Duel Battery Setup
Hi Everyone,
This is my first time so go easy.
I'm looking at setting up a Duel Battery system in our 105 Diesel (non turbo)LandCruiser.
While I think I've got a clear understanding of the standard setup I'm wondering what is involved to also wire in my engel Battery Pack?
i.e main battery, agm Deep Cycle Battery and then the Engel BatPac in the rear
I currently have a 12v charger wired into the back coming directly from the Main Battery?
Any help would be most welcome and hugely appreciated.
Reply By: Member - Allan B (QLD) - Sunday, Apr 25, 2010 at 22:58
Hi Jack, just connect your Engel Battery Pack to the deep cycle battery but be sure there is a fuse at both ends of that cable unless it is a very short cable with no chance of faulting.
AnswerID: 414282
Follow Up By: Outback-Jack - Sunday, Apr 25, 2010 at 23:06
Thanks Allan,
Appreciate the advice, If I could impose a little more, does that mean I continue to run the 12v engel charger? and will it run the aux batterys down together or drain the BatPac first?
FollowupID: 684501
Follow Up By: Member - Allan B (QLD) - Sunday, Apr 25, 2010 at 23:15
I assumed that the charger was a 12v dc to dc charger from the main cranking battery (and hence, alternator) to the auxiliary battery.
Regardless, with the BatPac in parallel with the aux battery, they will behave as though one battery during charging and discharging. I would have thought that the BatPac was to be used to run the fridge when removed from the vehicle and be recharged when returned to the vehicle. Have I got that all wrong?
The alternative is that if left permanently together, the BatPac will simply be adding some capacity to the aux battery.
FollowupID: 684504
Follow Up By: Outback-Jack - Sunday, Apr 25, 2010 at 23:26
Thank again Allan
To give a little more detail, I already had the Batpac and was using it in our Hilux. Having recently purchased the Cruiser I thought that I would ad a duel battery system as it has more space under the bonnet.
Seems a waist to discard the Batpac and was thinking it would give us additional power when stationary and would also allow the option of portability should we ever require. Having said that the fridge usually remains in the truck.
FollowupID: 684505
Follow Up By: Member - Allan B (QLD) - Sunday, Apr 25, 2010 at 23:32
Yep, that would be OK Jack. The BatPac will add some capacity to your aux system and be available for off-vehicle use also. Depending on the battery types of the aux and BatPac batteries it may not be a perfect match for charging and thus stored capacity but will be near enough and certainly better than the aux battery alone.
FollowupID: 684506
Follow Up By: Outback-Jack - Sunday, Apr 25, 2010 at 23:39
Thanks Allan
Greatly appreciated, happy travells and look us up when you next head south.
Cheers, Jack
FollowupID: 684507
Reply By: Member - John and Val - Monday, Apr 26, 2010 at 08:59
Hi Jack,
Welcome aboard!
Further to Allan's reply - If I understand your post correctly, the plan is to install the AGM in the engine bay and the Engel pack in the back with the fridge. IF (and only if!) I'm right in thinking this, the 12v-12v charger introduces further considerations.
These devices are excellent, optimising charging voltage for batteries - especially good to overcome voltage losses in wiring when the battery is remote from the alternator. In your case though only one of the batteries is remote.
The 2 batteries could simply be wired in parallel (with fuses as Allan suggests) and the composite fed by the 12v-12v charger in the engine bay. But this will result in the Engel pack not getting the advantage of the charger. Further, since both Engel pack and fridge in the back of the vehicle will be drawing current through the one feed line, there will be a significant voltage drop. The Engel pack will be pretty slow charging and probably never get a full charge.
An alternative is to put the charger at the back with the Engel battery pack, i.e. from an electrical point of view, between the two batteries. In this configuration, the front battery misses out on the benefits of the charger, and will continue to contribute current to the loads in the rear when the alternator isn't running. This may be OK, provided the charger is pretty efficient.
I guess it comes down to the fact that with the batteries not close together, only one can benefit from the charger. I'd be inclined to give that benefit to the battery remote from the alternator. (A further alternative of course would be to install the AGM in the back of the vehicle...... decisions.....decisions...!!)
One further point - You say that the charger is currently fed "directly" from the main battery. Very important to have all wiring pass through fuse/s close to the battery to minimise fire risk.
Sorry to turn a simple matter into something more complex!!
J and V
- Albert Einstein
AnswerID: 414304
Follow Up By: Outback-Jack - Monday, Apr 26, 2010 at 21:48
Thanks John,
Appreciate your taking the time to assist.
As you've no doubt guessed Im a relitive novice when it comes to all things electrical.
At this stage I am planning to mount the Deep cycle battery up front in the space provided, I have already wired in the batpacs charger and that now fits snugly into the rear of the truck not far from the Batpac. If I'm reading you correctly you would suggest that I take the existing positive wire from the main battery and attach it to the Auxiliary battery instead and then just plug it in as normal to the Batpac which in turn plugs into the fridge is that correct? Should I have fuses in the positive wires?
Thanks again John
Jack
FollowupID: 684619
Follow Up By: Member - John and Val - Tuesday, Apr 27, 2010 at 08:26
High Jack,
First - Apart from the leads going to the starter and the vehicle's own fuses, EVERY other connection to any battery should pass through a fuse close to the battery. There is a lot of energy stored in a battery - enough to start a fire if a very high current flows, as can happen if the insulation is damaged and the bare +12V wire touches the vehicle chassis. A fuse (I use 20A or 30A fuses close to batteries) will protect against this.
My approach in your case would be to feed from the cranking battery through a fuse then through a relay (see below), through another fuse to the AGM. The line to the back of the vehicle should be fairly heavy (at least 6 square mm copper) and I'd connect it on the AGM side of the relay. This point is secured by the 2 fuses and will carry current from the alternator when the engine is running, and from the AGM when the engine is stopped.
At the back, I'd run the feed from the front to the 12v charger and the output of the charger to the Engel battery pack and fridge.
The relay - All of this extra wiring and batteries must be disconnected from the cranking battery when the engine isn't running. A relay is simply an electrically operated switch. A simple relay will do what's required - the cheapest (<$20) way is to use a 30A headlight relay, which is operated by the ignition circuit. Better still through a switch connecting it to the ignition circuit. The switch will allow you to manually turn on the relay, but only if the ignition is turned on; this way you can leave everything disconnected until the motor is running and delivering current.
A more popular option is to use a VSR - voltage sensing relay ($100+). This will make the connection automatically, but only after charging voltage is present. They are said to delay making a connection until the cranking battery has been charged, but in my experience they usually operate as soon as the alternator is up to speed. I use the cheap system, with a few embellishments to render it fully automatic - bit complicated to describe here!
Hope that all makes sense!
J and V
- Albert Einstein
FollowupID: 684643
Follow Up By: Outback-Jack - Wednesday, Apr 28, 2010 at 18:53
Thanks again guys,
I cant believe how helpfull the people are in this forum. Its good to know that no matter how busy life gets, we still have people who retain those great Aussie values and are always happy to help!
Looking forward to hopfully returning the favour at some stage in the future.
Many Thanks
FollowupID: 684782
