Anderson plug
Submitted: Sunday, Apr 18, 2010 at 14:33
Member - Greg H (NT)
Gidday all,
I have a
grey Anderson plug fitted to the back of my vehicle and the other to the camper trailer.
I am disappointed with the plug as over dirt roads it tends to rattle out. Maybe I am wrong, but i thought this type of plug would clip together and remain that way or did i get a dud?
Is there another type of plug that can handle the rigours of off road?
Reply By: Rockape - Sunday, Apr 18, 2010 at 14:41
Greg,
something is wrong as they are great plugs, robust and don't come apart easily.
The plug may have been assembled wrong or for some reason the tension has gone out of the spring steel inserts that retain the contact pins.
413416
Reply By: Tenpounder (SA) - Sunday, Apr 18, 2010 at 14:45
Hi there. I remember, some time back, when I bought a pair of Andersons to upgrade the 12v supply to the caravan's notorious 12v Electrolux fridge. (But we won't talk about that now!!)
I had some strife with the installation, and it was because the cable must sit properly in the casing, and the actual contacts must be correctly located in the casings as
well, otherwise they will not lock in properly. So the fixing of the cables into the contacts must not distort the 'lie' of the contacts, and the contacts must sit correctly into the
grey plastic mouldings.
In my case, it was impossible until I got it right, and dead easy once I did get it right.
If your joints a rattling loose, I'd bet the contacts are not properly aligned within the casings, and so can't click together properly.
413418
Follow Up By: Member - Greg H (NT) - Sunday, Apr 18, 2010 at 15:09
I reckon I have the same problem that you had. One of the pins seems loose. How do you get the pins out? The electrician (expert?) installed
mine and i didn't see him do it.
683508
Follow Up By: Tenpounder (SA) - Sunday, Apr 18, 2010 at 15:17
All I can recall is a suitable mixture of rude words, a screwdriver, pliers and brute force. But the scientific use of the screwdriver won out! This allowed me to withdraw the connector in question, melt and resolder the joint, and then reassemble.
Sorry, but I really can't fill in the blanks so long after the event. But I can say that, if an autoelectrician fitted it, then he can also fix it!!
It may be simpler to sacrifice the faulty connector and simply buy a new one, or else take up the kind offer from your fellow Territorian
683509
Reply By: Member - Noel K (NT) - Sunday, Apr 18, 2010 at 15:00
Hey Greg,
Something wrong there, I have quite a few Anderson's with no troubles. If you are in
Darwin send me a member message and I'll see if I can help.
Noel K.
413421
Reply By: Member - Greg H (NT) - Sunday, Apr 18, 2010 at 15:15
Problem solved. One of the pins was not in correctly, had a fiddle and bingo. I'm happy now!
413425
Reply By: Mandrake's Solar Power- Sunday, Apr 18, 2010 at 17:01
I bought some pins for 10-12 size cable the other day and they don't "snap" click like the size 6 ones - perhaps you have these in instead of the size 6 ones ??
There should be a audible click when the 2 connectors are put together ..
Steve
413444
