Drawbar Boxes etc ...
Submitted: Sunday, Apr 18, 2010 at 19:32
Mandrake's Solar Power
I am having a drawbar box built to house spare tyre (trailer's) 2 Jerry can
water and
fuel , porta-potty . and gas bottle ...
Image Could Not Be Found
When fully loaded it will probably add about 100 Kgs to the drawbar - Still
well under the 210 allowed by Jeep towbar specs ...
Do I need to do anything with Motor Vehicle Reg - Roadworthy ??
For info this will be made from 2.5mm Aluminium sheet and will have drop sides and locakble lid ..
Steve
Reply By: Member - Graham H (QLD) - Sunday, Apr 18, 2010 at 19:34
Must be a pretty light van to have a ballweight of under 100kg
413472
Follow Up By: Mandrake's Solar Power- Sunday, Apr 18, 2010 at 19:42
Its not a van its the Tardis - all up weight fully loaded was 600 Kg - ballweight was 60Kg -- Empty it weighs in at 250 Kgs !!
Steve
683564
Follow Up By: Member - Carl- Monday, Apr 19, 2010 at 08:58
Can you do a post on your trailer.
Cost
what changes you have done,
does it come with Patrol / landcruiser
wheels,
what you use it for?
It looks very interesting.
Carl
683611
Follow Up By: Mandrake's Solar Power- Monday, Apr 19, 2010 at 09:05
Carl ,
There's a blog on the Tardis re-fit in the my blog link below ...
It comes with standard trailer
wheels and a camper unit installed ..
Steve
683612
Reply By: Member - Graham H (QLD) - Sunday, Apr 18, 2010 at 20:16
It appears to be an offroad capable unit but perhaps the A frame may not be up to having an extra 100kg or so above the point that usually bends when overloaded
Will probably be over 100 with two jerrys 43kg, spare 35, gas bottle 15 and portapotti 20? plus the weight of the box.
413480
Reply By: crd patrol - Sunday, Apr 18, 2010 at 20:20
Steve,
Just make sure where it attaches to the drawbar is strong enough to take the maximum weight you are going to add to it.
I just got a trailer made with a box on the front (1200mm x 1200mm x 700mm) and they used 6 small tek screws to hold it to the drawbar, nothing else, I actually thought it was gong to fall off on the trip home. I have since fixed this myself and now the box sits on a subframe and that is bolted to 6 angle brackets welded to the chassis rails with 6, 3/8 high tensile bolts with nyloc nuts and spring washers. Yes I know I should have taken it straight back but I needed the trailer for a trip up north, and as the old saying goes "if you want something done right do it yourself"
crd
413481
Follow Up By: Mandrake's Solar Power- Sunday, Apr 18, 2010 at 20:39
There will be a steel angle sub frame to hold the whole box in place - not sure about the fastening yet but will check with the builder when I deliver the Tardis to him next weekend for assembly ..
Steve
683575
Reply By: Member - The Bushwhackers -NSW - Sunday, Apr 18, 2010 at 21:05
Hi Steve
I'm not sure you are 'adding 100kg', you already have the spare and gas bottle mounted on the A frame anyway, so just the weight of the box itself (prob not too much as it's aluminium, 2 jerrys (say 45 kg when full), and porta potti (reckon
mine weighs about 5kg empty).
If the box is set back as close to the pod as possible, to minimise the mechanical advantage of the weight, it will be better still.
You still need to make sure, as others have said, that the A frame is strong enough, and the box securely fixed. Like I said, half the weight that is going in the box is already on the frame, all you are really doing is rearranging the distribution of that weight, and adding some.
Cheers, Dave
413486
Reply By: Rockape - Monday, Apr 19, 2010 at 06:43
Steve,
you may wish to extend the angle sub frame for some length, to spread the load along the A frame.
Fixing to the A frame itself could be done using U bolts or similar, this will allow you to remove the box easily and not interfere with the A frame.
Have a good one
413514
Reply By: Member - Carl- Monday, Apr 19, 2010 at 08:53
Hi Seve,
You did not say what type of van you had but I thought I would show you
mine. Might give you some additional ideas. I store different things but I have also descovered it is a great way of also having a stone guard as
Mine can also be used for a
water tank for short distances. Takes the annex struts and drain hoses as
Probably more important, are the dust seals which work great and this type of lock is good for security.
413522
Reply By: Peter_n_Margaret - Monday, Apr 19, 2010 at 10:36
Make sure the battery is completely isolated and sealed from the
fuel and gas which must be vented properly if enclosed.
OKA196 Motorhome
413529
Follow Up By: Mandrake's Solar Power- Monday, Apr 19, 2010 at 10:47
Peter ,
No worries the battery resides happily in the side jerrycan holder as I couldn't find a 20 Litre Jerry can that would fit in the sideways space ... Got a 10 Litre on the other side ! So with this box I will have 300 Kms of
fuel !!and that means 1000 Kms before needing to refill !! Can't wait until next April !! LOL
Steve
683621
Reply By: CJ - Monday, Apr 19, 2010 at 20:08
Guys,
In general be aware that weight on the drawbar affects towing - the max speed before you get a death wobble greatly decrases with weight on the drawbar - it is a simple physics fact
The industry is being led by customer demand and one sees massive staoage on the drawbars. There is a reason for the drawbar and it is to get the weight back
DIY beware
The last thing you want when you speed up to overtake a truck ...
CJ
413578
Follow Up By: Lex M (Brisbane) - Tuesday, Apr 20, 2010 at 09:18
"In general be aware that weight on the drawbar affects towing - the max speed before you get a death wobble greatly decrases with weight on the drawbar - it is a simple physics fact"
This seems to totally the opposite to what is usually said. Have you any refences for this information please?
683720
Reply By: CJ - Tuesday, Apr 20, 2010 at 17:15
Lex,
The further back the centre of gravity is from the tow vehicle, the higher the speed that it can be towed. That is the general law applied.
Even if you attach slays insted of
wheels, this basic law applies equally.
Manyufacturers have to balance functionality, so drawbars can't are too long. But then we the users load the front up, so we bring the horizontal centre of the load forward, and decrase safe towing speeds
CJ
413664
Follow Up By: CJ - Tuesday, Apr 20, 2010 at 17:57
fat fingers typing too fast sorry for the typos
683773
