get it under the axle without any trouble, I run the vehicle or CT up on a block to get it a bit higher.
Regardless of the state of the tyre, driving up onto a block is not going to do any more damage, but allows you to slide the jack under the axle without any trouble.
I normally have levelling blocks in the CT, so that's what I use.
If it is a busy area, I have a safety vest in the vehicle all the time, and I also have one of those emergency flashing beacons as well, just in case.
If the flat is on the car, everybody out and off to the side of the road for sure.
Dave
'Wouldn't be dead for quids'
AnswerID: 412263
Follow Up By: Member - DAZA (QLD) - Friday, Apr 09, 2010 at 16:09
Yes the Safety Vest is a good idea.
FollowupID: 682239
Reply By: Adey - Friday, Apr 09, 2010 at 15:21
If you get the most recent addition of '4WD Action Camper Trailer Touring' there is an extensive article on changing/repairing trailer tyres.
AnswerID: 412267
Follow Up By: Adey - Friday, Apr 09, 2010 at 15:23
Apologies for above typo - that should be 'edition' and not 'addition'.
FollowupID: 682231
Follow Up By: Member - DAZA (QLD) - Friday, Apr 09, 2010 at 16:15
It would be handy for any Newby just starting off to read and get some ideas.
FollowupID: 682242
Reply By: Motherhen - Friday, Apr 09, 2010 at 16:52
Hi Daza
Usually wait until we get home!Well that was the luck of the draw on the last two big trips; we got a flat in front of the house when we got home after all those kms.
In addition to that we did have one blow out last year on a caravan tyre (original tyres from F250 so over six years old). We were on a road where there were drop offs both sides, trucks using the road and not really safe to stop. We had to go a couple of kilometres or so before we could pull off at a farm gate. There was no damage to the rim. Apart from a pop sound, we wouldn't have known about the blow out either as the van rode true (Simplicity suspension).
We travel with two jacks - usually a bottle and a trolley jack and have needed both on a number of occasions - for ourself and to help others. We also have flashing LED light safety triangles, but have not needed to use them. We got them after an incident on the Stuart Highway in 2006 when the tow bar broke, again on a spot with drop offs, so we were just off the bitumen. We could not drive further along the road to a safer spot. We had two bottle jacks with us and needed both to lift the a-frame. My husband stayed with the caravan while i went some distance to get repairs done to get us mobile. It was OK until dark, when trucks were rushing past close by rocking the caravan which was not all that visible. My husband put the internal lights on and opened the curtains, and was still felt threatened by the trucks. The van was not easy to see on a dark night.
AnswerID: 412273
Follow Up By: Member - DAZA (QLD) - Friday, Apr 09, 2010 at 19:57
Hi Mother Hen
Touch wood we haven't had any tyre problems yet, but it's bound to happen sooner or later, I was thinking about the problems people might have when I was doing some prevenative maintenance on the van today, I was using the Side Winder Jack and was amazed how easy it was to lift the van with little effort.
FollowupID: 682278
Reply By: Member - George (WA) - Friday, Apr 09, 2010 at 17:55
Get a "Trailer Mate" jack. No mucking about under caravan to position a bottle jack. The Trailer Mate jack fitts into the jacking point behind the rear wheel at the side of the caravan, and will lift both wheels at the same time. Best investment you will ever make. Cheers
AnswerID: 412279
Follow Up By: Steve Ellis - Friday, Apr 09, 2010 at 19:12
GHday George. I believe you are right. trailmate way to go. Expensive but worth it. I am a lousey B%gger { thanks to GFCrisis} and I bought a 1,4tonne trolley jack from supercrap for my van [Not heavy] 1.4 T total weight. It would not lift one side! I could not exert enough force on the handle to lift it. Only get what you pay for. I am old enough to know that but looking for cheap way out. Silly old begger.
FollowupID: 682266
Follow Up By: Member - DAZA (QLD) - Friday, Apr 09, 2010 at 19:49
Hi George that's similar to our Side Winder Jack, it lifts both wheels at the same time, at the jacking point.
FollowupID: 682276
